Old 10-04-2006, 02:35 PM   #376 (permalink)
letxen3's Avatar
Member Number: 41680
what does BPV mean?
letxen3 is offline   Reply With Quote
Old 10-06-2006, 09:06 AM   #377 (permalink)
04SRTMAN's Avatar
Member Number: 12178
Quote: Originally Posted by letxen3
what does BPV mean?
(BPV) By Pass Valve
2004 Black SRT-4 SSTock!
2006 Green ZX10-R
04SRTMAN is offline   Reply With Quote
Old 10-07-2006, 02:07 PM   #378 (permalink)
Member Number: 35943
Default stock wga
can this vacuum reroute be done with the stock wga? or is it better to get an adjustable wga first?
thanks
05 Flame Red SRT-4
mopar stage 1
msd coil & wires
mopar STS
AGP Dog Bones
JMB Catch Can
HKS turbo timer
Turbo XS HPBC
Injen SRI-Coated Mirror Red by JMB Perf.
JMB Hard pipes with HKS bov
Aftermarket WGA-coming soon
flameredsrt05 is offline   Reply With Quote
Old 10-10-2006, 10:46 AM   #379 (permalink)
04SRTMAN's Avatar
Aftermarket Wasgate
Old 10-15-2006, 11:01 AM   #380 (permalink)
Fierce Ragnarok's Avatar
Member Number: 45562
Thanks for the diagram...
god i hate idiots.
Fierce Ragnarok is offline   Reply With Quote
Old 10-20-2006, 04:04 PM   #381 (permalink)
chancek06's Avatar
Member Number: 47324
I nedd the solenoid vacum diagram anyone have it
Chance Kirkdorffer
chancek06 is offline   Reply With Quote
Old 10-20-2006, 04:08 PM   #382 (permalink)
chancek06's Avatar
I just bought my srt and the vacum hoses were all off is the what # solenoid is the tip solenoid
Old 10-20-2006, 04:59 PM   #383 (permalink)
chancek06's Avatar
Does anyone just have the stock 05 srt-4 solenoid diagram
Old 10-20-2006, 10:55 PM   #384 (permalink)
Member Number: 42752
Default vacuum drawing
Quote: Originally Posted by Psi-Fi Motorsports
This is how we rerouted our vacuume lines with the Mopar Stg1 setup. You will notice that we only have the TIP solenoid hooked up. The lines going to the other solenoids I removed all together. To be honest I an pretty sure that we don't even need the Tip vacuume lines either.
The idea here is that I removed all the unneccesary vaccume lines that are no longer in use with the Mopar Stg1/MBC setup.
:edited for better viewing:
I can't see your drawing of the Vacuum please forward a link
Tnaks
Chris
2003 SRT-4
1997 Jeep Wrangler with 99 LS1 5.7L auto, 7" long arm lift, ARB front locker, Full Detroit 8.8" rear and muck more.
2005 Nissan 350 Z Roadster.
2 seat sandrail with Suzuki Hayabusa 1300
Jeeper90 is offline   Reply With Quote
Old 10-20-2006, 11:31 PM   #385 (permalink)
letxen3's Avatar
theres a diagram on under your hood you cant miss it.
Old 11-25-2006, 08:37 PM   #386 (permalink)
SkittlePower's Avatar
Member Number: 37724
Trader Rating: (24)
stock formation is solenoid #1 is the tip sensor solenoid which the red line from the cold ic pipe connects uptop then the white line to the tip sensor goes in the middle and a bleed at the bottom. solenoid#2 is the boost solenoid which the green line from the back of the turbo goes uptop then the black line to the wga goes in the middle with a bleed at the bottom. solenoid #3 is the bov solenoid which the blue line comming from the bottom of the turbo goes uptop then the pink line to the bov goes in the middle and the black line going to the clusterfuck at the bottom of the turbo goes at the bottom.
for the diagram above: from: srtgallado
green line from back of turbo-> mbc in
mbc out=black line to wga
*remove green and black lines from boost solenoid and dont disconnect the plug on the solenoid cuz ull throw a code*
*keep the tip solenoid the way it is or just remove the vac lines and do not disconnect the plug on the solenoid and dont disconnect the tip sensor either(you will throw a high voltage code) either way it will do the same thing because the tip sensor is not needed for stage kits. stock is a different story and you will have to keep the tip*
*add a "t" fitting in the brake booster line and run a line from that "t" to ur bpv or bov and remove the vac lines from the stock bpv/bov solenoid, again dont disconnect the plug from the solenoid because you will throw a code.*
SkittlePower is offline   Reply With Quote
Old 11-29-2006, 09:05 AM   #387 (permalink)
Member Number: 21385
Please direct us to the diagram for variuos Mods and colors please. Too many threads on this now...
Thanks
Batavia Booster SRT4 is offline   Reply With Quote
Old 01-29-2007, 09:11 PM   #388 (permalink)
mxpimp18's Avatar
Member Number: 3923
Does this work for the 05?
Quote: Originally Posted by dansrt4
WAAAA LAAAAAA poof the diagram
05 ACR SRT-4 12.21 @ 115.8 SST V2
mxpimp18 is offline   Reply With Quote
Old 02-21-2007, 09:37 PM   #389 (permalink)
Member Number: 37033
I just installed my AGP wga tonight and I have stage 1. When I rerouted the vac. lines I took the black one off as the directions said, and just used the green line straight from the turbo to the wga. The direction said to remove the black and green lines but then to run a line from the turbo directly to the wga (if no MBC)...so I just wanted to make sure its alright to use the green line.!
Any other tips or anything is appreciated!
2005 Orange Srt-4
Mopar STS- Mopar Stage1- Mopar Riceplate- AEM SRI- AGP WGA- AGP MM- AGP Tranny Mount- NGK IX's- MSD Wires- Tien S-Techs- MAxxFab 3in O2- Needswings v5 e-cutout- Tokico Illuminas- MPx BFMIC- Kyowa 316's soon to be wrapped in Eagle F1s!
KiNgPiN is offline   Reply With Quote
Old 02-23-2007, 10:24 PM   #390 (permalink)
ACeR's Avatar
Member Number: 49468
Default Picture
I can't view this picture. Not sure why.
ACeR is offline   Reply With Quote
