#16 (permalink) |
![]() Join Date: Jan 2007
Member Number: 50159
Ive had the same msd coil on my car for 6+ years, 70k miles, and 435+ hp. The only time I had issues was with it overheating. Slapped a heat shield on, no more issues.
| Sponsored Links | |||
Advertisement | |||
#18 (permalink) |
Fresh Meat Moderator
![]() Join Date: Dec 2009
Member Number: 76568
Some of the MSD's work, but they have a super high failure rate. Its just not worth it for the .5HP gain you may get.
![]() Diablo CMR tuner ~Dan~ 2004 Black Neon SRT4: E85 stock turbo SOLD ![]() 310HP 436TQ 2004 Eblue Neon SRT4: E85 5558 ![]() XXXHP XXXTQ |
#19 (permalink) |
![]() Join Date: Mar 2010
Member Number: 78519
I bought a car that didn't have upper or lower heat shield but came with a broken one in the trunk.
It's made from some fairly thick aluminum. For the time being at least I traced it onto some thin metal I found in my attic and made my own. ![]() ![]() I can't tell how thin the metal that you used is from your pics, but if it's like 1/32 of an inch (.032") thick or less then it's probably not doing much as far as deflecting goes. That and the fact that it looks like steel which will retain the heat for longer. Guy's if you're going to make your own, pick up some 1/8 of an inch (.125") thick aluminum and fab on up
BURN RUBBER ░░▒▒▒▓████ Full stage 3R on E85 ![]() Mod list: http://www.cardomain.com/ride/3855900/2004-dodge-neon |
#20 (permalink) |
![]() Join Date: Jul 2011
Member Number: 85390
According to MSD they had a insulation problem on the earlier production runs.. has been fixed since as they now use a different insulation material. I have had 1 on my DD for over 70K not a single issue, and my toy for over 30k and no issues, other than a hotter spark.
Yes, I know.. your milage may vary and this is just my exp,,
451whp/440wtq on 92pump with 100%meth inj@28PSI
Tune Finished, ACT 6 puck installed. Not quite done. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
