Old 10-20-2003, 01:31 PM   #46 (permalink)
SRToc Member
Pit Viper's Avatar
Member Number: 339
Trader Rating: (60)
Well, I have to until after work.
eVilcreations sold me a POS unfixable turbo.
Old 10-20-2003, 01:31 PM   #47 (permalink)
Member Number: 114
If that's the line I'm thinking about, it's the same as the pcv valve line in the sense that it is used to recirculate polluted air. On the inside of the airbox there is a piece of foam blocking the hole (to catch oil.) My foam square is pretty oily.
-Sam
-SamelCamel
Samel_Camel is offline   Reply With Quote
Old 10-20-2003, 01:59 PM   #48 (permalink)
cali's Avatar
Member Number: 159
Originally posted by mike_coleman_srt
that's nothing to brag about in fact that's downright embarrassing.
Come to Florida and do better.
Until then STFU!
someone is watching me
Old 10-20-2003, 02:04 PM   #49 (permalink)
cali's Avatar
Member Number: 159
Originally posted by Samel_Camel
Cali,
Question for you. I have a manual boost controller and the Mopar BOV. Where should everything be plugged in at for vacuum routing?
-Sam
You guys should try it my way, try it their way and decide for your self which is better.
I have my BOV routing the way it came from factory. I have stg1
Old 10-20-2003, 02:07 PM   #50 (permalink)
SRToc Member
Pit Viper's Avatar
Member Number: 339
Trader Rating: (60)
C'mon Cali, answer my question toooooo!
Old 10-20-2003, 02:13 PM   #51 (permalink)
cali's Avatar
Member Number: 159
Originally posted by Psi-Fi Motorsports
It is the first "T" right off the compressor next in line is the check valves. Turn your engine on and pull off that line then use your hand to open the throttle body and rev the engine. I bet you will feel boost.
Ah that hose....I got another story to tell about it.....
See the pic below? When I had my initial problems and the dealer rep replaced my entire vacuum harness, my line was connected as shown below.
My car was insane!! I lit up tires in 1st and second! Stock!
I took it back to them because I saw the bad routing, and due to the fact I was on the verge of lemon, had it documented.
They fixed that and 3 days later the car started overboosting....took it in, and they said No problem found, and the car was miraculously fixed.
Good info Psi--FI....never paid attention to where that sucker went.
Cali
NOTE: Look carefully at what is connected to the manifold, and what is on the airbox.
Old 10-20-2003, 02:14 PM   #52 (permalink)
cali's Avatar
Member Number: 159
What Dale didnt figure out the answer yet? U have got to be kidding me!!!
Ditch the green solenoid!
Old 10-20-2003, 02:43 PM   #53 (permalink)
aaronneon@RealTune's Avatar
Member Number: 623
Trader Rating: (379)
Default ha
you guys[not psi] are just figuring this out now?I have had my vacuum hoses similar to this for months.Now how am I supposed to keep wooping other srt cars that have more mods if u guys keep spillin the beans?Bah you guys suck.Hahah just kidding..I did this so long ago i forgot all about it.I was wondering why my buds car isnt movin like mine..we have pretty much the same stuff.Well thanks for he reminder..i will have to hook my dude up.
later,
aaron
ps..keep it up psi you guys friggin rock..
Look for 9s with a manual very soon!
10.62@133.8
10.64@136.7
CSRT4 In house! http://www.caliberforums.com/forums/...ead.php?t=5153
Old 10-20-2003, 03:01 PM   #54 (permalink)
cali's Avatar
Member Number: 159
aaron ,
u talking about the one goign to the airbox?
or in general?
Old 10-20-2003, 03:11 PM   #55 (permalink)
mike_coleman_srt's Avatar
Member Number: 1625
We did 12.30s with the stock BPV hooked up our way on DOT tires.
now that's something to brag about!!!
[live=mikecoleman23]mike coleman[/live]
Yeah and someones daughter is likely to have my dick in their mouth tonight. Am I supposed to feel bad about that?
mike_coleman_srt is offline   Reply With Quote
Old 10-20-2003, 03:14 PM   #56 (permalink)
Member Number: 1625
Until then STFU!
at 19psi with stage 1 and a wga I'd do much better. I can do 13.5 with a spring and an mbc. if you're gonna brag on someonelse's runs make sure they are worth bragging about otherwise you just look silly.
Old 10-20-2003, 03:19 PM   #57 (permalink)
Member Number: 623
Default yes
yes cali airbox and allround.Mike your times are nothing to brag about either so stop your beatchin
aaron
Old 10-20-2003, 03:25 PM   #58 (permalink)
Member Number: 623
Default yo
hay one more thing guys.Before you all get happy and go and reroute your lines..make sure you will be keeping stage one..we dont know if stage 2 ect. will like the new routing.
aaron
Old 10-20-2003, 03:32 PM   #59 (permalink)
Member Number: 1625
i'm not bitching. I can't compare with you aaronneon but i'm just saying cali was talking like 13.3 is impressive with those mods it's not. BTW pm me your set-up I'd like to be a loyal aaronneon follower.
Old 10-20-2003, 03:50 PM   #60 (permalink)
cali's Avatar
Member Number: 159
Not in florida darling. I'd be happy to pay your ticket down here for next august and you can come do better with a WG and STG1.
I wasnt braggin...point was ebing made that over 18PSI boost was not leakign via surge valve.
Aaron:
Dont see any reason why stage 2 wont like it?
This is a interesting find! It was in my hands, in front my eyes! and I never realised......me is a dumbass...hehe
