Old 05-17-2008, 05:27 PM   #1 (permalink)
xjoewhitex's Avatar
Member Number: 49136
Default throttle sticking.
Ive noticed this since I got the car and I figured id finally ask about it. The car doesn't stick wide open so it would wind out.. Only happens when I get on it into boost and let off then when I go back onto the gas pedal its kinda stuck so I have to press more firmly on it. So id say its stuck closed?
Any suggestions.
xjoewhitex is offline   Reply With Quote
Old 05-17-2008, 05:35 PM   #2 (permalink)
SRToc Member
jaymzx's Avatar
Member Number: 278
Trader Rating: (12)
I would check around the throttle body cable cam and see if there are any obstructions. Turn the cam manually and see if you feel it bind at any point.
James
READ AND LEARN:
Old 05-17-2008, 06:49 PM   #3 (permalink)
xjoewhitex's Avatar
OK i will do that, it just started with a thunderstorm outside so it will have to wait.
Page generated in 0.12515 seconds with 11 queries
