Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendor Forums > PTPerformance
Old 10-08-2008, 04:07 PM   #16 (permalink)
sti_zee's Avatar
Member Number: 40201
Quote: Originally Posted by mole' View Post
if you plan to use the Queasy as a return source, you will need a bottleneck fix feed line........
make a bottleneck fix with a quick-disconnect to fit factory line and a feed hose that will remain 100% ok when submerged in gas and you're gold. sell the bneck fix/queasy together. no-brainer. this is what i originally thought you were doing.
sti_zee is offline   Reply With Quote
Old 10-08-2008, 05:52 PM   #17 (permalink)
Moparahollic05's Avatar
Member Number: 54793
Hope this might help in any confusion....
Bottleneck fix installed in pump, no Queasy....
[IMG][/IMG]
Bottleneck fix (not the same^^^)...
[IMG][/IMG]
Queasy installed in pump...
[IMG][/IMG]
You could picture the two together.
What i would love to see in a kit would be a high flow walbro fuel pump inside the canister with the bottleneck fix installed, kinda like DCRs. A return supply Queasy, all the anoide fittings, bradied fuel lines, a regulator with brackets to mount in a good location, kinda like AGPs, then a quick connect fitting to go the the stock rail.
I realize that this would be an expensive way of going about it, but it really would be a complete kit, with little doubt as to what your getting and how it would perform. On a side note, whatever it turns out to be, ill buy
293HP, 349TQ
8.258@87 1/8 mile pass
12.925@108 1/4 mile pass
Moparahollic05 is online now   Reply With Quote
Old 10-10-2008, 04:58 PM   #18 (permalink)
aww sheet's Avatar
Member Number: 20431
Trader Rating: (31)
i need to get that quick connect so i won't have to run a new line all the way to the fpr but, how would you connect a inline filter with that fitting?
View Modifications
Old 10-11-2008, 11:50 PM   #19 (permalink)
RicanSRT4's Avatar
Member Number: 56171
I realize that this would be an expensive way of going about it, but it really would be a complete kit, with little doubt as to what your getting and how it would perform. On a side note, whatever it turns out to be, ill buy.
You forgot the fuel pump rewire to complete all fuel system upgrade!
AGP S256 & SCT and stuff...
RicanSRT4 is offline   Reply With Quote
Old 10-12-2008, 06:03 PM   #20 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (567)
We are working on that right now. It would be easy to do, so yess. I just have to get the proper fittings for that application.
Home of the DSP Tuned 657 WHP SRT4 Neon, 593 WHP SRT4 Caliber and the fastest stock turbo DSP tuned SRT4
DSP or Trinity
Old 10-12-2008, 06:04 PM   #21 (permalink)
I am waiting on the fuel rails to get done. Then we are golden to move forward with this kit.
Old 10-12-2008, 10:20 PM   #22 (permalink)
aww sheet's Avatar
Trader Rating: (31)
cool keep up posted. i'll be the first to buy. you did get my order for the queasy, and the led bake light right?
Old 10-21-2008, 06:50 PM   #23 (permalink)
RicanSRT4's Avatar
got the queasy in stock yet?
Old 10-21-2008, 08:02 PM   #24 (permalink)
aww sheet's Avatar
Trader Rating: (31)
^^^just got mine
Old 10-22-2008, 05:06 AM   #25 (permalink)
RicanSRT4's Avatar
I hope to get mine before on this week ends!
Old 10-22-2008, 10:11 PM   #26 (permalink)
Wait till you see what I have to offer up next!!!
I will be making this a sticky for everyone to read up on. Thanks.
I think everyone's order has shipped.
Old 10-23-2008, 09:37 AM   #27 (permalink)
Member Number: 26275
I've had mine for quite some time now...for anyone that is confused on the set-up, this is how it would go...
Walbro pump - bottleneck fix - feedline w/ filter - Fuel Rail - Return Line hookup - FPR - Return Line - Queasy
Very simple to hookup, just make sure to put some silicone around the queasy before you put it in the canister, it's a good tight fit but mine did leak a little bit.
2004 E-BLUE SRT-4
EssArTee-4 is offline   Reply With Quote
Old 10-23-2008, 01:35 PM   #28 (permalink)
aww sheet's Avatar
Trader Rating: (31)
well tell us already damnit!!!!!!!!!!
ok should i wait to order the bottle neck fix?
Old 10-23-2008, 05:49 PM   #29 (permalink)
RicanSRT4's Avatar
[quote=ptperformance;6624557]Wait till you see what I have to offer up next!!!
So what's next I just need a fuel rail to complete the upgrade....
Old 11-12-2008, 07:39 PM   #30 (permalink)
aww sheet's Avatar
Trader Rating: (31)
info info
Page generated in 0.20876 seconds with 13 queries
