Old 02-27-2007, 11:57 PM   #181 (permalink)
mole''s Avatar
Member Number: 17477
Trader Rating: (164)
Quote: Originally Posted by srt4geezer
So, that's with the lighter flywheel?
the last 4 pics show the Flywheel. you can also see the ARP bolts in one of them.
PTperformance PTP's Cali CREW Mole'
100% BONE STOCK.
Old 03-17-2007, 07:27 AM   #182 (permalink)
scottw03's Avatar
Member Number: 23435
Trader Rating: (31)
Hey John,
The S3 clutch that I ordered, we will be looking at putting that in real soon since I think my stocker is finally slipping so I want to get this in there in the next 2 weeks. Just wanted to ask, I didn't get the light weight fly wheel, just the clutch and some other part in the package, do I need anything else to do the install? I am assuming I am going to need to refill my tranny fluid and use friction modifier as well right? I will be back in the states later this week so I guess I will have to try to find some, any suggestion where exactly? Otherwise I will check with the dealership.
scottw03 is offline   Reply With Quote
Old 03-17-2007, 09:07 AM   #183 (permalink)
nvr2loud's Avatar
Member Number: 1690
Yeah, you shouldn't need anything else for the install other than what the clutch came with.(Modular setup with clutch & steel flywheel, Throw-out bearing) Just need time, tools to pull tranny and pick up some new tranny fluid. Also, get some locktite for the driveplate and clutch bolts. If the Mopar ATF+4 fluid and modifier is working good for you, then you can stick with it. Myself and others have switched to different brands/types, but these trannies seem to have there own fluid that they like. Some peoples' trannies like one type of fluid and some don't. Just need to find a fluid that your tranny likes and stick with it.
'99 DOHC Neon~Built & Boosted!
'04 SRT-4~modified
nvr2loud is offline   Reply With Quote
Old 03-17-2007, 09:24 AM   #184 (permalink)
GLHtoo's Avatar
Member Number: 23030
Trader Rating: (24)
I replace my fluid with redline synomesh every 6-7K miles.
87' Cherokee 4.0L auto 280K miles. 3'' lift 31's
02' TJ wrangler Apex edition 69K miles. 4.0L 5-speed. 33'' tires 4'' lift, custom front bumper, sway bar disconnects.
03' caravan !!!!
04' SRT4 stock again... 28K miles.
GLHtoo is offline   Reply With Quote
Old 03-17-2007, 11:29 AM   #185 (permalink)
scottw03's Avatar
Trader Rating: (31)
Well, we got the MOPAR ATF +4 over here but no friction modifier. Can anyone give me brands or what I should be looking for when I go home (connecticut) on the 22 - 27 March. I will pick it up while I am in the states and bring it back with me. How much do we use of it? Just need to know if I need to bring back more than one bottle or not.
Old 03-17-2007, 02:03 PM   #186 (permalink)
nvr2loud's Avatar
Member Number: 1690
I believe it is just 4oz. of the Friction Modifier that is needed with the Mopar ATF+4. Mopar has the friction modifier.
I would also recommend Amsoil Slip-Lock Differential Additive (ADA)
and Amsoil Synthetic Universal Automatic Transmission Fluid (ATF)
if you can get Amsoil products.
The Amsoil Slip-Lock is a friction modifier.
Either route you go, just use the 4oz bottle with the 2-2.3quarts of ATF tranny fluid.
Old 03-17-2007, 02:49 PM   #187 (permalink)
scottw03's Avatar
Trader Rating: (31)
Cool, I will look for those while I am in the states.
Old 03-18-2007, 11:42 PM   #188 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (532)
Sounds good, and I hope that everthing works out smooth when you get the parts.
Old 03-20-2007, 11:06 AM   #189 (permalink)
vegasDSM's Avatar
Member Number: 726
john- i sent you a guy who PM'd me about the stage 3 clutch yesterday...
free bump
F this forum and it's bullshit ads......ekool has jumped the shark
www.myspace.com/vegasdsmr<--vids....................
http://www.WebPeople.us
http://www.WebPeopleVideos.com
vegasDSM is offline   Reply With Quote
Old 03-20-2007, 12:10 PM   #190 (permalink)
Thank you. With the GB now going I suspect that there will be a huge request on these.
Old 03-20-2007, 08:31 PM   #191 (permalink)
mole''s Avatar
i hope you have the second batch on order already.
Old 03-26-2007, 02:42 AM   #192 (permalink)
Yes they are on the way. Looks like 11 units have already sold, they will be shipping this coming week and we have enough to go around so no worries about that.
Old 04-11-2007, 04:57 PM   #193 (permalink)
towsrt4's Avatar
Member Number: 37591
hey john i'm at 680 miles right now, i was planning on waiting until 1000 to start doing anything but i'm' seeing a lot of ppl here starting to do 3rd gear pulls so i'm wondering if i should start. Also, have any of you guys had that vibration and if so when did it go away? My vibration has gotten better but it is still present. Thanks guys. can't wait to do some pulls
towsrt4 is offline   Reply With Quote
Old 04-11-2007, 05:23 PM   #194 (permalink)
mole''s Avatar
i had a LITTLE BIT for the first maybe 300 miles. but it was slight. nothing like the CM clutches.
Old 04-13-2007, 03:52 AM   #195 (permalink)
e_freeman85's Avatar
Member Number: 13554
Trader Rating: (13)
before the advance auto TOB ate my pressure plate i was able to drive a little with the stage 3 clutch and it was great no vibration what so ever it was great felt just like stock
e_freeman85 is offline   Reply With Quote
