» Tire Upgrade Garage
Old 05-01-2008, 12:05 PM   #1 (permalink)
showbo's Avatar
Member Number: 46046
Default PTP Filter/FPR Mod
Ok. For those of you that have this, have you ever had a problem with this? Since day one of install, my car acts like it doesn't want to start for the first 5 seconds, and when it does, it wants to die then it finally catches.
Ok, yesterday i even took it out, rechecked all my connections and reinstalled it. Same problems, the car acts like it doesn't want to start for about 5 secs. I put my stock one back in, starts 1st click. I dont know if thats suppose to just happen or what.
Is it flooding at startup or what? I took it out and have my stock one back in because i don't want to wear down my starter by keep cranking it over and just hoping it will start. Thats BS, and if its meant to do that, then i guess i didn't quite understand the purpose of the FPR or something. I have PMed John and emailed him, no reponse. Can anyone help me out here or give me some insight of why its doing that?
Oscar
Moments
Of
Performance
Are
Rare
showbo is offline   Reply With Quote
Old 05-02-2008, 01:03 AM   #2 (permalink)
Member Number: 9051
Trader Rating: (15)
Hmmmm, well.... what are your mods? It could be that the injectors are getting overloaded with the pressure... I know the stage 3 uses the same pressure but has another regulator right on the rail to compensate....
pphilps is offline   Reply With Quote
Old 05-02-2008, 01:13 PM   #3 (permalink)
showbo's Avatar
Mods:
WGA
DFFMIC
3inch TBE
just stock injectors on my 05. If that's so, how can i use this, without having hard starts?
Oscar
Old 05-03-2008, 05:25 PM   #4 (permalink)
showbo's Avatar
TTT please
Old 05-09-2008, 09:35 AM   #5 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (529)
Its an install issue. Did you get the factory o-ring out of the feed hole? How hard did you push to install the new FPR with the mod installed? Did you lube the o-rings on the new FPR when you installed it? If any of these were missed then you are going to get hard starts and long crank times./
Page generated in 0.14041 seconds with 11 queries
