#1 (permalink) |
Member Number: 90137
So I tried installing the upper mount, and after 2 hrs of struggling it seems like the upper mount is to long. Would it be possible that I need to loosen the lower mount to get the upper mount to line up with the bracket coming off the motor? Any suggestions would be greatly appreciated, thanks Josh.
Dsp, Aem wideband, 3in dp, agp hard pipe, hks bov, scan gauge, booger bushings, b woody cc, injen cai, wally 255
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
![]() Join Date: Mar 2004
Member Number: 8941
I have the AGP mount, and I assume these are the same. Mine also appears to be about 1/10 of an inch off. I gorillas it in there. Not what I recommend.
Yes I tried flipping the silver colored mounting piece around. OP, how far is it off?
20G Stage 3 on E85: New data:384 hp 411 tq
"Maybe I should just stick to bolt-ons." -Hitler I don't really want to wrench anymore. I'd rather detail. |
#3 (permalink) |
![]() Join Date: Jan 2008
Member Number: 60962
take off the lower mount as well and habe the motor supported with a jack and a piece of wood then it should line up perfectly.... i tried putting my agp mounts like that also and top wouldnt line up for shit... had to remove bottom to line up.
"Duster360 knows his $hit"
#4 (permalink) |
Mines like a 1/4 inch off, makes sence now, so remove the bottom mount, support the engine with a jack and a piece of wood, this should allow me to move the engine just enough to get the top mount bolt in? Will the bottom go in smooth or will it be off just like the top one?
#5 (permalink) |
I tried to force it on there was no way, that's when the cuss words and tools started to fly lol I thought there was no way it should be this hard
#6 (permalink) |
![]() Join Date: Apr 2012
Member Number: 88759
so how did you get them on finally? im getting mine soon and want to avoid a headache. cause when shit doesnt go my way, things in my garage get broken. haha so how do they go in smoothly?
PTE 5431 on 26 psi tuned by Eric Raymond at Integrated Auto!
![]() 387/381 on pump |
#7 (permalink) |
I havent got them on yet, I'm going to try again tonight, I'm at work. But technically the top one should swap easy the bottom one is the one you need to jack up the motor to get it to line up. But in my case I'm assuming my stock top mount was worn out which allowed the engine to relax a bit, so now I need to take off the bottom mount and use a jack and wood to get the top one to fit
#8 (permalink) |
well i got both upper and lower mounts on, i had to remove the bottom mount and support the engine with a jack and pull the engine forward to get the upper mount bolt in, the bottom mount went in like butter, after getting them both done, went for a cruise and i hear a whining noise, is this normal? almost sounds like a little s/c
#9 (permalink) |
![]() Join Date: Nov 2005
Member Number: 35677
A whining noise? You should feel and notice a little minor vibration but a whining noise that was not present before is now audible? A few pix would be nice. |
#10 (permalink) |
yes i do hear/feel more vibrations, but i also hear a slight whining noise, ac is off, radio is off
#11 (permalink) |
![]() Join Date: Dec 2010
Member Number: 82185
I've never had a problem with the mounts, I just use a pry bar between the frame and metal bracket that covers the timing tensioner to move the engine until it lines up
As for the whining noise some timing belts make a little bit of a whine, as long as it isn't ridiculously loud it's nothing to worry about. You hear it with the solid mounts because all of the engine noise resonates through the frame now.
280whp 303wtq 16g bws, injen short ram, meth injection.
Stock intercooler, manifolds, o2 housing, wastegate, and motor. Best et: 13.4 Best trap: 107 |
#12 (permalink) |
so you think a little bit of a whine is normal its very hard to hear but i can hear it now and it was not there before
#13 (permalink) |
yeah its a very faint whine you can hear if all the windows and closed and radio off etc right?
Nothing to worry about
#14 (permalink) |
yup radio off everythings off it fluctuates with rpms, windows up once exhaust gets loud i cant hear just when im barley taking off in first i can hear a slight whine
#15 (permalink) |
it's true you feel vibrations with the newer solid/harder motor mounts, but a whining noise? How old is your timing belt?
If the noise is now audible due to the mounts, if the noise gets worse or strange, better determine where the noise is coming from. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
