WTF is my car doing? - Dodge SRT Forum
post #1 of 24 (permalink) Old 02-26-2013, 05:56 PM Thread Starter
RTdodgeneon's Avatar
Quoted: 3 Post(s)
Garage
Angry WTF is my car doing?
its been doing this since i got it running. i have swapped 2 coils, 4 wire sets, changed the spark plug gap from .35 to .38 to. 30 and still no changes. im running stock coil with granatelli wires now. with stock copper champions and has the hiccup at idle the most plug while having it held at a rpm under no load just like this video
just like that guys car but maybe a little more than him.
As for my mods i have a stage 2 kit no toys, 15lbs, stock coil with ganatelli wires, Mpx bfmic, 3 in 02 and dp, ported intake ports, hard pipes, bwoody CC with mpx cv, PCM boost, pretty much a stock stage 2 kit with simple bolt ons. so maybe its an injector? or teh plugs? was thinking of NGK iridiums, but wanted to get some professional suggestions before i throw money in it
RTdodgeneon is offline
post #2 of 24 (permalink) Old 02-26-2013, 05:58 PM
CarbonSRT's Avatar
Quoted: 0 Post(s)
Trouble codes?
I just wanna go fast!
CarbonSRT is offline
post #3 of 24 (permalink) Old 02-26-2013, 06:20 PM Thread Starter
Quoted: 3 Post(s)
Garage
also the vacum at idle is 20 and tried to boost leak test with my new mpx one with the key on and only leaks from the holes on the MOPAR BOV. what am i doing wrong here?
post #4 of 24 (permalink) Old 02-26-2013, 06:23 PM Thread Starter
Quoted: 3 Post(s)
Garage
po522 and po663
post #5 of 24 (permalink) Old 02-26-2013, 06:26 PM Thread Starter
Quoted: 3 Post(s)
Garage
one is for the key which is no changes and the other is for the stock oil sending unit cause i have it off due to my Mopar oil psi gauge
post #6 of 24 (permalink) Old 02-26-2013, 07:27 PM
ACRMAG's Avatar
Quoted: 0 Post(s)
So it ran fine till you cleaned your injectors. What did you do to clean them or who did you send the to?
Sold: 2005 SRT-4 ACR Stone White
Dismantled: 2000 Neon: Project SRT-4 full swap
Current 2003 SRT-4
ACRMAG is offline
post #7 of 24 (permalink) Old 02-26-2013, 07:35 PM
NeOnDrAgOn's Avatar
Quoted: 0 Post(s)
My car kinda has that little pop on the idle (hear in the exhaust and inside), but i am pretty sure that is normal. The mid range breaking up still sounds like ign? You sure all the parts swapped are ok and in working order?
05 Black,Full 3inch exhaust, BWS3 47#,Ported and polished, Duster360's injectors and tune
Realtune LCA's Bushing= Best mod since the DSP.
Originally Posted by never2muchboost View Post
hadoukens will be shat
NeOnDrAgOn is offline
post #8 of 24 (permalink) Old 02-26-2013, 09:27 PM
CarbonSRT's Avatar
Quoted: 0 Post(s)
Does it drive ok?
Sent from
post #9 of 24 (permalink) Old 02-26-2013, 09:50 PM Thread Starter
Quoted: 3 Post(s)
Garage
it drives okay, just idle and no load rpm it does it and is VERY annoying to me. i looked on my scan gauge at the throttle % and voltage stayed the same so maybe a cam or crank sensor?
but ive noticed a little more lately is sometimes when i rev it up or givr iit throttle it bogs down or poops feels like
post #10 of 24 (permalink) Old 02-26-2013, 10:19 PM
04PAcruz'n's Avatar
Quoted: 1 Post(s)
I would run NGK 4306s NOT iridiums @ .35 gap. when @ idle try to wiggle the TPS and IAC wires to see if there is any change in idle sound.
Mods:
FM E3, Stage 3 w/o toys, JMB Ported IM+PTP 55mm TB, PTP charge pipe, Thermal R&D exhaust w/cat, Mopar CAI, Spearco DF-IC, Samco IC hoses.
Mopar Stage 1 suspension (springs+sways), rear tension struts, Mopar front STB, Pwerks rear STB, mm inserts (street)
Mopar STS, Mopar BOV, JMB catchcan, Pwerks grounding kit
04PAcruz'n is offline
post #11 of 24 (permalink) Old 02-26-2013, 10:49 PM
Quoted: 345 Post(s)
Maybe imbalanced injectors?
2005 SRT-4, BW Stage 3, Tuning...
2002 Camaro SS M6, Turbo kit in, working on things!
2003 SRT-4 Sold!
enginjoe is offline
post #12 of 24 (permalink) Old 02-26-2013, 10:49 PM Thread Starter
Quoted: 3 Post(s)
Garage
so ask for 4306 or is that a part #?
post #13 of 24 (permalink) Old 02-26-2013, 10:54 PM
SRT of the Month
underSRTarmor's Avatar
Quoted: 4 Post(s)
Re: WTF is my car doing?
Tell them u want 4 ngk 4306 plugs
Then when they ask for what car u say I asked for ngk 4306 lol
TUNED By MindMelt101
MyBuild Thread
10.99 @132.23 1.70 60ft 27 psi
Need Fuel setup ideas click here
Props go out to:
Mindmelt101, Tuner Geeks, Act, Wikyd Performance, Pwerks
underSRTarmor is offline
post #14 of 24 (permalink) Old 02-26-2013, 11:00 PM Thread Starter
Quoted: 3 Post(s)
Garage
lol ill do that and see how it goes
post #15 of 24 (permalink) Old 02-27-2013, 07:46 AM
Quoted: 345 Post(s)
...and then the girl behind the counter will say, I really need to get the car information...
2003 SRT-4 Sold!
enginjoe is offline
User Tag List
Linear Mode Linear Mode
