Old 11-07-2009, 03:43 PM   #16 (permalink)
Member Number: 72478
its the turbo xs type s
Nervus is offline   Reply With Quote
Old 11-07-2009, 07:16 PM   #17 (permalink)
wowwowweewhoa's Avatar
Member Number: 55784
^no such thing.... its a turbo xs type "H" or "RFL", or a greddy type "S".... if it is a type s from greddy then it can flutter.
BC Stage 2 Cams BC Springs and Retainers Fidanza Cam Gears Msd Coil Msd Wires Agp Hard Pipes Agp WGA Perrin SRI Mpx TBE Single Exit Mpx FMIC Mpx Heat Shield Turbo XS Rfl BOV Eibach SportLine Springs 17" Tenzo R DC 6.... Internal Motor Work Done By Turbo666
wowwowweewhoa is offline   Reply With Quote
Old 11-07-2009, 07:40 PM   #18 (permalink)
bene's Avatar
Member Number: 53801
Trader Rating: (40)
adding a washer to prevent flutter is the exact opposite of what you want to do... remove all washers. the spring pressure from the stock spring is a bit much for the stock turbo so it will fluter - 5 psi
bene is online now   Reply With Quote
Old 11-08-2009, 08:25 AM   #19 (permalink)
i mean we dont even know exactly what bov it is..... if its the type s you can adjust it from soft to hard. if its a turbo xs you have to adjust it with the washers it came with. im using four in my rfl atm.
Old 11-08-2009, 09:21 AM   #20 (permalink)
04SRT_08's Avatar
Member Number: 68190
Trader Rating: (15)
^^ same here i have four too. just post up an f-ing pic and itd be much simpler than guessing
'04 SILVER NSRT-4
AGP 50 TRIM @10psi untuned
04SRT_08 is offline   Reply With Quote
Old 11-08-2009, 09:29 AM   #21 (permalink)
^ four washers ftw!
Old 11-08-2009, 09:51 AM   #22 (permalink)
04SRT_08's Avatar
Trader Rating: (15)
^ four washers ftw!
Old 11-08-2009, 09:38 PM   #23 (permalink)
turbo XS Type H-RFL, flutters anytime the boost is under 8psi..
Old 11-08-2009, 10:42 PM   #24 (permalink)
blackandbluesrt4's Avatar
Member Number: 71452
check all your lines. make sure the TB line is still connected to everything. make sure the blow off valve connection is secure. also, make sure your vac lines are big enough. that can make a big difference. they need to be small enought to fit snug on the top of the blow off but big enough to flow through. if all that is fine, then lose some washers one at a time until it works. i only have 2 at 20psi and it works fine. you're positive you have a block off plate on the turbo? cause it kinda sounds like the stock blow off is still connected....
04 nsrt-4 E-blue
Seibon CF stocker, Stock exhaust(gutted cat, sounds better than my side exit!), mopar sts w/booger/MPx knob, Turbo XS on stock couplers, HD catch can, ebay CAI, ebay MBC at 20psi, P&P intake mani and TB, apexi TT. pump rewire, fan switch. http://www.srtforums.com/forums/f27/...lights-540636/
blackandbluesrt4 is offline   Reply With Quote
Old 11-09-2009, 09:17 AM   #25 (permalink)
red04's Avatar
Member Number: 24993
Trader Rating: (49)
You need to take the pink line off the car and run a vac line from the throttle body spacer to the blow off valve. With the pink line hooked to it the factory solenoid has control over the valve which you dont want.
Scott @ Forward Motion Inc.
302-658-2829
www.forwardmotioninc.com
Email: scott@forwardmotioninc.com
Paypal Address: scott@forwardmotioninc.com
Owner of FM's GT37R powered SRT4 513 whp 469 wtq pump gas (93 octane) @ 6,000 rpms
11.31 @ 131.74 mph w/ 1.90 60'
red04 is offline   Reply With Quote
Old 11-09-2009, 03:52 PM   #26 (permalink)
I have a BoP on, and have that fucker silicon glued sealed shut and screwed it. Pink line might be the flutter, would that also lead to a small boost leak? also i haven't checked the washers yet..I'm running stock boost so about 10-12 psi.
Old 11-09-2009, 04:11 PM   #27 (permalink)
Member Number: 60098
i mean we dont even know exactly what bov it is..... if its the type s you can adjust it from soft to hard. if its a turbo xs rfl you have to adjust it with the washers it came with. im using four in my rfl atm.
I had to use 4 washers as well, just play around with it untill you get no leaks or flutters
oldasdirt78 is offline   Reply With Quote
Old 11-09-2009, 11:23 PM   #28 (permalink)
please just post pictures. that would solve all of the issues.
Old 11-10-2009, 02:42 PM   #29 (permalink)
pics or ban!
Old 11-17-2009, 01:55 PM   #30 (permalink)
Member Number: 75469
Ok, not trying to hijack the thread, but my RFL just started fluttering TODAY. I have 4 washers. It only flutters under 5psi or so, any higher than that and I still get a perfect sound. Could I be hearing compressor surge?
Turbonetics .50/.63, Turbonetics Evolution WG, Wiseco Pistons 8.8:1, Eagle H beams, Clevite bearings, PSi Fi Solid mounts, AEM CAI, BWoody Check valves, RC 750s, Custom Return Line, Custom oil catch, AGP exhaust manifold, 3" custom turbo back, custom MBC, Innovate LC-1, DSP, Turbo XS BOV, 25psi
LinkLow is offline   Reply With Quote
Page generated in 0.14211 seconds with 13 queries
