Hey PTP, I'm looking at buying this http://www.srtforums.com/forums/f27/...o2-wga-435194/ And I wanted to know how much it would cost to turn it into an external wg, if it was possible. And how much it's going to run to turn a V.1 into a V.3 if that's possible?
Proud Owner Of The S.S. Neon
Stage 2 w/o, Maxxfab 3in o2 and 3in SEE no cat/no res, AGP Race BFMIC, AGP Hard Pipe set, HKS bov, plugs and wires, AEM CAI, BWoody MM, CC, Check Valve
$299 to go from V1 to a V3
External gate is $199 plus shipping. Add $125 for ceramic after we are done with the work.
Ohhh baby. Bring it I locked up the SST and the manifold. There were problems with his current turbo being shipped out, so it's going to be a week or two before it's sent, but I might just have the manifold sent to you. I'm just trying to figure out who I'm going to have install the neo and wideband. Not sure if I should attempt to install the sst and manifold myself. I've never done something like that before.
Do you need a boost controller for an external wg? Or is boost adjusted on the wg? I did research on the external, but it's few and far between with informative articles because a lot of talk goes on about them.
i depends on the spring in the wg. its not adjustable in order to change boost you need to change the spring in the wg. so itd be alot easier with a boost controller
