tuning stage 1 - Dodge SRT Forum
post #1 of 26 (permalink) Old 01-21-2013, 03:59 PM Thread Starter
Quoted: 1 Post(s)
tuning stage 1
how much horsepower can I look at getting with just the stage1,intake, and 3 inch from o2 housing to the back?
I'm debating on buying a Wally and rc750cc injectors to max out the turbo.
Idk which route to go with as i'm still learning about upgrading parts.
jneon2003 is offline
post #2 of 26 (permalink) Old 01-21-2013, 04:08 PM
Merderates da formz
NorthNJSRT4's Avatar
Quoted: 3 Post(s)
You'll make whatever your local dyno says you make. Adding mods does not have a predictable result where if you put on X you'll get Y HP.
Read the guide before wasting money on parts you don't need: SRT-4 Performance Modifications and Upgrade Paths
Stage 1 is completely obsolete, you'll do MUCH better with a handheld flash programmer.
NorthNJSRT4 is offline
post #3 of 26 (permalink) Old 01-21-2013, 04:12 PM
theRTguy's Avatar
Quoted: 10 Post(s)
Garage
I'll refer you to this LINK, read it thoroughly.
If you Don't have a Stage1, Don't waste your $. Get a DiabloSport programmer and go from there.
2004 SRT-4 (45K Miles)DC SPorts Exhaust, MOPAR C.A.I., DSP, MOPAR STS, B WOODY Solid MM Tranny Mount., 3" D.P., 3"O2 Housing, AXIS DECADES 18x8, EIBACH PRO-KIT, AGP CC, Fuel Pump Re-Wire,180 Degree T-Stat, UEGO, N2MB W.O.T. BOX w/2 Step, AEROFORCE Scan Guage, F.I.C. 565cc, DCR Oil Mod, Apexi TT, SouthBend Stage4, COOLINGMIST STAGE_II (dual M3), Walboro 255,3BAR,309whp/413trq non finalized tune
theRTguy is offline
post #4 of 26 (permalink) Old 01-21-2013, 04:29 PM
New Member
Quoted: 0 Post(s)
Why do some people get stage 1 and dsp? Does running a dsp on a stock pcm and running a catless down pipe throw a code? Would running dsp on a stage 1 pcm make a difference as far as not throwing codes?
2005 Black SRT-4(Recently purchased)
Mopar Blow-Off Valve,
Mopar Cold Air Intake,
Mopar Short Throw Shifter,
Needswing Downpipe with electric cutout,
Thermal R&D Exhaust,
Greddy turbo timer,
Greddy Catch Can w/Greddy Bracket
2005 ORANGE BLAST(R.I.P)
trashkilla is offline
post #5 of 26 (permalink) Old 01-21-2013, 05:26 PM
Fresh Meat Moderator
Quoted: 3 Post(s)
Stage 1 PCM wont throw on cat codes.
But you can have a CMR tuner adjust the tune for the stock PCM to do the same thing.
tunerlover3 is offline
post #6 of 26 (permalink) Old 01-21-2013, 05:30 PM
New Member
jay05acr's Avatar
Quoted: 0 Post(s)
But I have read that even with dsp and the code turned off the car won't pass emissions but with stage 1 it will
Go to wikyd-performance.com for all of your srt4 performance needs. Contact jtm0n3y or wonderer86 for more info
http://www.srtforums.com/forums/f416...-parts-639326/ my for sale thread
jay05acr is offline
post #7 of 26 (permalink) Old 01-21-2013, 05:37 PM
Quoted: 3 Post(s)
^ depends on how you turn it off with the CMR software.
There is a "correct" and "not correct" way to turn off the o2 sensor.
post #8 of 26 (permalink) Old 01-21-2013, 06:31 PM
Zenkat's Avatar
Quoted: 51 Post(s)
Interesting to note, if that's true. I always read that the code could be turned off, but that it was a 'not ready' signal still, and would fail emissions OBD tests. Regardless, i have S1 in Arizona and havent bothered getting rid of it because it makes testing a piece of cake.
10.68@137.33
Zenkat is offline
post #9 of 26 (permalink) Old 01-21-2013, 06:38 PM
New Member
jay05acr's Avatar
Quoted: 0 Post(s)
^ this is what I have read... I was very vague in my earlier post thanx zenkat
jay05acr is offline
post #10 of 26 (permalink) Old 01-21-2013, 07:08 PM
Quoted: 3 Post(s)
If you do it the right way, the code will show up as not applicable just like what the stage pcm's do.
post #11 of 26 (permalink) Old 01-21-2013, 11:17 PM
New Member
Quoted: 0 Post(s)
Nice, so I'll keep my stage 1 pcm, i just need to get it flashed....does anyone know where to get it done? Does flight system still flash 'em? I went to the dealer and they said they would charge their normal rate to take the old pcm out, put the new one in, and then flash it, and they said they wouldn't guaranty that it would work... Can they mess it up and erase the tune that's in the pcm?
Greddy turbo timer,
post #12 of 26 (permalink) Old 01-22-2013, 06:09 AM
Merderates da formz
Quoted: 3 Post(s)
If you mean getting the VIN flashed to the PCM so you can use it in your car that's not really a big deal. There are instructions on the site on how to do it that you can bring with you to the dealer. By erase the tune, no, they can always load the S1 calibration on it. If you have a DSP\SCT tune on it now that you're trying to preserve that would likely get wiped out because it's paired to a VIN.
post #13 of 26 (permalink) Old 01-22-2013, 09:35 AM Thread Starter
Quoted: 1 Post(s)
im already stage 1.ive looked at the guide again and im at the stock tubo first mods.the only thing i dont have right now is front mount.
for handheld i bought an sct one,is this ok?i know dsp is more popular for tweaking and datalogging.
post #14 of 26 (permalink) Old 01-22-2013, 11:12 AM
Merderates da formz
Quoted: 3 Post(s)
SCT is just fine but unless you have and learn how to use the PRP option you have to have an SCT tuner make changes for you each time and every time you need even the slightest thing altered. The DSP is more popular because you can get a base tune from a tuner that's got everything you need to run the car then you can tweak fuel, spark, boost, fan activation temps, etc anytime you want and however you want without having to go back to the tuner. The SCT, as you know, doesn't datalog which is extremely helpful when diagnosing issues or tuning fuel and spark. Many people that use SCT will get a DSP that's locked to another car for a very low price just for datalogging purposes.
post #15 of 26 (permalink) Old 01-22-2013, 04:51 PM Thread Starter
Quoted: 1 Post(s)
ok,so now the other question is getting an email tune just as good as getting it dyno tuned?
User Tag List
Linear Mode Linear Mode
