Virtual dyno - Page 11 - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 01-22-2013, 11:40 PM   #151 (permalink)
toofast82's Avatar
Member Number: 76443
Quote: Originally Posted by Barn hill View Post
I say this after many attacks on forums besides this one. This forums has been pretty calm and a bunch of nice guys so far.
I'd have to imagine that most of the people that don't like this program either don't have it setup or configured properly or are butthurt over the numbers they are coming up with. It's not really so much about the numbers, as it is a great tuning aid. But at least for my setup, the numbers are a very good ballpark figure i'd imagine
They have to keep in mind that its a free program that you put your time into creating and are here for support for these forums. I appreciate it
toofast82 is online now   Reply With Quote
Old 01-23-2013, 05:12 AM   #152 (permalink)
draxxus's Avatar
Member Number: 87964
Default Re: Virtual dyno
The numbers were higher when I changed it to a 4th gear pull. But when I put it in third gear my number were like 160 then when I changed it to 4th gear the came up to about 270 which is about what I was figuring
SAMSUNG-SGH-I747 using AutoGuide App
2004 NSRT Flame Red, AGP wastegate, AGP Solid motor mounts, Eibach Street line springs, Energy suspension bushings, Maddog 58% STS, 3" downpipe w cutout, AEM SRI, Home Depot Catch Can, 750cc DW injectors
draxxus is offline   Reply With Quote
Old 01-23-2013, 09:42 AM   #153 (permalink)
Barn hill's Avatar
Member Number: 91827
Go to File -> Car Editor and look over the numbers for your car in there. Make sure one of the gear ratios isnt off. If it is report it to me and Ill fix it in the definitions.
Barn hill is offline   Reply With Quote
Old 01-24-2013, 10:47 AM   #154 (permalink)
draxxus's Avatar
I can do that once I get home
Old 01-26-2013, 10:45 AM   #155 (permalink)
Barn hill's Avatar
awesome ... keep me posted drax
Old 01-27-2013, 10:53 AM   #156 (permalink)
Crazyced's Avatar
Member Number: 56385
I just checked and the gear ratios a re correct.
Crazyced is online now   Reply With Quote
Old 01-28-2013, 06:44 AM   #157 (permalink)
draxxus's Avatar
Yes they are good. Might just be a bad run
Old 01-28-2013, 08:20 AM   #158 (permalink)
Barn hill's Avatar
Could be ... make sure the road is the flattest you can find, and with no gravel or pot holes as wheels spin will cause a spike.
I only left the 0 smoothing option in there so I could use it to spot spikes. It will look pretty wavy but you will definitely notice the spikes if you have any.
Old 01-28-2013, 09:03 PM   #159 (permalink)
draxxus's Avatar
Figured out the problem. Put 17 in for wheel diameter insted of 25. Whatever. So got that fixed and put me at about 280 hp and cant remember tq. Which is what I was figuring with basic bolt ons 750cc injectors exhaust ported tb and meth
Old 01-29-2013, 09:06 AM   #160 (permalink)
Barn hill's Avatar
hahaha ... nice. There is a little button beside tire size you can enter your tire specs and it will figure the diameter for you. I measure instead of using it though just so Im pinpoint accurate. The more accurate your information the more accurate VD is. Grats on figuring out the issue Drax!!
Old 01-29-2013, 11:42 AM   #161 (permalink)
draxxus's Avatar
Thanks man I think its a really good tool and thanks for doing this for us
Old 01-29-2013, 01:58 PM   #162 (permalink)
Crazyced's Avatar
How about slicks? I run 24.5"s but slicks have a tendency to 'grow' at higher speed. Do you think it could significantly impact the results?
Old 01-29-2013, 02:09 PM   #163 (permalink)
Member Number: 51111
I think the gear ratio change of the slick will matter more than that....24.5's don't grow that much to care
go ahead...change yours too now; again
lVlemphizStylez is offline   Reply With Quote
Old 01-31-2013, 12:17 PM   #164 (permalink)
Barn hill's Avatar
What do you have a pro mod dragster?
I guess that could make the numbers off a little bit at higher speed ... but I think your measurements of the tires is going to be off more with the human measuring factor than its going to change size. What about tread wear? These are things I worry about with my numbers. I make sure to measure myself. The more accurate and 'anal' you are about those details the closer your numbers will be.
Old 02-25-2013, 08:31 AM   #165 (permalink)
SRT4Delta46's Avatar
Member Number: 88656
how do you get to show the AFR and Boost?
Agp Kit with 5431 Turbo Tuned by Nigel aKa Turbo666
SRT4Delta46 is online now   Reply With Quote
