Valvoline 5w-20 SynPower Oil??? - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 01-17-2013, 11:40 AM   #1 (permalink)
RiotMaker's Avatar
Member Number: 84453
Default Valvoline 5w-20 SynPower Oil???
I told the mechanic to use 5w30 and he put 5w20 valvoline synpower oil instead. Will this oil be all right in my car????. He said it is the same thing...... and will be alright in my car.
RiotMaker is offline   Reply With Quote
Old 01-17-2013, 11:42 AM   #2 (permalink)
famoussrt4's Avatar
Member Number: 53668
How many miles so u have? That oil is thinner
famoussrt4 is offline   Reply With Quote
Old 01-17-2013, 11:42 AM   #3 (permalink)
RiotMaker's Avatar
I have 88000 miles
Old 01-17-2013, 11:43 AM   #4 (permalink)
Ridin59vette's Avatar
Member Number: 86347
Take It back and tell him to do it right. It is not the same. That oil is too thin to be used in our cars
04 SRT-4: Under Construction
99 9-3: Daily Driver
FS Thread:
http://www.srtforums.com/forums/f416...5/#post9777568
Ridin59vette is offline   Reply With Quote
Old 01-17-2013, 11:46 AM   #5 (permalink)
famoussrt4's Avatar
Agreed...
Old 01-17-2013, 04:43 PM   #6 (permalink)
SRT4Delta46's Avatar
Member Number: 88656
Default Re: Valvoline 5w-20 SynPower Oil???
Yea that's too thin. Tell him to change
Agp Kit with 5431 Turbo Tuned by Nigel aKa Turbo666
SRT4Delta46 is offline   Reply With Quote
Old 01-17-2013, 07:12 PM   #7 (permalink)
Member Number: 63342
Just because 5w30 is the 'recommended' oil doesn't mean that's what you have to use ALL the time. Various factors can play into it, weather mostly. Depending on where you live in Albuquerque, it can get cold. And since it is winter time, thicker oil and cold weather don't mix well. It can cause hard starts which wears on your starter. In the winter time I ALWAYS go to a thinner oil.
E1 turbo, PTP pnp e-mani, FM wga, 3" O2, full 3" Thermal R&D exhaust, full 2.5" IC piping, TurboXS RFL, filter on turbo, NGK plugs, AEM uego WB, Spearco DFFMIC, MM inserts, AGP tranny mount, ACT 6 puck, Maddog 80% sts;
best dyno 307whp/301wtq @ 19psi
13.676 @ 106 on 20spike, 16-17 redline.stocker
13.45 @ 103 ~18psi spike, 16 hold. pcm boost/stock WG
E1 at ~16psi spike/hold; 13.3 @ 105 w/pcm boost(can't launch/no driver mod ftl)
1fast4 is offline   Reply With Quote
Old 01-17-2013, 07:49 PM   #8 (permalink)
Member Number: 86430
The first number of the oil grade is the 'winter weight', meaning it flows like a 5 weight oil when cold, which would be thinner than a 10 weight oil when cold. That's the number to look out for when trying to prevent cold weather 'dry' starts that can cause bearing and cylinder wall wear. However aside from climate, bearing clearances will also dictate what oil weight to run.
The second number is the hot temperature protection rating, which on a turbocharged vehicle is really important. In this application a 20 rating would not provide the protection needed when the turbo gets hot, especially after spirited driving. This is where oil coking comes in and can cause oil flow issues as well.
For a completely stock SRT-4, 5W-30 is sufficient. However anybody that drives their car hard and/or is running higher amounts of boost or a big turbo really should be using at least 5W-40 IMO.
DROID3
DSP Performance Tune, exhaust resonator delete, Innovate MTX-L: 252 WHP 321 WTQ
4FishLimit is offline   Reply With Quote
Old 01-17-2013, 08:13 PM   #9 (permalink)
Member Number: 35677
Default Have a visocity chart at all times
Look at the following chart - look at the low temperature for your area. Do you really need the left number to be anything but 10W? 20-50 is usually a kind of race grade oil. Fortunately with synthetic oils there is great flexibility in temperature suitabiltiy, but a 10w-30 oil would be a better choice. There isn't likely to be any damage to your engine.
Google Image Result for http://www.clubprotege.com/forum/attachment.php%3Fattachmentid%3D53029%26d%3D132543 8001
ValleyRacer is offline   Reply With Quote
