Old 10-30-2008, 10:45 PM   #1 (permalink)
Member Number: 56991
Default Weird Issue Help!!!
OK I've thought it was the tune and maybe it STILL is not sure I've switched from SFAC Neo to SCT Tune from AGP still have same problem. After going Big Turbo it seems after I come to a stop by car will go really LEAN 17's max out my Wideband AEM and car will start to stumble like its going to die. Then go back up. It only does this after I slow down and come to a stop. Any thoughts?? Maybe a sensor or something
99.9% Stock!
RaiedZ is offline   Reply With Quote
Old 10-31-2008, 01:27 AM   #2 (permalink)
bump!
Old 11-01-2008, 01:09 AM   #3 (permalink)
Anyone??
Old 11-01-2008, 05:18 AM   #4 (permalink)
SRTMIAMI's Avatar
Member Number: 54645
Trader Rating: (12)
if you smell fuel and the car starts feeling like its camming you need to replace your upstream o2 sensor and reset your pcm...: then drive it around for a while and it should go away...
GT3076R-AEM EMS-DP VARI-COOL
WWW.MYFLORIDASRT.COM
SRTMIAMI is online now   Reply With Quote
Old 11-02-2008, 02:58 AM   #5 (permalink)
Well its for sure camming out and I've noticed the smell of Gas a lot lately. Up stream the one on the o2 housing correct??
Old 11-08-2008, 05:05 PM   #6 (permalink)
SRTMIAMI's Avatar
Trader Rating: (12)
yes there is an upstream and downstream sensor... you need to replace your upstream...
Old 11-17-2008, 12:24 AM   #7 (permalink)
Well I replaced the upstream 02 Sensor with a Bosch and it seems that its still going it. Could it just be the SCT tune or any other suggestions?
Old 11-17-2008, 12:31 AM   #8 (permalink)
Lupis's Avatar
Member Number: 47638
when mine did that i replaced the sensor and reset the pcm and it took alittle bit for it to go back to normal..prolly 2-3 days. then it idled like a champ
Running out of bolt ons...
Lupis is online now   Reply With Quote
Old 11-19-2008, 11:11 PM   #9 (permalink)
Been over a week same issue!
Page generated in 0.14677 seconds with 13 queries
