#91 (permalink) |
SRT of the Month ![]() Join Date: Aug 2005
Member Number: 32888
Well it just cuts boost. I haven't taken the car out yet. Ill test that out it has to work the boost solenoid gets its grd from the gauge. The grnd is removed on lean or rich condition.
| Sponsored Links | |||
Advertisement | |||
#93 (permalink) |
Fresh Meat Moderator
![]() Join Date: Dec 2009
Member Number: 76568
I believe that it works. I would just like to see it the gauge do its job lol
![]() Diablo CMR tuner ~Dan~ 2004 Black Neon SRT4: E85 stock turbo SOLD ![]() 310HP 436TQ 2004 Eblue Neon SRT4: E85 5558 ![]() XXXHP XXXTQ |
#94 (permalink) |
Hard to build boost in the garage. Hahaha lol! Autoguide.com App
#97 (permalink) |
You're making it really difficult to resist buying this gauge...lol
i like it... to me it was a very good investment..... i should of done a how to... but is exactly the same as an aem wb, except 1 it has a usb plug coming out 2 you hook up to a boost/vac source. 3 the failsafe wire to the boost solenoid 4 rpm wire
#98 (permalink) |
![]() Join Date: Feb 2012
Member Number: 88244
but is exactly the same as an aem wb, except 1 it has a usb plug coming out 2 you hook up to a boost/vac source. 3 the failsafe wire to the boost solenoid 4 rpm wire Where exactly do you wire the rpm wire to? |
#99 (permalink) |
injector #4 they have a green wire and a blue, i tested the blue, blue tested good. so i just used it.... = ) i have some injector clips, i dont like them so im going to be cutting the stock clips off and soldiering the new clips on..
#100 (permalink) |
either my injector clips suck or somethings up... rpms are working really well except between 3500 and 4000 rpm, it jumps around alil...hmm connection is soldiered, ill get rid of my clips and solder new wires on..... see if that helps.
AEM Catalog & Software Downloads d load aemdata and ill send you the log..... back to the drawing board... i did get a tach driver ill try that too.. we will get it perfect.... its really cold in the mid 50s here colder than when i went to the track. so you see my afr is around 12.5, when the orange line goes up the alarm triggered and u see the boost and afr slow fall down..... u also see the rpm jump up 2-3 times around 3500-4000
#103 (permalink) |
![]() Join Date: Jul 2009
Member Number: 73914
Hey Brandon give me a heads up as to when you will be in Houston again. There are alot of things you have done to your car that I'd like to do to mine.
I'm just not as good as you at putting things together
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
