What's the difference between low and high impedance injectors? - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 10-18-2004, 10:18 AM   #1 (permalink)
Member Number: 4953
Default What's the difference between low and high impedance injectors?
Just wondering what's the difference between high and low resistance fuel injectors, and are there any performance difference between the two?
Do we have the high impedance ones in our SRT-4?
TIA
bluert is offline   Reply With Quote
Old 10-18-2004, 10:25 AM   #2 (permalink)
Member Number: 326
Yes they are.
SRT4B is offline   Reply With Quote
Old 10-19-2004, 08:26 AM   #3 (permalink)
Member Number: 99
Performance differences? Sure there are, without some modification low impedence injectors won't perform in the place of high impedence injectors, same goes for high impedence injectors in the place of low impedence injectors.
Sometimes knowledge eludes me and logic fails me, so to compensate I lie.
Kyle is offline   Reply With Quote
Old 10-19-2004, 01:16 PM   #4 (permalink)
Member Number: 2728
Low Z injectors I believe are peak-and-hold (they draw a lot of current) - they are generally used for injectors 50 lb/hr and over. I think high Z injectors are used because they are cheaper and the driver is cheaper/more reliable. I don't know of a production car with low Z injectors (stock).
-Alex
AlexA is offline   Reply With Quote
Old 10-19-2004, 02:09 PM   #5 (permalink)
diablo25mn's Avatar
Member Number: 1104
-Alex
Hmm couple cars that come w/ low impendance stock. Lets see... 80s/early 90s turbo dodges, DSMs, Supras, 300zxs, GNXs, Turbo T/As, Early Evos i think, some ODB-1 Hondas, and a couple more out there. Low impendance are considered overall better but they typically draw way more current and are louder than high impendance injectors
diablo25mn is offline   Reply With Quote
Old 10-19-2004, 04:26 PM   #6 (permalink)
Member Number: 4953
So a low resistance flows just as much as a high resistance injectors or vice versa if they are both 850cc etc....?
Old 10-19-2004, 04:50 PM   #7 (permalink)
AnotherSlowSRT4's Avatar
Member Number: 17879
I think what there trying to say is one will flow more in certain points than others. (RPM's that is)
AnotherSlowSRT4 is offline   Reply With Quote
Old 10-20-2004, 07:42 AM   #8 (permalink)
Mattyb's Avatar
Member Number: 10963
GN's GNX's Turbo Regals and TA's all come with HIGH Z injectors..... You have to mod your computer in Buicks to use the LOW Z injectors. I've seen High Z's up to 65's. I'm not sure about the rest of your list but it doesnt sound to correct.
Mattyb is offline   Reply With Quote
Old 10-20-2004, 06:26 PM   #9 (permalink)
diablo25mn's Avatar
Member Number: 1104
My GNX runs low impedepance... go figure.. and so does my friend's dsm, and my friend's supra. As they all offered me their injectors for my neon when i was shopping for some
Old 10-20-2004, 11:40 PM   #10 (permalink)
Member Number: 2728
I think you can actually put a low Z injector in a car setup for high Z, but you'll eventually damage the drivers. Using a 50+ lb/hr high Z injector will probably give a bad idle as the low pulse width control is sucky.
-Alex
Old 10-21-2004, 06:43 AM   #11 (permalink)
Mattyb's Avatar
Awsome, glad someone hacked another GNX So which GNX of the 547 do you HAVE??? Buicks have High Z drivers, you need to send you comp out to run Low Z's simple as that. You prolly bought a set of the Siemens 55's and someone told you that they where low z, when in fact Siemens makes a High and low in 55's <<< Its prolly mix up like that....
Got any pics of your GNX??
Old 10-21-2004, 07:42 AM   #12 (permalink)
Member Number: 4953
-Alex
Hmmmm.. that make sense why some hp car with big injectors uses low impedance ones??
Old 10-21-2004, 11:29 AM   #13 (permalink)
diablo25mn's Avatar
Member Number: 1104
Sorry dude 86 GN- not a X model those are hard to find, and as far as pics eh i think i'll pass i don't even have pics of my neon. I'll have my step-dad check the injectors on the car, considering i'm in Gainesville,Fl for school and the car is back in Miami (in storage). But i have seen some high impedance cars run low impendance injectors without a resistor box, but not for an extended period of time.
