Old 03-31-2008, 05:27 PM   #421 (permalink)
TrueBegginer's Avatar
Member Number: 61902
im not sure exactly how to post so im reply n to this... i recently bought a stage 1 and i called a local dealership and the said it may not be able to flash... is that true? they said it may or may not work... it is used
TrueBegginer is offline   Reply With Quote
Old 04-03-2008, 05:58 AM   #422 (permalink)
datadave49's Avatar
Member Number: 39365
Hey Hey
This is true if you got a pcm that does not work right is what I think they mean
Dave
Have Fun
2000 neon with a 05 SRT drive train with a S1 Pcm More to come
http://www.cardomain.com/ride/2351649
http://datadave49.tripod.com/datadavenewtoy
datadave49 is offline   Reply With Quote
Old 04-03-2008, 07:23 AM   #423 (permalink)
Miguelangelo's Avatar
Member Number: 23664
contact flight systems, they can doit
RIP Uncle Felix
Miguelangelo is offline   Reply With Quote
Old 05-10-2008, 03:10 AM   #424 (permalink)
Xx_R/T_xX's Avatar
Member Number: 18749
i installed my agp wga today(got it for free)..and im spiking and holding 16psi 2-5 gears...stock turbo maxes out at 19psi and stock fuel system makes out at 16psi,i have a s1 ecu and danm does the car haul ass now...
Xx_R/T_xX is online now   Reply With Quote
Old 05-23-2008, 09:59 PM   #425 (permalink)
04RedSrt-4's Avatar
Member Number: 56795
Trader Rating: (18)
ANybody know how to install a Stage1 ECU, with A Kinetic Wastegate?PM ME please.
04RedSrt-4 is offline   Reply With Quote
Old 06-01-2008, 11:55 AM   #426 (permalink)
Member Number: 64268
Default does any one have the correct vacuum diagram for a boost controller
Quote: Originally Posted by Psi-Fi Motorsports View Post
This is how we rerouted our vacuume lines with the Mopar Stg1 setup. You will notice that we only have the TIP solenoid hooked up. The lines going to the other solenoids I removed all together. To be honest I an pretty sure that we don't even need the Tip vacuume lines either.
The idea here is that I removed all the unneccesary vaccume lines that are no longer in use with the Mopar Stg1/MBC setup.
:edited for better viewing:
does anyone have vacuum diagrams, pictures correct ones please
onefastsrt is offline   Reply With Quote
Old 06-01-2008, 12:02 PM   #427 (permalink)
could you repost that diagram
Old 06-01-2008, 02:45 PM   #428 (permalink)
jedaj's Avatar
Member Number: 47396
its e few pages back...
+ some more mods = 260 bhp / 261 torque
jedaj is offline   Reply With Quote
Old 06-09-2008, 07:28 PM   #429 (permalink)
trueSRT4's Avatar
Member Number: 61340
Ok so this looks nothing like the way that mine are hooked up so I think I need to adjust. I have the AGP WG, HKS SSQ, stage 1, and an K&N typhoon intake...Does anyone know where the normal/stock setup diagram for stage 1 could be found??? I have looked but I can't really seem to find one.
-Truesrt4
trueSRT4 is offline   Reply With Quote
Old 06-10-2008, 04:39 PM   #430 (permalink)
jedaj's Avatar
-Truesrt4
If you have AGP WG and HKS SSQV you cant use the stock setup. I have the same mods as you and im running this setup. When I stayed conntected to the PCM I got so much PTB and it was pissing me off. So be a man and redo it, and you can remove those shitty colorful vac lines... I just left the TIP lines, thats red and yellow. S1 doesnt use TIP anyway so its your choice
Old 06-11-2008, 05:28 PM   #431 (permalink)
JRstxsrt4's Avatar
Member Number: 48119
Still have questions on Vac line setups? Look here:
this should be easier to figure out
JRstxsrt4 is offline   Reply With Quote
Page generated in 0.25843 seconds with 11 queries
