#1 (permalink) |
Member Number: 91147
I recently found a dsp in my area for sale but i read that you "should" have a wideband to monitor a/f ratios. What do i need to do to my car to run a wideband as im pretty much stock. Im buying this dsp regardless as its a great deal just not hooking it up until i figure out how to support it
| Sponsored Links | |||
Advertisement | |||
#4 (permalink) |
![]() Join Date: Mar 2012
Member Number: 88421
Yep its pretty easy, everything you need comes in the kit except for the gauge pod. I welded the bung in myself with a mig welder, thats the only part that might hang you up if you don't have access to one. Any exhaust shop should be able to do it cheap though.
#6 (permalink) |
![]() Join Date: Feb 2011
Member Number: 83208
Yes the ring (o2 bung) is threaded. It will come with the wideband. I would take it to a shop if ur not handy with welding. Or you can just buy a better downpipe that has one already welded in it.
Autoguide.com App
Ratman Racing
#7 (permalink) |
Fresh Meat Moderator
![]() Join Date: Dec 2009
Member Number: 76568
What ever down pipe you install it on, make sure it install it BEFORE the cat if its catted.
![]() Diablo CMR tuner ~Dan~ 2004 Black Neon SRT4: E85 stock turbo SOLD ![]() 310HP 436TQ 2004 Eblue Neon SRT4: E85 5558 ![]() XXXHP XXXTQ |
#8 (permalink) |
ok so i bought the dsp and ordered a aem wideband, now im thinking exhaust...i have a stock exhaust so i was wondering if i should upgrade it to a 3" dp with the 02 bung already in it with a cut out the will connect to my stock exhaust, good or bad idea? or should i get a 3" o2 housing AND a 3inch exhaust? what are your guy's recommendations?
#9 (permalink) |
I have a 3" in downpipe without a cat and LOVE it. It's loud as hell when u want it to be and when it's closed it sounds just a little bit better then stock. 3" o2 housing is up to you. A lot of people say the gains aren't worth the money. I put one on just because I figured I already got the downpipe off and its right there.
Autoguide.com App
Ratman Racing
#10 (permalink) |
If you want to keep the stock exhaust then just get a 3 inch downpipe catless with a cutout. Will perform near to a full 3 inch exhaust.
O2 housing on the stock turbo isnt really needed. It will help slightly but its not worth the PITA it is to install.
#11 (permalink) |
so mainly get the 3in dp with cut out that reverts back to 2.25in the stock exhaust is right? if i get a 3in dp tho how does it attach to the stock o2 housing? isnt it a different size clamp/bolt connector?
newbie at modding cars here, thanks for sticking in there!! |
#13 (permalink) |
![]() Join Date: Jan 2004
Member Number: 6784
This: NeedsWings Neon SRT4 3" Cat-less Cutout Downpipe v.5
or this: NeedsWings 3" Cutout Neon SRT4 DownPipe w/Cat v.6 and you're golden.
R.I.P. Gregory Brewer 01/31/51-07/01/12
![]() Loud pipes and other myths. Your e-penis is a mighty e-beast and feared by e-tribes everywhere.
Quote: Originally Posted by ILLJIM69
and for the record............i fail!!!!!!!!!!
jim |
#14 (permalink) |
okay so i got the wideband in my stock dp for now and got the dsp 93 tune loaded. im slightly overboosting, i turned the boost down by 5%1-2k rpm and 10% for the rest of the rpms ranges. im supposed to disconnect the battery everytime i even slightly modify the tune right? not just the main ones correct?
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
