Shifter issue - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 01-13-2013, 05:15 PM   #1 (permalink)
SRT-Diesel's Avatar
Member Number: 75019
Default Shifter issue
So got a DCR tubular manifold, been the biggest pita I might add.
Installed it and went to put the cables back on, but it wouldn't go into gear. So I bought new cables, a new hurst shifter, and it didn't change anything. I've tried the crossover adjustment and everything else.
http://www.youtube.com/watch?v=m3i8K3Zbyws
Any ideas?
SRT-Diesel is offline   Reply With Quote
Old 01-13-2013, 05:23 PM   #2 (permalink)
Fresh Meat Moderator
tunerlover3's Avatar
Member Number: 76568
Well it looks like your turbo is hitting the cables.
Call Darrell and see what he says. You may have to try and make a bracket to get the cables to shift over a little.
Diablo CMR tuner ~Dan~
310HP 436TQ
2004 Eblue Neon SRT4: E85 5558 Built motor
XXXHP XXXTQ
Old 01-13-2013, 05:29 PM   #3 (permalink)
SRT-Diesel's Avatar
Other people didn't have issues. Darrell didn't have any solutions. The only thing I can think of is I somehow bent something on that top plate on the tranny. But I have all billet selectors.
Old 01-13-2013, 05:42 PM   #4 (permalink)
yeah I would say that would be smart as a next move. Pull the top plate and inspect.
310HP 436TQ
XXXHP XXXTQ
Old 01-14-2013, 10:12 AM   #5 (permalink)
matman2492's Avatar
Member Number: 91147
it sounds like u might have pinched the cables in something, i did that when i put a new tranny in, caught the cable in the tranny case and was not happy when i had to nearly pull it to unlodge them.
matman2492 is offline   Reply With Quote
Old 01-14-2013, 10:50 AM   #6 (permalink)
SRT of the Month
BluFlame's Avatar
Member Number: 8399
You need two people. First, remove the cables and move your gear selectors on the top plate by hand. If nothing was wrong with your transmission before the install nothing should be wrong with it now. If all is fine re-install the cables and have someone work the shifter while you look for anything odd going on with the cables. I'm betting one of the cables popped out of it's socket and is not fully extending to shift into gears. It's hard to explain but you will see what I'm talking about if that is the issue.
ZHP Built & Enhanced - D3 Performance Engineering Tuned - FWD Performance Supported - Modern Performance Supported - Texas Forums Supported
Leave em' Blowin' N Da Breeze'
10.32@135
More to come...
BluFlame is offline   Reply With Quote
Old 01-14-2013, 06:56 PM   #7 (permalink)
SRT-Diesel's Avatar
They're brand new cables and new shifter. I did pry on the old cables when installing the manifold so thought I stretched them out but obviously not.
Old 01-15-2013, 04:42 PM   #8 (permalink)
Supporting Vendor
Maddog's Avatar
Member Number: 5932
Possible you pinched the cables inside their sheathing.
Also, do you have the shifter stops backed all the way out? If they're in too far, you won't be able to move the shifter far enough to engage the gears.
Maddog STS
Complete Short Throw Shifters sold here! 0% to 80% overall throw reduction! Custom work available!
PM or email Chuck@maddogsts.com for more information.
'05 Stone White - a few mods...
Maddog is offline   Reply With Quote
Old 01-15-2013, 07:21 PM   #9 (permalink)
SRT-Diesel's Avatar
Seems as though it was just the angle of the cables. Took one bolt off the top of the cable bracket on the tranny, turned it, and viola. No issues now, tightened the hell out of the one bolt so it seems as though I'm good to go.
