Old 03-31-2008, 09:51 AM   #1 (permalink)
Member Number: 44310
Default help!!! SST v2 turbo question
guys now that it is getting warmer i have turned my boost on my sst turbo back up to around 19lbs. after i did this i took it for a run down the highway and when the turbo hits 19lbs there is like a 2-3 second hesitation in boost then it kicks back in. today i turned down the boost a bit to see if it still does but i wont have an update til this afternoon. any suggestions?
bluesrt4man is offline   Reply With Quote
Old 03-31-2008, 09:29 PM   #2 (permalink)
Kason23's Avatar
Member Number: 34502
Trader Rating: (15)
I had the same problem and it was a exhaust leak at the 02 housing. but could prob be a boost leak check the hotside pipe thats connected to the turbo!
AGP 44LB kit...382whp/416wtq
on 22psi and pump!
Old 04-01-2008, 07:32 AM   #3 (permalink)
i turned my boost down to around 17-18 lbs and it seems like ti went away. could this be a possible fuel cut?
Old 04-01-2008, 08:06 AM   #4 (permalink)
SRToc Member
vschaos's Avatar
Member Number: 3626
Trader Rating: (15)
could be. what boost where you running before the summer? Do you have an a/f guage?
Shop hours are 10am to 7pm Mon-Fri
Taking calls on Tuesdays and Thursdays
Old 04-01-2008, 08:17 AM   #5 (permalink)
i was running 19 lbs this past summer. i turned it down to 15 for the winter and now im back to 17-18 lbs currently with no hesitation. but when i put it back up to 18 - 19 lbs it hesitates at full boost for approx. 3 seconds then kicks in. only leak i have with a boost leak tester is my tb. it leaks at the top of the tb where there is a indented circle.
Old 04-01-2008, 11:18 AM   #6 (permalink)
SRToc Member
vschaos's Avatar
Member Number: 3626
Trader Rating: (15)
could maybe be some bad gas?
Old 04-03-2008, 05:46 PM   #7 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (552)
Plug gap?
Wires?
Bad gas?
Knock counts?
Lots that it could be, get a complet list of mods including fuel and we can go from there.
Old 04-07-2008, 04:02 PM   #8 (permalink)
Member Number: 46363
Trader Rating: (38)
I have a similar issue at 18psi. If I am crusing and down shift and hit WOT, I get no knock, afr's seem to stay steady around 14.7 -15.0 but boost hits 19psi and stay there for a few seconds then the afr's pull down to 11.5-12 and the car moves like a bat outta hell. Its almost as if the PCM is taking awhile to recognize WOT and adjust timing.
Bryan Tracy
04 Silver SRT4 - Parted and Sold
05 Aero Blue SRT-6 - New Toy
ImportLabSRT4 is offline   Reply With Quote
Old 04-07-2008, 07:54 PM   #9 (permalink)
CIVICEATER's Avatar
Member Number: 16703
Trader Rating: (10)
Yea whats your setup, including fuel and if a piggyback is being used.
2003 Solar Yellow SRT-4
E1 Turbo
Kinetic WGA
Devils Own W/I with Progressive Controller
MPx 3" Exhaust with Cat
MPx Intercooler
AGP CAI
Stage 3 ECU
Walbro 255lph Fuel Pump
Stage 2 Injectors
Perrin Fuel Rail
AEM Wideband
Aeroforce Scan Guage
Greddy Type RS BOV
Mopar STS
Exhaust Depot Hardpipes
DCR Oil Mod
DCR 5 Layer Headgasket
299hp - 324ft-lbs tq
13.1 - 110mph<----- Traction Ownz Me
CIVICEATER is offline   Reply With Quote
Old 04-08-2008, 01:30 PM   #10 (permalink)
mole''s Avatar
Member Number: 17477
Trader Rating: (173)
any updates?
PTperformance PTP's Cali CREW Mole'
co-founder of www.casrtoc.com
100% BONE STOCK.
Old 04-10-2008, 06:45 AM   #11 (permalink)
i have an agp wastegate non pcm controlled, mopar rice plate, stage 1, needswings dp v5, k&n drop in, no fuel mods, and obviously sst turbo. i recently sold my a/f gauge but when i had the setup last year with the gauge and running 18-19 lbs the a/f #'s were good.
Old 04-10-2008, 08:51 AM   #12 (permalink)
kbosch's Avatar
Member Number: 56616
my car is doing the same thing...i replace the plugs...wires and coil pack and it still does it....but if i turn down the boost it doesent due it as bad....some people claim its the computer cause we are boosting to much but my one buddy has a stage one and it dosent due it to him and hes boosting 20 pounds....
Hahn 20g boosting 23lbs, Big Fmic, Open turbo, Turbo XS BOV, Boost controller, DC front and rear strut bars, Prothane inserts, stage 1 computer, short throw shifter, Tein springs, Aem Wideband, rc 650cc injectors, Safc Neo, Walbaro 255 fuel pump.
I dyno'd 293 on pump gas at 21lbs on a dyno dynamics...I call bullshit?
kbosch is offline   Reply With Quote
Old 04-10-2008, 09:07 AM   #13 (permalink)
i have a buddy that was boosting around 23 pounds and it wasnt doing it. nad im not running my boost off of my pcm so it isnt being controlled at all.
Old 04-11-2008, 05:20 PM   #14 (permalink)
Updates?
Old 04-12-2008, 04:56 PM   #15 (permalink)
kbosch's Avatar
i heard some people talk about getting bad gas....and the gas has some water in it and it makes it hesitate or seem like its missing.....my brother had it happen to his ford f-250 where there was water in the fuel and it got so bad the car wouldnt start....so they had to drop the tank make sure all the gas was out and then they had to put in some new injectors....then it fixed the problem....but it could be really anything like the fuel filter or something...if you figure yours out before i do let me know and ill let you know too...keep me posted
Page generated in 0.18262 seconds with 11 queries
