Old 03-31-2008, 05:27 PM   #421 (permalink)
TrueBegginer's Avatar
Member Number: 61902
im not sure exactly how to post so im reply n to this... i recently bought a stage 1 and i called a local dealership and the said it may not be able to flash... is that true? they said it may or may not work... it is used
TrueBegginer is offline   Reply With Quote
Old 04-03-2008, 05:58 AM   #422 (permalink)
datadave49's Avatar
Member Number: 39365
Hey Hey
This is true if you got a pcm that does not work right is what I think they mean
Dave
Have Fun
2000 neon with a 05 SRT drive train with a S1 Pcm More to come
http://www.cardomain.com/ride/2351649
http://datadave49.tripod.com/datadavenewtoy
datadave49 is offline   Reply With Quote
Old 04-03-2008, 07:23 AM   #423 (permalink)
Miguelangelo's Avatar
Member Number: 23664
contact flight systems, they can doit
STOP STREET RACING
Quote: Originally Posted by 757 BMW 525i View Post
....when you dont know how to do a DIY, dont do it yourself!
Miguelangelo is offline   Reply With Quote
Old 05-10-2008, 03:10 AM   #424 (permalink)
Xx_R/T_xX's Avatar
Member Number: 18749
i installed my agp wga today(got it for free)..and im spiking and holding 16psi 2-5 gears...stock turbo maxes out at 19psi and stock fuel system makes out at 16psi,i have a s1 ecu and danm does the car haul ass now...
Xx_R/T_xX is online now   Reply With Quote
Old 05-23-2008, 09:59 PM   #425 (permalink)
04RedSrt-4's Avatar
Member Number: 56795
Trader Rating: (47)
ANybody know how to install a Stage1 ECU, with A Kinetic Wastegate?PM ME please.
04RedSrt-4 is offline   Reply With Quote
Old 06-01-2008, 11:55 AM   #426 (permalink)
Member Number: 64268
Default does any one have the correct vacuum diagram for a boost controller
Quote: Originally Posted by Psi-Fi Motorsports View Post
This is how we rerouted our vacuume lines with the Mopar Stg1 setup. You will notice that we only have the TIP solenoid hooked up. The lines going to the other solenoids I removed all together. To be honest I an pretty sure that we don't even need the Tip vacuume lines either.
The idea here is that I removed all the unneccesary vaccume lines that are no longer in use with the Mopar Stg1/MBC setup.
:edited for better viewing:
does anyone have vacuum diagrams, pictures correct ones please
onefastsrt is offline   Reply With Quote
Old 06-01-2008, 12:02 PM   #427 (permalink)
could you repost that diagram
Old 06-01-2008, 02:45 PM   #428 (permalink)
jedaj's Avatar
Member Number: 47396
its e few pages back...
stg1, agp wga, 3'' turboback, MPx FMIC, greddy ebc, AEM UEGO and more
read here:
http://www.cardomain.com/ride/2624476
jedaj is offline   Reply With Quote
Old 06-09-2008, 07:28 PM   #429 (permalink)
trueSRT4's Avatar
Member Number: 61340
Ok so this looks nothing like the way that mine are hooked up so I think I need to adjust. I have the AGP WG, HKS SSQ, stage 1, and an K&N typhoon intake...Does anyone know where the normal/stock setup diagram for stage 1 could be found??? I have looked but I can't really seem to find one.
-Truesrt4
trueSRT4 is offline   Reply With Quote
Old 06-10-2008, 04:39 PM   #430 (permalink)
jedaj's Avatar
-Truesrt4
If you have AGP WG and HKS SSQV you cant use the stock setup. I have the same mods as you and im running this setup. When I stayed conntected to the PCM I got so much PTB and it was pissing me off. So be a man and redo it, and you can remove those shitty colorful vac lines... I just left the TIP lines, thats red and yellow. S1 doesnt use TIP anyway so its your choice
Old 06-11-2008, 05:28 PM   #431 (permalink)
JRstxsrt4's Avatar
Member Number: 48119
Still have questions on Vac line setups? Look here:
this should be easier to figure out
JRstxsrt4 is offline   Reply With Quote
Old 07-18-2008, 06:18 AM   #432 (permalink)
Member Number: 65633
Default not boosting right!!!
hey guys i have a 2004 srt. ive got an aem cai, 3" dp with 3" catback, hks hard piping and the ssq bov from hks. my problem is that i dont build boost like my last srt. with the old one i would boost 15psi no matter what gear or rpm range. the new car in first gear i max out at 5psi then 2nd through 5th it jumps to 7psi and creeps up to 10psi. as i build rpms after its hit its peak boost it starts to drop back down to 7psi. every once in awhile it will spike to 14 psi. very frustrating for me and any input would be appreciated, thank you!!!
GODS#1 is offline   Reply With Quote
Old 07-23-2008, 09:12 AM   #433 (permalink)
YoNkErZsRt4's Avatar
Member Number: 43878
mostlikely you have a boost leak....check all your vac lines and do a boost leak test on your car...go to the boostleak threads you should find out sum stuff there.
YoNkErZsRt4 is offline   Reply With Quote
Old 07-29-2008, 07:28 PM   #434 (permalink)
Member Number: 34454
I was just wondering where the boost guage comes into this circuit? Also what color line does it use and where does it come through the firewall?
Thanks,
Roman
04 SRT4 12.977@104.64, 1.88 60'........Stage 1, CAI,STS,WGA,DR's
99 CamaroSS M6 9.87@139.5 all motor...... A few bolt ons
romanss is offline   Reply With Quote
Old 09-06-2008, 02:26 PM   #435 (permalink)
usmc pitbull's Avatar
Member Number: 67259
here is my prob i am at 9lbs wot, i have a few pix up. one is my break booster and i capped off the center piece that i think goes to the ac and heating thermostat or somthing, the bih hose goes to the manifold and the small one to my boost guage. the next pic is a hose i capped off cuz i didnt know where it was connected to the third is another view of it. From the pix do i have wrong vac hooked up and i dont have nething from my break booster hooked up to chek valves im confused and could use some help
usmc pitbull is offline   Reply With Quote
