Old 07-05-2007, 09:25 PM   #121 (permalink)
1LAPSRT's Avatar
Member Number: 38267
Trader Rating: (19)
Quote: Originally Posted by 7055
I don't understand how thats possible, I mean theres no boost in the crankcase or oil pan. Does it push past the piston rings or something?
Nope....it's the boost coming thru the lines from the Throttle Body and going to the PCV valve.
Old 07-11-2007, 12:57 PM   #122 (permalink)
Member Number: 52407
What is the pcv valve?
7055 is online now   Reply With Quote
Old 07-11-2007, 04:51 PM   #123 (permalink)
1LAPSRT's Avatar
Trader Rating: (19)
It's the thingy in the left side of the cover do-dad that is on top of the engine. It's got a black hose thing running to it from the siver whatsis where the air comes in.
Otherwise known as Positive Crankcase Ventilation valve. Boost blows oil out where it shouldn't.
Heading for a new track? Just want to improve your times at a track you already run?
Old 07-11-2007, 11:32 PM   #124 (permalink)
I just did a but load of research on all the pcv stuff and from what I understand is the pcv system routes all the crankcase gasses from the crankcase (to prevent sludge) back into the throttle body. The valve regulates the amount of these gasses going into the intake and if the pressure in the intake becomes greater than that in the crankcase its supposed to close to keep pressure from building up in the crankcase right? Atleast thats what I read. So if the pcv valve is operating correctly please tell me why you would need a check valve?
Old 07-12-2007, 10:32 AM   #125 (permalink)
1LAPSRT's Avatar
Trader Rating: (19)
I have highlighted the area of your research that makes the Check Valve a good idea.
When I am pushing 26 lbs of boost through the intake, I don't want to rely on a $3.00 PCV valve to keep me from dumping all my oil out of the breather (I kinda need the oil on the inside).
Old 07-13-2007, 01:49 AM   #126 (permalink)
Member Number: 42189
Plus our pcv is a piece of junk!
13.9 @ 101.2mph...We'll get faster yet.
www.moparmen.ca
SilverBeast is offline   Reply With Quote
Old 07-17-2007, 11:29 PM   #127 (permalink)
Anybody tried putting some other kind of crankcase ventilation on there and getting rid of the pcv? Isn't pcv bad for engine life anyway? Just wondering, I Know it would probably be illegal because of emmisions or something but same with alot of things on these cars.
And where do you get a checkvalve?
Old 07-18-2007, 07:50 AM   #128 (permalink)
1LAPSRT's Avatar
Trader Rating: (19)
http://www.pt-performance.com/showPr...1&cID=1&pID=13
Old 08-02-2007, 11:28 PM   #129 (permalink)
Member Number: 54051
How are connecting rod bolts insurance against a spun bearing? Isn't a lack of oil that would cause a spun bearing?
Bobsrt is offline   Reply With Quote
Old 08-23-2007, 07:07 AM   #130 (permalink)
akmrue's Avatar
Member Number: 46876
Trader Rating: (13)
Marked
PERFORMANCE
AEM SRI/MSD 8.5mm Wires/3'' Needswings DP/MPx 3'' o2/Maddog STS/180 T-Stat/MPx FMIC/PTP WGA 17/15/PTP Check Valve/Street MM Inserts/Greddy Type-S/NGK 4306's .35 Gap/AEM WB/Map Clamp
ALL PARTS ARE FOR SALE!!!!
DYNO 9/1/07:
248whp & 289wtq (15psi) MUSTANG DYNO
akmrue is offline   Reply With Quote
Old 11-11-2007, 09:32 PM   #131 (permalink)
Member Number: 59286
Thanks...good info, btw...any used nology wires and plugs? will they do more long term damage than short term good?
Quik_Silver is offline   Reply With Quote
Old 04-04-2008, 04:55 PM   #132 (permalink)
Wozzy's Avatar
Member Number: 45835
So I figured I'd post here to see what everyone thinks of this setup and maybe possible think of a better route to go, or anything really :P.
I really want to go with the 3" MPx dual exhaust but I'm kinda leary that it's going to be very loud, I can tolerate loud, but how loud are we talking? So that kinda why I'm leaning towards the Mopar 2.5".
  • MPx Intercooler
  • Injen Short Ram Intake
  • AGP Uppipe (B.O.P, HKS flange, HKS SSQV)
  • Granatelli spark plug wires
  • AGP Wastegate
  • Mopar Stage 1
  • MPx 3" o2 housing (Still deciding...maybe pair with the "Mopar Cat-delete kit, or just get the Mopar kit instead, opinions?)
  • Mopar 2.5" exhaust
  • Eibach Pro Kit springs
Not wanting to go too crazy, goal is to keep it in good working order, don't want to upgrade to a bigger turbo. Maybe give me a rough estimate of HP and if this is a good setup?
Thanks
Quote: Originally Posted by SRT_Maniac
Even when people get rear ended the wing servives. it is in fact designed by god!
Wozzy is offline   Reply With Quote
Old 05-14-2008, 12:04 PM   #133 (permalink)
xjoewhitex's Avatar
Member Number: 49136
Must you gap the NGK plugs?
xjoewhitex is offline   Reply With Quote
Old 05-15-2008, 06:37 AM   #134 (permalink)
Member Number: 59665
Its always good to check the gap on the plugs. You never know if there is a factory fault that caused the gap to be larger than it supposed to be.
bobczar is offline   Reply With Quote
Page generated in 0.27745 seconds with 11 queries
