Old 05-13-2008, 01:01 AM   #1 (permalink)
Nvbby's Avatar
Member Number: 63388
Default Stock to stage 2
So yea, i pretty sure its somewheres on here, but i'm a bit lazy to search. so i just wanted to ask. I would like to jump straight to a Stage 2 Turbo, seeing that its only 500 bux more w/o turbo toys. and i can always add that later, so heres the question. what is everything i need to change? first i'm going to get a 3"down pipe all the way back so i dont have to worry about air flow through there, but dont know what brand or which one sounds good. any tips on that would be helpful as well.
Nvbby is offline   Reply With Quote
Old 05-13-2008, 01:09 AM   #2 (permalink)
Member Number: 59543
learn more about cars................
1st stage 2 is not a turbo kit.
2nd u cant always add toys later.
3rd a 3in. down pipe goin all the way back is purty kustom.
4th just wait a while and talk to guys on here before you go to serious(like stage 2) do some exhaust mods and intake mods.
Kinetic WGA, denso iridium plugs, Vibrant strut brace, Hawk HP+ Performance pads ,Turbo XS RFL, Turbo XS boost controller, MSD coil pack, MSD wires, AGP solid motor mounts, Eibach Sportlines
Wanting to run a Hahn 20G setup just waitin on cash
wannagofstr is offline   Reply With Quote
Old 05-13-2008, 01:12 AM   #3 (permalink)
scottw03's Avatar
Member Number: 23435
Trader Rating: (31)
First off, unless you get a used S2 w/toys PCM but no toys you can't add toys to a S2 no toys PCM. They are not the same PCM. The S2 w/out toys does not have the extra port on the PCM to connect the Toys option to.
So you have to decide which route you want to go before you buy. If you get new the toys option comes with the toys PCM. If you get the no toys option then you can't add on later.
Second, exhaust. My friend has an Exhaust Depot 3 in catless TBE and it sounds great. I have a Needswings Downpipe with a cutout and the stock cat back. sounds ok but it is loud. Get annoying sometimes but then I just close the pipe and it sounds fine for long distance driving.
I would say to looking into exhaust depot or into MaxxFab. Both are good supporting companies on the forums.
scottw03 is online now   Reply With Quote
Old 05-13-2008, 01:12 AM   #4 (permalink)
lilmike0450's Avatar
Member Number: 56278
I agree do some reading lazy ass.
05 White ACR
lilmike0450 is online now   Reply With Quote
Old 05-14-2008, 12:32 AM   #5 (permalink)
Nvbby's Avatar
ok... i didnt know that about the toys. thanks for telling me. Now i am not going too drastically by jumping to a stage 2... i dont see the point of a stage 1 if a stage 2 is just alittle more. i'm asking what is everything that needs to be changed so i can mark a list and slowly upgrade the parts and then put on a stage 2, that way i have no problems. i'm asking to make sure that everything i read goes with those who actually have stage 2's or 3's or whatever.
Old 05-14-2008, 01:31 AM   #6 (permalink)
scottw03's Avatar
Trader Rating: (31)
IMO, the best combination would be S2 (with or without Toys). Depends on if you are going to run race gas, meth injection, and/or go to the track. If you answer "no" to these then don't bother spending the extra money for toys. It will be a waste. Get a Forward Motion wga to replace the S2 wga. Holds boost much better and the part throttle boost is very very minimal.
You do not need anything else other than S2 to support S2. It is a complete bolt-on and go mod. It comes with everything you need. Wga, PCM, MAP sensor, TIP sensor, and injectors. Everything is easy to install. You can do it in your garage or driveway.
Now if you want to maximize the most out of S2, get a 3" TBE to include the 3" O2 housing and meth injection, and wideband since you will need to know where you are a/f wise. A larger intercooler wouldn't hurt either but it isn't necessary.
Old 05-14-2008, 02:16 AM   #7 (permalink)
True story....
Old 05-14-2008, 02:54 AM   #8 (permalink)
Nelson's Avatar
Member Number: 52787
Funny....
Realistically, look at supporting mods as well and learn a little more about your systems first. Stage 2 THRIVES off of a 3 inch exhaust, so you'll need that. No a full body downpipe... Look at maxxfab for an o2 housing and a downpipe at the minimum. There's no better quality part. You don't need to worry about the intake, it will hold you fine on a stage 2. I made the noob mistake and bought a cold air when I could have better spent the 240 buckos. As stated above, look into a wideband O2 setup. Stage 2 runs very rich, so you'll want to get a Map Clamp/SAFC/DTEC/SCT as well to lean it out. See: Tuning. Also what tuning pertains to on our cars. There's a rough start mate... Do some major reading in the performance section and what's hot on the active topics. Ask serious questions and assume nothing. Nobody gets made fun of when they're serious and they've done reading. Search first... ask questions later.
Proud Owner Of The S.S. Neon
Stage 2 w/o, Maxxfab 3in o2 and 3in SEE no cat/no res, AGP Race BFMIC, AEM Wideband, AGP Hard Pipe set, HKS bov, plugs and wires, Scan Guage, AEM CAI, 30/30 Guage, BWoody MM, CC, Check Valve
Nelson is online now   Reply With Quote
Old 05-14-2008, 03:44 PM   #9 (permalink)
Member Number: 9221
You can get toys on a non toys PCM. N2MB sells toy kits for the non toy S2 PCMs
GO FAST PARTS
Stage 1
FM E1 turbo
FM WGA
Dtec FC
AGP returnline
PTP 55mm TB
PTP check valve
ED hardpipes w/ HKS BOV
Maddog STS 72%
AGP motor mounts
Zeitronix ZT2 wideband
NGK v power plugs .040
8.5 MSD wires
Needswings DP (no cat)
Quickwhips direct fit FMIC
180 thermostat
Bwoody H-brace combo
Bwoody Trans mount
AnotherNeon is offline   Reply With Quote
Old 05-14-2008, 08:54 PM   #10 (permalink)
SRT SVT's Avatar
Member Number: 28986
from my understanding the toys kit from n2mb only works with s2 with toys pcm and all stage 3 pcms. The stage 2 without toys pcm do not have the extra connector needed for the toys.
SRT SVT is offline   Reply With Quote
Old 05-15-2008, 12:15 AM   #11 (permalink)
Nvbby's Avatar
Thank you all. gonna look into everything that was said. i appreciate the generosity.
Old 05-15-2008, 02:17 AM   #12 (permalink)
Nelson's Avatar
More noobs need to be like this!!
Old 05-15-2008, 02:40 PM   #13 (permalink)
BoostinAMopar's Avatar
Member Number: 55767
Stock PCM, Forward Motion WGA, AIS BFMIC w/ modified stock crash bar, BWoody solid motor/trans. mount, AGP CAI/Oil Catch Can/LHP, PTP check valve, ED UHP w/ Greddy Type-S, Apexi Turbo Timer, Darksyde Powder work.
Yet to come (when I get the money )....
Wideband, Scan Gauge, Maxxfab SEE w/ Maxxfab o2 housing, S3R & A CLUTCH sway bars and coilovers, DONE
BoostinAMopar is offline   Reply With Quote
Old 05-15-2008, 03:34 PM   #14 (permalink)
SRTkid89's Avatar
Member Number: 53533
S2 w/ toys, AEM Wideband, SAFCII, 3" MPx tbe, AGP cai,AGP dogbone mm, FM wga, QW Bfmic,Stage 3 Fuel Rail, Fidanza sts, Goldline springs, Energy Suspension bushing kit
HID's and Yellow Fogs FTW!!
SRTkid89 is offline   Reply With Quote
Old 05-15-2008, 04:31 PM   #15 (permalink)
TurboMoparGod's Avatar
Member Number: 33697
Trader Rating: (29)
Huh? Don't think so bud.
www.ForwardMotioninc.com
Sales@ForwardMotioninc.com
Stock turbo 12.82@107mph DR's
E1 Turbo 12.48@115mph DR's slipping stock clutch
E3 Turbo and new FM clutch XX@XXX
TurboMoparGod is offline   Reply With Quote
