Old 03-15-2008, 11:50 PM   #1 (permalink)
srt-sparkle's Avatar
Member Number: 8546
Default whats stage 3 supposed to boost at?
Does anyone know where should my boost be at through each gear on setting 2 on the dial a boost???????? im trying to determine if i have a boost leak its 33 degrees out here btw
srt-sparkle is offline   Reply With Quote
Old 03-15-2008, 11:59 PM   #2 (permalink)
svtsrt's Avatar
Member Number: 41942
Trader Rating: (15)
no toys, stg2 pcm and I'm gettin 18.
05 SRT-4
-Mopar stg3, Mopar BOV, sts, exhaust, CTI hotside pipe, JBM cc, Maxxfab dp w/ cat, AEM uego wideband, Aeroforce gauge-
svtsrt is offline   Reply With Quote
Old 03-16-2008, 12:02 AM   #3 (permalink)
Member Number: 8546
did you leave the wastegate as is when you got the kit and just bolt it up?and leave it? I get 16 so boostleak maybe?
Old 03-16-2008, 12:04 AM   #4 (permalink)
2Spools's Avatar
Member Number: 18960
Trader Rating: (17)
25psi here. Uhmm but I do have an EVC. A stocker should run 22 falling to 18 at redline.
Mopar Stage3 turbo 11.58@124 JANNETTY RACING SCT TUNED
www.turboaddictionparts.com
2Spools is offline   Reply With Quote
Old 03-16-2008, 12:09 AM   #5 (permalink)
svtsrt's Avatar
Trader Rating: (15)
I changed the setting when I put it on. I'm thinking I have a boost leak too.
Old 03-16-2008, 12:11 AM   #6 (permalink)
solis1479's Avatar
Member Number: 11963
anything under 27psi.
im @ 25psi
not stage 3 anymore...
BUY MY STAGE 3 KIT
http://www.srtforums.com/forums/f27/...toybox-432202/
solis1479 is offline   Reply With Quote
Old 03-16-2008, 12:14 AM   #7 (permalink)
DDogsrt461BLK 3.0's Avatar
Member Number: 32500
This is a video, that shows, what stg3 wtoys, mpx - Video
DDogsrt461BLK 3.0 is offline   Reply With Quote
Old 03-16-2008, 03:16 AM   #8 (permalink)
Member Number: 8546
i wonder where am i supposed to be at though and what to check if im not because i just ziptied all my lines so its a little better and also should i adjust my stage 3 wastegate? I never touched it i just slapped the manifold and turbo on altogether.
Old 03-16-2008, 07:34 AM   #9 (permalink)
MoxhairR/T's Avatar
Member Number: 17662
23spike 18hold
S3 WGA. S3 ECU. ECU Controlled Boost
MoxhairR/T is offline   Reply With Quote
Old 03-16-2008, 11:05 AM   #10 (permalink)
Member Number: 8546
So what should i do should i readjust the wastegate myself
Old 03-16-2008, 12:23 PM   #11 (permalink)
Double J's Avatar
Member Number: 25570
What pcm are you on? If your running it with a stage 2 pcm, it won't matter how tight you make the wga. It's not going to hold any more then 17 psi on pcm controll. My E1 does that and I have seen about 3 or 4 other guys with the same problem.
You'll have to run the wga right off the turbo if you want to run more boost on the stage 2 pcm.
AGP S3D /40 lb. wheel- Mopar Stage 3 W/Toys- Maxxfab 3" TBE w/out cat- Mopar STS- Exhaust Depot ic pipes w/ HKS ssq bov- AGP CAI - MSD wires-MM Inserts- PTP Check Valve- PTP 55mm TB- CCA FMIC- Slowboy crashbar- Megan Racing CO's- Hotchkis Swaybars- ACT Clutch/Flywheel
Double J is offline   Reply With Quote
Old 03-16-2008, 10:44 PM   #12 (permalink)
Member Number: 8546
im on stage 3 everything stage 3 no halfsteppin here.
Old 03-17-2008, 05:51 PM   #13 (permalink)
Double J's Avatar
I would do a boost leak test. Then reset your pcm.
