Old 11-19-2008, 05:23 PM   #1 (permalink)
Member Number: 66771
Default Stage 2 injec. or Return line
Ok im running the stock turbo and i plan on getting a 255 walbro fuel pump and im going to get a diablo very soon. I know im needing a fuel mod. What is the better route? Get the return line, because i can use it later on if I go big turbo, or since idk when that will be,or if ever, get stage 2 injectors? Or with the return line, are the stage 1 injectors plenty enough for the stock turbo's?
pirate562007 is offline   Reply With Quote
Old 11-19-2008, 05:35 PM   #2 (permalink)
Member Number: 9221
Trader Rating: (19)
go with a returnline. returnline and S1 will be more then enough fuel for the stock turbo
GO FAST PARTS
Stock PCM
AGP 44# delta
Diablo predator
Dtec FC
FIC 625cc injectors
AGP returnline
PTP 55mm TB
PTP check valve
ED hardpipes w/ HKS BOV
Maddog STS 72%
AGP motor mounts
Zeitronix ZT2 wideband
Needswings DP (no cat)
180 thermostat
Bwoody H-brace combo
Bwoody Trans mount
AnotherNeon is offline   Reply With Quote
Old 11-19-2008, 05:39 PM   #3 (permalink)
NoisufnoC's Avatar
Member Number: 136
the nice part about running a return line is the fact that you an run lower fuel pressure at idle/while in vac and build pressure as you build boost. it helps with tuning on larger injectors with the stock or stage 1 pcm
stage 2 injectors would be easier to install, but you'll run much richer at idle (and all around if you dont tune for them) and probably see fuel economy suffer as well.
my vote is for the returnline.
HOWEVER...with the diablo you may be able to get a little more fuel out of the stock injectors and dial back fuel if you wen stage 2 injectors.
Keeping the tire companies in business...
...one WOT shift at a time™
|| Mod List Coming Soon ||
***Forum Rules***
Old 11-19-2008, 06:37 PM   #4 (permalink)
StageSRT4's Avatar
Member Number: 46216
Trader Rating: (102)
return line. S1 are plenty of fuel to max out a stock turbo.
246hp 13.2xx@115mph
www.chicagolandsrtclub.com
member #88
StageSRT4 is offline   Reply With Quote
Page generated in 0.12706 seconds with 13 queries
