» Tire Upgrade Garage
Old 04-24-2008, 01:31 PM   #1 (permalink)
showbo's Avatar
Member Number: 46046
Default Ptp Fpr
Hey, i have a basically stock car, with WGA, DFFMIC, and TBE, catless. My question is will this have adverse effects by installing the filter/fpr in without any SAFC or wideband?
I really was just going to buy the filter by itself, but went ahead and got the FPR just because. Its ok to just slap that right in correct?
Moments
Of
Performance
Are
Rare
showbo is offline   Reply With Quote
Old 04-24-2008, 05:01 PM   #2 (permalink)
Member Number: 9221
No when ever you add fuel or air you must get a wideband. This will allow you to run 75psi static pressure. Stock is 58psi. You will need a mapclamp at least to lean it out while upping the boost. I am assuming your talking about the FPR mod. If not then putting the stock filter/fpr is fine.
GO FAST PARTS
Stage 1
FM E1 turbo
FM WGA
Dtec FC
AGP returnline
PTP 55mm TB
PTP check valve
ED hardpipes w/ HKS BOV
Maddog STS 72%
AGP motor mounts
Zeitronix ZT2 wideband
NGK v power plugs .040
8.5 MSD wires
Needswings DP (no cat)
Quickwhips direct fit FMIC
180 thermostat
Bwoody H-brace combo
Bwoody Trans mount
AnotherNeon is offline   Reply With Quote
Old 04-24-2008, 05:57 PM   #3 (permalink)
showbo's Avatar
Yes im talking about the FPR mod.
Oscar
Old 04-24-2008, 09:55 PM   #4 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (529)
Yes you will have additional fuel to feed the motor and you will either have to up the boost to lean it out or get a map clamp/piggy back to get clean AFR's. I expect that you have a wide band or plan on getting dyno tuned to set your AFR's. Thanks.
Page generated in 0.11803 seconds with 11 queries
