Old 02-27-2007, 04:17 PM   #391 (permalink)
xtrm4's Avatar
Member Number: 38360
Quote: Originally Posted by mxpimp18
Does this work for the 05?
Quote: Originally Posted by dansrt4
WAAAA LAAAAAA poof the diagram
Is this the diagram for 04' Stage1 or just in general? Getting ready to buy ptp wga and aaronneon mbc.
04' Dodge SRT4- modded 93' Ford Cobra- stock 94' Honda Civic- modded
PIZZA BOY
thats nothing, i floored it one day and the boost pegged infinity and i actually traveled a full week into the future...
xtrm4 is offline   Reply With Quote
Old 03-03-2007, 02:48 PM   #392 (permalink)
you4ic's Avatar
Member Number: 28235
can someone make this a bit easier for every1 and just post up the diagram for stage1 aftermarket wga and stock bov........updated...
and maybe the updated stage1 w/aftermarket wga and bov with bop
thx
just asking cause I thought I had the right set-up, now there are check valves....
I am a framing genius
you4ic is offline   Reply With Quote
Old 03-16-2007, 07:08 PM   #393 (permalink)
YoNkErZsRt4's Avatar
Member Number: 43878
tell me how to get rid of this ptb sh!t....i have s1 , agp wga ,mbc,hks bov..ect. any help thanx.do i have to cap the redline or poke holes in the whiteline...lol...new turbo is out of the question...lmao(bigger compressor wheel)...i need a better job to keep this car happy...lol
p.s i have no codes from ptb ish...
YoNkErZsRt4 is offline   Reply With Quote
Old 03-17-2007, 12:32 AM   #394 (permalink)
JesseL's Avatar
Member Number: 51882
ok, I can't be this intoxicated... I really don't see a diagram anywhere....
JesseL is offline   Reply With Quote
Old 05-21-2007, 02:51 PM   #395 (permalink)
Member Number: 54190
can i get rid of my vacuum lines with stock ecu
dodge srt4 driver is offline   Reply With Quote
Old 05-21-2007, 07:03 PM   #396 (permalink)
letxen3's Avatar
Member Number: 41680
yes but leave the soinolds connected or you will get an engine light.
James | 2004 PT GT 5spd
letxen3 is offline   Reply With Quote
Old 05-22-2007, 02:28 PM   #397 (permalink)
removed vacuum lines like on diagram and only pushing 8lbs of boost with the wga in or out. i have stage 2 wga, fmic,cai cant figure it out any help would be nice and it is a 05
Old 05-22-2007, 02:35 PM   #398 (permalink)
thats because the s2 wga needs the stock solinoids to boost....keep the black and green lines on......make sure you adjust the arm on the wga right. and check for boost leaks.
Old 05-22-2007, 07:44 PM   #399 (permalink)
i will try that and let u know what happends thanks
Old 09-05-2007, 11:23 AM   #400 (permalink)
JRstxsrt4's Avatar
Member Number: 48119
Quote: Originally Posted by aaronneon@RealTune
hay one more thing guys.Before you all get happy and go and reroute your lines..make sure you will be keeping stage one..we dont know if stage 2 ect. will like the new routing.
aaron
Have you figured out if this works on stage 2 yet? I want to try this on mine but i dont want to screw anything up. Ive got stage 2 and a MBC.
JRstxsrt4 is offline   Reply With Quote
Old 09-07-2007, 02:37 PM   #401 (permalink)
no it dont werk with stage2 you need pcm controlled boost....
Old 10-06-2007, 10:56 PM   #402 (permalink)
Member Number: 56963
can someone show me how to install ebc with aftermarket bov/agp wga.. w/ bop
skittleson3 is online now   Reply With Quote
Old 10-11-2007, 04:30 AM   #403 (permalink)
jedaj's Avatar
Member Number: 47396
Same what i wanted to ask. Right now my setup looks like this Vac setup for HKS BOV & BC and i didnt change it because i didnt get any problems. But mine ebc is off and i wanted to use it, and change to stg1. Should I then change my vac lines like Fuzzy said in post #5? Or I can stay connected to the stock selonoid/ BTW I tried to tighten the WGA and the boost levels didnt increase, is it because im connected to the selonoid??
stg1, agp wga, 3'' turboback, MPx FMIC, greddy ebc, AEM UEGO and more
read here:
http://www.cardomain.com/ride/2624476
jedaj is offline   Reply With Quote
Old 10-13-2007, 07:04 PM   #404 (permalink)
Member Number: 38097
I cant see the pic of the line set up for some reason. Any chance you could pm this to me or repost it. Thanks
I found it but another question ...what is connected to the bottom connector on the TIP solenoid is it just capped off?
busce3590 is offline   Reply With Quote
Old 10-16-2007, 06:30 AM   #405 (permalink)
jedaj's Avatar
it looks like this, its capped off, or cut...
http://img144.imageshack.us/img144/7...1016001ll5.jpg
