Virtual dyno - Page 4 - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 01-09-2013, 01:12 PM   #46 (permalink)
Crazyced's Avatar
Member Number: 56385
Quote: Originally Posted by SRT4Delta46 View Post
has anyone tried the program yet i just did but i kinda dont believe the results lol.. it seems way high to be hones even on mustang dyno results.. what smoothing settings do you guys use?
Look at my previous posts for data:
Don't forget to put the drivers weight in along with everything else posted above and choose the right gear.
The results will be bad if you had any kind of wheelspin (even bumps on the road).
Crazyced is offline   Reply With Quote
Old 01-09-2013, 01:16 PM   #47 (permalink)
SRT4Delta46's Avatar
Member Number: 88656
ok so i took a log i had that i did when i first installed the pte 5431 with a sucky manual boost controller at 22psi dropping down to 19psi according to the Virtual dyno on Mustang dyno reading on smoothing factor 2 is 352hp@4288 and 433Trq@4288 and on smoothing factor 3 that i think most people use is 327hp@4438 and 401Trq@4288
Now the Dynojet numbers are as followed smoothing factor 2 404Hp@4288 and 497Trq@428 and smoothing factor 3 is 375Hp@4438 and 460Trq@4288
Agp Kit with 5431 Turbo Tuned by Nigel aKa Turbo666
SRT4Delta46 is online now   Reply With Quote
Old 01-09-2013, 01:25 PM   #48 (permalink)
do they sound legit? now i did talk to nigel awhile back and he told me on his tune on 22psi on his dyno he would think it would be clost to 330hp and by the virtual dyno on mustang results its 327hp!!! i say this tool is pretty awsome.. going to up the boost to 25psi pump gas soon and fix my boost leaks and see what it says... plan on taking to dyno when spring gets here so i will compare the results
Old 01-09-2013, 01:30 PM   #49 (permalink)
Crazyced's Avatar
Smoothing 1 seems to be the most accurate for my log.
Old 01-09-2013, 02:01 PM   #50 (permalink)
D-SRT's Avatar
Member Number: 80561
IB4ownersstartputtingVD#sintheirsig
Pumpking.
10.71@140. 1st SRT in TENS in CA.
Thanks to:
TUNED BY MINDMELT101@DRAG-ON Tuning. - http://drag-ontuning.com/blog/
GOKEY RACING for anything fabrication related
instagram for updates and pics: m_santiago37
D-SRT is offline   Reply With Quote
Old 01-09-2013, 02:07 PM   #51 (permalink)
Fresh Meat Moderator
tunerlover3's Avatar
Member Number: 76568
Yeah really
Diablo CMR tuner ~Dan~
310HP 436TQ
XXXHP XXXTQ
Old 01-09-2013, 02:16 PM   #52 (permalink)
Ridin59vette's Avatar
Member Number: 86347
Haha There's Probably already a few on here
04 SRT-4: Under Construction
99 9-3: Daily Driver
FS Thread:
http://www.srtforums.com/forums/f416...5/#post9777568
Ridin59vette is offline   Reply With Quote
Old 01-09-2013, 06:45 PM   #53 (permalink)
draxxus's Avatar
Member Number: 87964
Hmmm im glad i started this thread now. Hope everyone enjoys
SAMSUNG-SGH-I747 using AutoGuide App
2004 NSRT Flame Red, AGP wastegate, AGP Solid motor mounts, Eibach Street line springs, Energy suspension bushings, Maddog 58% STS, 3" downpipe w cutout, AEM SRI, Home Depot Catch Can, 750cc DW injectors
draxxus is offline   Reply With Quote
Old 01-09-2013, 08:31 PM   #54 (permalink)
toofast82's Avatar
Member Number: 76443
I had a good opportunity to play around with the program some this afternoon. I made a good amount of street pulls to tweak up my 93 tune a tad since i never really put much time into it since switching back off of E85. The graphs lay right on top of each other very well when making comparisons and the power and curve was consistent between pulls with the changes made.. I'd be one to be very skeptical on these types of things, but honestly the numbers were right on par with what i figure the car should be at given the bolt-ons and stock turbo.
If anything it is an excellent tool to help with street tuning the vehicle in my opinion and i will definitely use it in the future with changes on the car
toofast82 is online now   Reply With Quote
Old 01-09-2013, 08:55 PM   #55 (permalink)
Glad to hear. I'm also going to be using as well!! What smoothing factor did you use?
Old 01-09-2013, 08:58 PM   #56 (permalink)
toofast82's Avatar
smoothing 1 seems to be on par for me.. but honestly i'm in it more for the tuning aspect of it. But 1 seems to be most on par for my particular car given trap speed and other similar setups and dynos i've seen
Old 01-10-2013, 07:03 AM   #57 (permalink)
duster360's Avatar
Member Number: 45182
You guys should test Hp output with the bare minimum of PIDs recorded and then with the Maximum and see how the result vary.
1025cc Injectors+ E85/GAS Base tunes =$359
ADD Boost By Gear to ANY PCM boost control tune $75
E85+Gas Base tune Combo $150*[*Only available for 1025cc Siemens/FIC1100&2150/AGP1200/All ID]
PLEASE USE EMAIL!!dave at needlesstorque dot com
Old 01-10-2013, 08:39 AM   #58 (permalink)
TylerM's Avatar
Member Number: 85528
Yes generally for vd in the evo world it likes only speed and rpm for the best log.
And if you want boost and afr but i don't think the srt ecu can log a wideband.
2005 Silver - Sold
2006 Evo IX GSR SSL SRT 4 Kills-3 SRT 4 Wins-1
TylerM is offline   Reply With Quote
Old 01-10-2013, 09:05 AM   #59 (permalink)
Crazyced's Avatar
Hopefully it won't matter too much once bbarnhil implement the utilization of the engine run time as the time reference.
Old 01-10-2013, 10:42 PM   #60 (permalink)
Barn hill's Avatar
Member Number: 91827
03-05 SRT4s now supported. Also added the ability to use the Engine runtime in diablo sport logs. Just start up your application with it connected to the internet and enjoy my friends!!!
Barn hill is offline   Reply With Quote
