Old 09-17-2007, 08:52 PM   #91 (permalink)
Orlandoech's Avatar
Member Number: 36006
Trader Rating: (104)
OMG! Awesome info... I was looking for some info about CVs and CCs and this was perfect!
Orlandoech is offline   Reply With Quote
Old 09-25-2007, 10:46 PM   #92 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (533)
Well there it is and if you don't have one by now you will need one when you hit the track.
Old 12-15-2007, 10:24 PM   #93 (permalink)
Member Number: 13606
I was told that when putting a breather on the drivers side sends out a CEL on stock PCM's. Is this true, do you need a S1 or higher to avoid. Otherwise I will be doing the breather on the driver side, and the check valve and CC on the TB side
Thanks
Injen 3" CAI, Weapon R Pressure Pipe W/Turbo XS RFL BOV, hard pipes, Needswing DP with powerplate, 60mm true TB with spacer, AGP Wastegate, Plugs and Wires, EBC, Fuel return line, DC Sports Front Strut Tower Bar, 27mm front sway bar, 22mm rear sway, barWerks 3 point rear strut tower bar, Motor mount inserts.
Soon to be FMIC and Stage ??
jackbandit is offline   Reply With Quote
Old 12-17-2007, 11:02 PM   #94 (permalink)
Member Number: 17360
Thanks
I was told that if you don't read the entire thread and aren't able to understand that you shouldn't use a breather, that you should be banned from the site permanently.
After that, you should refill your turn signal fluid.
Seriously, no breather, use check valve and catch cans(plural, meaning 2) where needed.
srtdrew is offline   Reply With Quote
Old 12-19-2007, 04:05 AM   #95 (permalink)
Member Number: 43665
im running a catch can off the pcv valve to my intake mani. im buying a checkvalve today but i wanted to know does the check valve get installed between the pcv and the catch can or between th catch can and the intake manifold
05 BLACK NEON SRT-4 - Totalled
08 SILVER CALIBER SRT-4 - Still Breaking It In
AASLT_SRT4 is offline   Reply With Quote
Old 12-19-2007, 08:58 AM   #96 (permalink)
I believe between the PCV and the CC is where I put mine, but it's been too many beers since then. Read around here, Darrell...breather or no breather? settle this for us once and for all=), for more detailed info.
Old 12-19-2007, 03:00 PM   #97 (permalink)
Member Number: 38039
Put the check valve between the intake manifold and the catch can, otherwise you will pressurize the catch can when you're boosting. You want to contain the boost at the manifold, makes sense, right? The best way to stop blow-by is to install a windage tray/crank scraper assembly. This keeps the oil coming off the crankshaft down in the oil pan and no longer getting whipped into an aerated froth that is sucked out of the valve cover when the PCV valve opens under engine vacuum (closed throttle). I have the Ishihara- Johnson version with the balance shaft assy removed. I now get no oil in my catch can and no oil in the cold side pressure pipe. Darrel Cox Racing makes this as well and I'm sure it works great too. The check valve is a must as the PCV valve will not hold 19 psi boost (like I run) and you will have a boost leak and will pressurize the engine. Highly recommended by Dr Mike
MDRACER is offline   Reply With Quote
Page generated in 0.29868 seconds with 11 queries
