» Tire Upgrade Garage
Old 04-25-2008, 07:51 PM   #1 (permalink)
NoisufnoC's Avatar
Member Number: 136
Default PTP Big Filter Kit How-To
I received my Big Filter kit from PTP today and decided that since it doesn't come with any type of directions, I write a how to for everyone.
Happily run from the mailbox as your parts you've been waiting for have finally arrived!
Open the box and inspect the contents. There should be an enormous K&N HP-3001 oil filter and a small packet of hardware. However, you will notice that there are no plugs for the coolant lines. Somewhere between the original group buy thread, which has been locked, and the new group buy thread the coolant line plugs became an option. Members such as myself that ordered the kit in the original thread will not receive the plugs. Don't worry about it though, you can get away with out them.
Raise your car, I used a lift, but a floor jack is addiquate. Make sure that you propery support the car so that you don't get squished. NoisufnoC and Philth are not responsible for loss of life or limb due to improper use of this How To.
Drain your oil and your coolant, if you skip this step you will be wearing it. Properly dispose of the waste oil and coolant. Keep in mind that cats and dogs seem to be drawn to the smell of Ethylene glycol which is extremely poisonous. Read more about it here, Ethylene glycol - Wikipedia, the free encyclopedia . Most pet emergencies occur in the owner's home. Please don't kill you pet. Jeff, my pug, doesn't approve of the senseless poising of animals
Anyway...
Locate the stock oil filter, you will notice the large cooling block with two coolant lines coming out of it. As you follow that block, you will see three bolts holding the coolant block to the engine block. These are 8MM bolts, remove them and disconnect the coolant lines.
Throw your 8MM socket back in your tool box as this is the last time you will need to use it. The nuts supplied by PTP are not the same as the OEM bolt heads.
Place the cooling block in a vise or have a strong friend hold it as you remove the center portion with a large allen wrench. We believe the marking on ours was H12
Remove the center section which will hold the cooling block to the 90 degree elbow section
Remove the coolant block and discard of it. You will never need this part again.
This is a good time to compare the stock oil filter to your new big filter. It really is a huge upgrade...
Okay, enough screwing around, get back to work.
Mock up your new o-ring plates and the PTP exclusive block and notice that the studs are incredibly long.
Pull the studs back out and reverse them. They appear to work better with the longer threads going into the engine block, and the shorter threads outward for the new nuts. However, the threads on the end of the stud are just barely too short, and the new nuts will bottom out before you get a chance to tigten them down. Drop what you're doing, find an alternative form of transportation (since your car is down now that you're in the middle of this install) and get over to Autozone for some lock washers. On a serious note, its unheard of to use non locking nuts without any time of washers. As soon as the torque from these nuts break you're going to loose tension and cause a major oil leak.
While at Autozone listen to the cashier pitch you the Autozone Rewards Program. For every purchase of $20 or more, you get a point. After 5 points you get a $20 store credit. Its too bad that you already purchased your oil and coolant for this install, or you would have received one point for the purchase. Only 4 more purchases to go before you get $20 off. And no, you dont get more than one point for a purchase. So if you spend $100 one day, you only get one point...not 5.
Place the lock washers on the studs and secure the 10MM nuts down. Make a mental note that these are no longer OEM sized nuts.
Take a step back and admire your work, or in my case, take a picture of your friend doing the work for you.
If you did not recieve the coolant block off's, remove one of your coolant lines and loop the other to where the first was connected. Remove the intermediate shaft from the transmission if you find it to be in the way. Also, take care to ensure that the looped coolant line will not rub the intermediate shaft.
Lube the o ring on the new filter and screw it into place.
Don't forget to replenish your oil and coolant. NoisufnoC and Philth are not responsible for engine damage due to improper lubrication.
I dumped in 5 quarts of oil and didn't notice any low oil condition. I plan to periodically check the level and add more as necessary.
Old 04-25-2008, 07:57 PM   #2 (permalink)
bpsrt4's Avatar
Member Number: 40796
Trader Rating: (24)
<--Has autozone rewards card
oh and
bpsrt4 is offline   Reply With Quote
Old 04-25-2008, 10:14 PM   #3 (permalink)
geekmonster's Avatar
Member Number: 25499
nice write up, lots of useful pics.
geekmonster is offline   Reply With Quote
Old 04-25-2008, 10:59 PM   #4 (permalink)
srt4moster's Avatar
Member Number: 24528
Trader Rating: (13)
umm. you installed the studs wrong, the shorter of the two threads goes into the pan leaving the longer of the two thread ends out. as they are not intended for the longer ends to be threaded into the pan.
srt4moster is offline   Reply With Quote
Old 04-25-2008, 11:47 PM   #5 (permalink)
Member Number: 40412
Thanks for the write up and pics! I will definatley be ordering one of these soon!
Friends may come and go, but enemies accumulate.
2004 eBlue SRT-4
PTP S3 SST 50lb Wheel (Clipped,3" Bell,Filled Surge,Ported Discharge),Race Ported S3 Exh Manifold,Race Ported Int Manfold (Port matched to PTP 60mm TB),S3 3.5" O2 Housing,DF FMIC,Hot & Cold Side Pipes,Discharge Pipe,675 Injectors,Inv Coilovers,S3 Clutch,FP Rewire.
MISC DCR Oil Mod,AGP S3 WG,Walbro 255,Coolingmist S3 HOM Trunk Mount WI Kit,HKS SSQV,MaxxFab 3" Catless DP & 3" Exh.
SRT4_Ryan is offline   Reply With Quote
Old 04-25-2008, 11:48 PM   #6 (permalink)
Philth's Avatar
Member Number: 46647
Trader Rating: (23)
this is NoisufnoC posting from the bar on Philth's iPhone.
I was provided with no directions. I don't see how putting the short threaded end into the block would have been better. The kit should have come with the all the required hardware to get the job done. Any one who has bought this kit can paypal me $.50 and I'll mail them three lock washers. My paypal is noisufnoc at gmail dot com
11.88 @ 116
Old 04-25-2008, 11:52 PM   #7 (permalink)
Philth's Avatar
Trader Rating: (23)
word.
Its a good kit with the spacer but make sure you pick up some lock washers.
Old 04-26-2008, 12:02 AM   #8 (permalink)
Philth's Avatar
Trader Rating: (23)
Hey man, the shorter threaded side didn't allow the studs to grave enough threads in the pan IMO. However no matter how you install the studs, the nuts are on the dangerous side of bottoming out on the shank of the studs. That being said, its common practice that nuts of this design are usually installed with a washer of some sort. The washer also acts a spacer to ensure the nuts actually clamp down and not bottom out.
Old 04-26-2008, 02:18 AM   #9 (permalink)
relaxor's Avatar
Member Number: 57521
Just what it says in the pic.
relaxor is offline   Reply With Quote
Old 04-26-2008, 02:36 AM   #10 (permalink)
relaxor's Avatar
Oops sorry, Dumb me didnt see the last steps. sorry.
Old 04-26-2008, 09:45 AM   #11 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (529)
We have the how to sitting here on the PC. I will get it out to you guys. The block off kit is not included because of the difficulty in getting the parts out of the block. Its going to be smarter to loop the hose back into each other. We will have a kit that blocks off the coolant supply at there locations vs looping the hose. I tryed to pull the coolant hose assembly out of 2 different cars, you have to pull the axle out of the passenger side in order to make it happen. Looping them was the smarter way to go.
The studs are long enough to hold the parts down. There are 5 threads left over after you get the studs into the pan and everthing tightend down. I will get the how to up here in a while.
Old 04-26-2008, 09:46 AM   #12 (permalink)
There not needed, there is lots of room for the nuts to bolt down.
Old 04-26-2008, 09:50 AM   #13 (permalink)
He has one installed on his car, it works with no problems, trust me. The studs are a little on the long side but I wanted them that way to make sure people had enough room for the install. Looks like they are to long. If you seat the short end all the way tight into the pan, there is 5mm worth of threads left when you are full tight. I have installed 4 of these kits now, all of them are leak free and have no problems. If reversing the threads works better for you, then so be it. I will make a note of that in the kit if people want to do it that way. Hell I will even put the 3 lock washers in all the current kits if need be.
Old 04-26-2008, 10:57 AM   #14 (permalink)
Philth's Avatar
Trader Rating: (23)
Whether the nuts bottomed out on the studs or not, there still should be lock washers there to provide the surface tension needed for a proper install IMO.
Old 04-26-2008, 01:57 PM   #15 (permalink)
That why we got the washered nuts. They should have enough surface area to hold them down tight. But, advice taken.... washers will be in ever kit.
