Vacuum Lines...newb - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 12-05-2012, 10:51 AM   #1 (permalink)
Member Number: 91385
Default Vacuum Lines...newb
ok so i dont understand what to do with the vacuum line setup. I just got the car not long ago, and as far as i can tell its stock except for a CAI, and aftermarket BOV. Ive been reading up on this and im confused as to what to do or how this improves the performance. Oh BTW i have a 3" catless Y with cutout. I do have a CC, 2 to be exact. Can someone answer my questions here? No smartass answers either. THANKS!
boost4dad is offline   Reply With Quote
Old 12-05-2012, 11:03 AM   #2 (permalink)
Member Number: 72787
How what improves performance?... what exactly are you trying to do? If you have a BOV and a CAI, run the black hose that went to the stock airbox to your CAI, put a breather valve on your valve cover and tap into a line from the intake manifold for the signal to the BOV. That will eliminate the pink line I believe it is to the surge valve and you should be good. Look up the diagrams by NorthNJsrt or something to that effect... he has them all diagramed.
Ryan
sidepipe87 is offline   Reply With Quote
Old 12-05-2012, 11:49 AM   #3 (permalink)
Member Number: 90281
Vacuum line setups
Here you go mang.
After 120 you should be content with the fact that you can die at any moment.
Bloo magoo is offline   Reply With Quote
Old 12-05-2012, 11:58 AM   #4 (permalink)
Thanks a lot. Yea I've seen a bunch of diagrams, but I was wondering what re-routing the lines actually do. When I look at the diagrams, there's no clear description on exactly what it's supposed to do. Get where I'm going?
Old 12-05-2012, 01:32 PM   #5 (permalink)
evobusa7's Avatar
Member Number: 91450
my pcv has a breather filter, is that right?
evobusa7 is offline   Reply With Quote
Old 12-05-2012, 02:30 PM   #6 (permalink)
Member Number: 3797
I think you are looking at the port on the driver side of the valve cover on the side. The PCV is on the passenger side on the top.
2003 SRT-4 Silver, AGP GT3076R on E85 DD!
Was 478hp/508tq ----> Now ???
2002 Camaro SS M6, going N/A...
enginjoe is offline   Reply With Quote
Old 12-05-2012, 02:33 PM   #7 (permalink)
evobusa7's Avatar
yes, my pcv valve has a vac line and its closed with a lil air filter...is that right?
Old 12-05-2012, 02:53 PM   #8 (permalink)
Member Number: 3797
What I get is that you should leave everything alone since you don't know what you are looking at as well as anything about a turbo car. Moving those lines around doesn't get you performance...but you would know that if you had read anything in the performance modification sticky area...
Old 12-05-2012, 02:54 PM   #9 (permalink)
Member Number: 3797
Take a pic of the top of the motor, I gotta see this.
Old 12-05-2012, 03:13 PM   #10 (permalink)
evobusa7's Avatar
[IMG][/IMG]
Old 12-05-2012, 03:23 PM   #11 (permalink)
Member Number: 3797
So, the PCV goes to the catch can then out of the catch can over by the throttle body to a little filter?
It should be hooked to the throttle body.
Old 12-05-2012, 03:31 PM   #12 (permalink)
evobusa7's Avatar
no...my pcv just is connected to the lil filter at the end.. but its not connected to a catch can or the throttle...would that be a vac leak?
Old 12-05-2012, 03:33 PM   #13 (permalink)
evobusa7's Avatar
Old 12-05-2012, 03:37 PM   #14 (permalink)
Member Number: 3797
I see in your pic the PVC connected to the red catch can, then it goes out towards your throttle body and I can't see anything else because of the red blob in the pic.
Old 12-05-2012, 03:39 PM   #15 (permalink)
steellittledude's Avatar
Member Number: 75042
Your PCV goes through the catch can and into the TB like its supposed to, you can see it in your picture. Take a close up pic in your engine of this filter your talking about.
Engine bay looks great btw!
It's 106 miles to Chicago, we got a full tank of gas, half a pack of cigarettes, it's dark, and we're wearing sunglasses......Hit it
steellittledude is offline   Reply With Quote
