Old 10-18-2003, 02:55 PM   #1 (permalink)
Member Number: 718
Default Stg1 Vacuume line diagram
This is how we rerouted our vacuume lines with the Mopar Stg1 setup. You will notice that we only have the TIP solenoid hooked up. The lines going to the other solenoids I removed all together. To be honest I an pretty sure that we don't even need the Tip vacuume lines either.
The idea here is that I removed all the unneccesary vaccume lines that are no longer in use with the Mopar Stg1/MBC setup.
:edited for better viewing:
Psi-Fi Motorsports is offline   Reply With Quote
Old 10-18-2003, 05:01 PM   #2 (permalink)
Exhaust Depot's Avatar
Member Number: 143
Trader Rating: (97)
Nice pic. THis should be posted in the FAQ section. How to hook up a MBC.
I agree with you on the TIP deal.
Exhaust Depot is offline   Reply With Quote
Old 10-19-2003, 09:01 AM   #3 (permalink)
cali's Avatar
Member Number: 159
Trader Rating: (15)
One suggestion, you may want to try the Surge Valve source from the stock setup.
I have tired it your way, and it blows off all day. Using it via stock solenoid, it blows off very fast! and seals right back up!
someone is watching me
Old 10-19-2003, 09:02 AM   #4 (permalink)
Member Number: 3141
If we don't have a BC, but have S1 and a WGA, can we use this setup but attach the line directly to the WGA (just delete the BC from the diagram) ??
Thanks
Don
Garrett: GT30BB Turbo 700382-5012 [ 56/84 Trim , .63ar , 4" Inlet]
SFP/TCC: Tubular Mainfold
ED: 3" Exhaust
AGP: Intercooler
Tial: .38 Wastegate
Custom 4" Air Intake w/K&N Air Filter
Innovative MotorSports: A/F Ratio Meter
RAGE: MM-Full, RFPR System
Mopar: Stage-1, STS
GReddy: Profec E-01 / E-Manage / Type-S BOV
Summit: 24" resonator
Golden Eagle: Vacuum Distribution Block
Denso Iridium ITV22 w/Yellow Wires
PattiDon2000 is offline   Reply With Quote
Old 10-19-2003, 09:09 AM   #5 (permalink)
drolander's Avatar
Member Number: 247
Thanks for the drawing. I read that Stage 1 doesn't use the TIP sensor?
drolander is offline   Reply With Quote
Old 10-19-2003, 09:28 AM   #6 (permalink)
NeonDan's Avatar
Member Number: 138
Trader Rating: (61)
TIP or Downstream o2
727-512-9684 Need SRT4 help? Im a call away
Built by experts. Tested in the real world. ~ Mopar
Dont let the fact i drive Neons deter you, I have 8+yrs neon and 5yrs SRT4 experience.....god bless!
Old 10-19-2003, 11:05 AM   #7 (permalink)
Member Number: 3141
If S1 doesn't use the downstream O2, can I replace it with the Auto Meter 2244 that I need to install for my A/F guage?
Is the downstream O2 the one in the CAT ??
Thanks
Don
Old 10-19-2003, 06:15 PM   #8 (permalink)
Member Number: 718
You do it via the stock solenoid it will also blow off to control boost. This way allows you to run more boost.
Old 10-19-2003, 06:18 PM   #9 (permalink)
cali's Avatar
Member Number: 159
Trader Rating: (15)
Have you tried?
I too used to think your way.....try it and find out. I know it works better the stock way with Stage 1. I know you gusy have stage one.
Old 10-19-2003, 07:14 PM   #10 (permalink)
abubamsry's Avatar
Member Number: 488
Now this is with the Mopar or Stock BOV correct?
If so, how does the BOV know when to release?
Remember Hitler was a Catholic, not an Atheist.
Muslim is a peaceful religion.
And the FSM promises a Beer Volcano and a Stripper Factory!
abubamsry is offline   Reply With Quote
Old 10-19-2003, 09:33 PM   #11 (permalink)
Member Number: 718
Yes we have tried with the BPV solenoid hooked up and the ECU would bleed off boost above 17 psi. The BPV still works as it should with it hooked up this way. You have a boost reference on one side of the valve and a boost referece from after the throttle body. When the throttle body closes then you will have a heavy vacuume on one side of the valve and boost on the other. This will force the valve open and bypass the pressure. Obviously this meathod works for us, given the performance we have shown with the car. If we had slow response and boost leaks then we wouldn't run the times that we have. All of this was with the stock BPV.
Old 10-19-2003, 10:11 PM   #12 (permalink)
bubba's Avatar
Member Number: 469
nice. but i have a few questions:
1. is stg1 like stock where the boost solenoid needs to see boost? (or did bypassing them like you did remedy that)
2. where does the line with the check valve go to the turbo? and which way does that particular check valve go? (obviously the brake booster needs the vacuum so it is self explanitory)
3. are you noticing timing being pulled?
4. do you need a guinnea pig for your piggyback in california?
my tombstone--
"hey, watch this!"
bubba is offline   Reply With Quote
Old 10-20-2003, 03:59 AM   #13 (permalink)
cali's Avatar
Member Number: 159
Trader Rating: (15)
You know what, you're right. You have a drag car, and the effects of the slow leak are nominal especially when youre WOT most of the time.
For a daily driver, it is better using the stock lines.
Edit: And several of us (Maybe 5?) dynoed 2 weeks ago with stock routing over 19PSI without any leaking.
Old 10-20-2003, 06:10 AM   #14 (permalink)
Member Number: 180
hmm, so enough people finally showed you evidence that stock is better for the bov one of the few, the proud, the informed
NeonWaSp is offline   Reply With Quote
Old 10-20-2003, 06:29 AM   #15 (permalink)
turbobozz's Avatar
Member Number: 1541
using the stock line works fine for me (w/ just a new WGA).
stock surge blows off real fast.
random aside - anyone know where to get a replacement for one of the bolts that hold the WGA to the turbo? mine fell into the brace underneath/behind the engine... can't get it out.
(don't worry I have it bolted on... just not with the correct bolt)
turbobozz is offline   Reply With Quote
