Old 05-05-2007, 12:03 PM   #706 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (534)
The exhaust leak is the culprit, fix that since the WB will get erratic readings the autotune is freaking out. Dawg send it, thanks.
Old 05-05-2007, 06:42 PM   #707 (permalink)
SRT-SanDawg's Avatar
Member Number: 17932
He should be good now, I left him my # if he has any issues with getting the file.
SRT-SanDawg is offline   Reply With Quote
Old 05-05-2007, 06:56 PM   #708 (permalink)
SRToc Member
barrr's Avatar
Member Number: 10243
Got it,
Thanks again!!!
Richard
Don't argue with an idiot; people watching may not be able to tell the difference.
barrr is offline   Reply With Quote
Old 05-08-2007, 07:50 PM   #709 (permalink)
Ok, got the car up and running. Tuning with the FTM has been INCREDIBLY easy to do.
Initially I had -11% globaly before I even started assumeing there would be WAYYY too much fuel by leaving it at 0%. Initial start up after priming oil AFR's were 10.5-11 at idle. Obviously a little rich... Immediatly shut it down pulled -30% just as a rough estimate. Mid 15 AFR's at Idle. Cool... Pulled it down to -28% just to be safe... 14.7-15.4:1 at idle. Great!
Pulled out on the road... AFR's though RPM band (no boost) were consistant High 14's, low 15's. Even Better!
Now for the boost... Nailed it... Spiking 20#'s slowly dropping to 15-16. AFR's all through boost are 10.1-10.5 Awesome! Time for autotune... Enabled TPS & Boost Triggers. 80% & 15psi. sens 17, adj% 19. Too drastic... soo as I got on it.. It went 10's for 1 sec, then to mid twelves at the peak of it's fluxuation then comming back down to 11.2-11.3 (Preferred AFR) . Fome here I disabled TPS trigger and did it soley on boost... remaining at 15#'s and also reduced sens/adj% to 12/14 . Got on it again a couple more times and soon as I get on it AFR's dip to 10's for not even a second then AFR's come up to 11.1-11.4 Which is great through out RPM Range.
I'm not really supprised john. Great product. I can't to get some more time in tuning.
Thought I'd share.
Later
Sandy
Edit: Fuel Mods are RC750's + FTM on S0. Other mods: 4" Downpipe+E-cutout + 3" No res, no muff catback + Uego + new fuel pump rewire + checkvalve + MM inserts. Other stuff here... but not installed yet.
Old 05-18-2007, 07:41 PM   #710 (permalink)
Member Number: 50897
Trader Rating: (12)
When are we gonna see the new FTM
xbladr is offline   Reply With Quote
Old 07-10-2007, 11:43 PM   #711 (permalink)
Exposed's Avatar
Member Number: 37041
Trader Rating: (17)
Is the new FTM available yet?
Mopar Stage 3(147)
Exposed is offline   Reply With Quote
Old 08-15-2007, 11:37 AM   #712 (permalink)
Trader Rating: (12)
I want to know what is going on any word yet John?
04 Black(kinda) SRT-4
Installed: FM WGA, Modified ED dual Exhaust (black), BDJ's 3" CAI ceramic, Bwoody Checkvalve, X02 BFMIC, Cold Side Pipe with Raptor BOV, Techgauge, Upper DogBone, Oil Modifier, 18" HPD Bronze wheels, and Goldlines
Waiting go be Installed: PTP FTM, Wideband, Lower MM insert
Page generated in 0.24692 seconds with 12 queries
