» Tire Upgrade Garage
Old 04-10-2008, 03:25 AM   #1 (permalink)
Nelson's Avatar
Member Number: 52787
Default Possibilities for manifold and SSTv1
Hey PTP, I'm looking at buying this http://www.srtforums.com/forums/f27/...o2-wga-435194/ And I wanted to know how much it would cost to turn it into an external wg, if it was possible. And how much it's going to run to turn a V.1 into a V.3 if that's possible?
Proud Owner Of The S.S. Neon
Stage 2 w/o, Maxxfab 3in o2 and 3in SEE no cat/no res, AGP Race BFMIC, AGP Hard Pipe set, HKS bov, plugs and wires, AEM CAI, BWoody MM, CC, Check Valve
Awaiting Install: SST V.3, External Gated Intimidator ex manifold, Safc Neo, 2 guage pillar, Scan Guage, 30/30 boost gauge, AEM wideband o2
Nelson is online now   Reply With Quote
Old 04-11-2008, 05:30 PM   #2 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (529)
$299 to go from V1 to a V3
External gate is $199 plus shipping. Add $125 for ceramic after we are done with the work.
Thats a great buy if you get it all.
Old 04-12-2008, 07:17 AM   #3 (permalink)
Nelson's Avatar
Ohhh baby. Bring it I locked up the SST and the manifold. There were problems with his current turbo being shipped out, so it's going to be a week or two before it's sent, but I might just have the manifold sent to you. I'm just trying to figure out who I'm going to have install the neo and wideband. Not sure if I should attempt to install the sst and manifold myself. I've never done something like that before.
Old 04-14-2008, 10:23 PM   #4 (permalink)
ibnzmonkey's Avatar
Member Number: 36611
Trader Rating: (10)
how much is it to go from a V2 to a V3?
Quote: Originally Posted by uberingram View Post
All that logic and common sense doesn't outweigh the fact that dual sounds way cooler than single.
I love SRTForums.
ibnzmonkey is offline   Reply With Quote
Old 04-15-2008, 02:12 PM   #5 (permalink)
mole''s Avatar
Member Number: 17477
Trader Rating: (156)
im pretty sure its the same price.
PTperformance PTP's Cali CREW Mole'
100% BONE STOCK.
Old 04-16-2008, 02:25 AM   #6 (permalink)
Nelson's Avatar
Do you need a boost controller for an external wg? Or is boost adjusted on the wg? I did research on the external, but it's few and far between with informative articles because a lot of talk goes on about them.
Old 04-16-2008, 05:50 AM   #7 (permalink)
sneaky brian's Avatar
Member Number: 21602
Trader Rating: (25)
i depends on the spring in the wg. its not adjustable in order to change boost you need to change the spring in the wg. so itd be alot easier with a boost controller
PTP SST and PNP exhaust manifold, PTP 3" O2 housing, CTI 3" SEE, PTP FTM and stage 2 injectors, red star fuel return line, perrin fuel rail, and 255 fuel pump w/ re-wire mod, AGP WGA, w/ AVC-R EBC @21lbs, DCR top end mod, Stage 1 PCM, QuickWhips BFMIC, injen SRI, Bwoody H-brace and traction bars.
sneaky brian is offline   Reply With Quote
Old 04-16-2008, 08:03 AM   #8 (permalink)
Thanks guys, all the advice given so far is correct.
Page generated in 0.14214 seconds with 11 queries
