Stage 3 now only 306 HP 329 tqr - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 09-28-2012, 02:47 PM   #1 (permalink)
triangles's Avatar
Member Number: 80981
Default Stage 3 now only 306 HP 329 tqr
Just had it dynoed. On a dynojet. So disappointed I only made 306.
Any ideas something I am missing it held at 21 psi all the to red line. On 91 gas?
05 flame red
bw Stage 3 47lb 20g By Mole'
daily driven
E85
triangles is offline   Reply With Quote
Old 09-28-2012, 02:50 PM   #2 (permalink)
Zenkat's Avatar
Member Number: 10522
Yeah, you're on 91 and low boost/timing. Thats actually pretty normal. Get a 2nd tune for e85, another 4-5lbs of boost, more timing, and you'll probably see about 60-70whp more.
11.21@127.88
Zenkat is online now   Reply With Quote
Old 09-28-2012, 03:36 PM   #3 (permalink)
triangles's Avatar
Just did one last run 320.08 HP and 330.07 got a print out. Car was at 135 in 4th gear
05 flame red
daily driven
E85
Old 09-28-2012, 03:38 PM   #4 (permalink)
triangles's Avatar
Pic of the 4 runs. first set was 3rd gear it was spinning tires whole way
05 flame red
daily driven
E85
Old 09-28-2012, 03:54 PM   #5 (permalink)
Member Number: 52541
Seems about right for 91oct. Did you happen to take a log of the car during the dyno pulls? Like Zenkat said you cant expect to have much timing on pump gas. Also where was your AF ratio?
The type of dyno impacts your numbers alot too.
2004 Black Srt4 -
12.6 @ 123mph - 2.1 60'
dabezt1 is offline   Reply With Quote
Old 09-28-2012, 03:55 PM   #6 (permalink)
Zenkat's Avatar
Dont put so much emphasis on tiny number changes. Doesnt look like smoothing is turned on which can inflate your peak number. Bottomline, you need more octane, more boost, more timing. Then your car will impress you.
11.21@127.88
Old 09-28-2012, 04:03 PM   #7 (permalink)
SRTFORUM Moderator
Advans's Avatar
Member Number: 12791
What's A/F's like?
Advans is offline   Reply With Quote
Old 09-28-2012, 04:11 PM   #8 (permalink)
triangles's Avatar
No I'm not good with the loging yet still trying to learn it. My air fuel was 11.5.-11.6 at redline the shop owner said the car has an extream amount of growth to play with as far as tunning goes. The dyno was a dynojet 4800 with 8000 lbs rollers.
The shop is just for Honda's and acuras he said he will start with my car on performance upgrades. Hoping he will give me a good deal maybe even start getting in some races
05 flame red
daily driven
E85
Old 09-28-2012, 04:13 PM   #9 (permalink)
Zenkat's Avatar
Duuuuuuude. Start listening to what people in this forum are trying to say to you before you go and waste a shitload of money on a 'honda' tuner.
You have a tune from Duster dont you? Talk to him more, ask him advice on your situation. You seem to have a lot to learn.
11.21@127.88
Old 09-28-2012, 04:48 PM   #10 (permalink)
triangles's Avatar
Yea I know I have alot to learn just wish I had someone infront of me to talk to ill email duster right now
05 flame red
daily driven
E85
Old 09-28-2012, 04:54 PM   #11 (permalink)
comatoast's Avatar
Member Number: 85196
I had a thread like this too.. Disappointed in #s, on the same boost level.. Mine was 387/421 on a Mustang, but yet trap pretty high.. i would upgrade the fuel system and run e85 if I were you .. Solved alot of issues with pump gas
Turbo / TB - AGP Zeta 3.0 / 28 psi , AGP bfmic, Boomba 70mm tb Engine - Wiseco 8.8:1 pistons .020 over , eagle h-beam rods , king main and rod bearings , DCR crank strap kit, Head - FnF race ported exh ports , +2mm rev exh valves , BC springs and Ti retianers , BC stage 4 cams (280*s) , Boomba cam gears,
Fuel - , 900cc fic inj , -6an feed and return lines , fuel pump rewire , bottle neck fix , Bosch 044 intank , aeromotive rrfpr , E85..
comatoast is offline   Reply With Quote
Old 09-28-2012, 04:57 PM   #12 (permalink)
comatoast's Avatar
Oh.. He knows his shit!!!!!
Old 09-28-2012, 05:35 PM   #13 (permalink)
triangles's Avatar
Car accelerates fast and is quick I know there more I can going to put e85 with my base tune tonight and try it out see How I like it
05 flame red
daily driven
E85
Old 09-28-2012, 05:49 PM   #14 (permalink)
Rhunter's Avatar
Member Number: 36794
- You cannot just drop e85 in the tank and hope to see gigantic gains. If you do that would mean you were having knock issues and now you are on e85 they are gone.
- Did you say they dyno'd the car in 3rd? those numbers are as useless as tits on a hog. Dyno in 4th for something closer to what you will use on the streets.
Nunca Levanta!
EL RALFO RACING.COM
"A Lotta turbo, Small motor, and a GO pedal!!!"
Old 09-28-2012, 06:02 PM   #15 (permalink)
mole''s Avatar
Member Number: 17477
I did 294hp and 297tq with a 19psi spike on cali 91 with my stock s3. Car was mostly stock. No tune or tuner on the car. You were there for this dyno day Ralph @ ST.
DCR spiced and Tuned by the Mad Scientist team
Jay@N2MB and Nigel@BST (turbo666)
Mole' (STOCK TURBO) 16g BWS setup #s
380hp+ and 444tq+
11.7@122
1.71 60ft
PM/email me for all your 16g/18g/20g BWS setup and DCR needs...... Darrell Cox Racing on facebook, 1-517-369-9636 10am-5pm est webstore... DCRSRT.com. email me at mole79@aol.com .
