Virtual dyno - Page 3 - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 01-08-2013, 08:40 AM   #31 (permalink)
Crazyced's Avatar
Member Number: 56385
Quote: Originally Posted by draxxus View Post
Hey bbarnhill glad I could get you in on this. Im going to try out your progrma as soon as I get a chance. My buddy is running it for his wrx and he said he absolutely loves it. Are you going to update the program to have the srt4 as an actual option in the droo down?
SAMSUNG-SGH-I747 using AutoGuide App
He also need a Diablosport datalog with the engine run time PID active. If someone could take a quick one.
Crazyced is offline   Reply With Quote
Old 01-08-2013, 12:21 PM   #32 (permalink)
Barn hill's Avatar
Member Number: 91827
Yeah Ill be glad to add SRT4 support and take a look at the diablo time issue given the right info. If the info above is correct for the 03-05 SRT4 Ill get it added. Someone please confirm the above specs and chime in. Also any data log will work it doesnt have to be a great log or anything. I just need to see the columns in a data file.
Barn hill is offline   Reply With Quote
Old 01-08-2013, 12:34 PM   #33 (permalink)
Crazyced's Avatar
What D-SRT posted is accurate, along with the 25.07" stock tire diameter and the gearing I posted. Although the curb weight says 2970lbs, I think the consensus says that it's actually a bit lighter, hence why I used 2900, to not inflate the results.
Quote: Originally Posted by D-SRT View Post
Yes the transmission specs are correct.
"Official" curb weight is 2970lb I believe.
Drag Coeff - .35
Frontal Area - 22.28
Old 01-08-2013, 02:02 PM   #34 (permalink)
draxxus's Avatar
Member Number: 87964
Im at work or id post one up
2004 NSRT Flame Red, AGP wastegate, AGP Solid motor mounts, Eibach Street line springs, Energy suspension bushings, Maddog 58% STS, 3" downpipe w cutout, AEM SRI, Home Depot Catch Can, 750cc DW injectors
draxxus is online now   Reply With Quote
Old 01-08-2013, 03:21 PM   #35 (permalink)
draxxus's Avatar
Does it have to be any log? Does it have to have anything specific?
Old 01-08-2013, 03:43 PM   #36 (permalink)
Crazyced's Avatar
As long as it have the 'engine run time' PID logged in it it will be fine. But adding RPM and MPH at least won't hurt.
Old 01-08-2013, 11:22 PM   #37 (permalink)
toofast82's Avatar
Member Number: 76443
I tried this program after seeing this thread. I put an old log from last summer on e85 and it actually was exactly what i figured around what the car made and off of trap speed. I was pretty impressed. I'm going to take my car out tomorrow if its decent out and do some logging and tweaking to the tune so i'll have more of a chance to play with it then. If anything it should be somewhat useful for seeing how the car responds to different mods or changes in tune
toofast82 is offline   Reply With Quote
Old 01-09-2013, 04:33 AM   #38 (permalink)
draxxus's Avatar
I was. Looking for the engine run time pid and couldbt find it what tabnis it under?
Old 01-09-2013, 06:35 AM   #39 (permalink)
Crazyced's Avatar
Make sure you try and find the engine run time PID.
I can't help you on that one, you might have an easier time finding it in Dataviewer on the laptop.
Old 01-09-2013, 07:25 AM   #40 (permalink)
draxxus's Avatar
I was on the dataviewer. Idk ill look again and try to do some pulls before work and upload them. Now my next thing how do I upload them on the forum
Old 01-09-2013, 10:20 AM   #41 (permalink)
toofast82's Avatar
I messaged Brad a log with engine runtime just now
Old 01-09-2013, 10:33 AM   #42 (permalink)
draxxus's Avatar
Thanks man I appreciate it
Old 01-09-2013, 12:27 PM   #43 (permalink)
Crazyced's Avatar
Thank you.
Old 01-09-2013, 01:03 PM   #44 (permalink)
SRT4Delta46's Avatar
Member Number: 88656
has anyone tried the program yet i just did but i kinda dont believe the results lol.. it seems way high to be hones even on mustang dyno results.. what smoothing settings do you guys use?
Agp Kit with 5431 Turbo Tuned by Nigel aKa Turbo666
SRT4Delta46 is online now   Reply With Quote
Old 01-09-2013, 01:06 PM   #45 (permalink)
turbo srt4's Avatar
Member Number: 47173
what did it say?
turbo lag was invented so v8s could keep up
DELTA 46 417 WHP 429 WTQ
turbo srt4 is offline   Reply With Quote
