Ok, Time to dish it out.
2004 Dodge SRT-4 (last owner was an idiot)
Engine
JE Forged Pistons 8.5:1 Compression, 88mm bore
Brian Crower H-Beam Connecting Rods
Stainless Steel Tubular Header
Ported, polished and ceramic coated intake manifold
CNC ported & polished cylinder Head
Custom cut Brian Crower camshafts
Garrett GT3071R Ball Bearing Turbocharger
Tial 44mm Wastegate
62mm Throttle Body
Held together by 90% ARP bolts and studs
Plumbed with 80% Steel braided hoses and tubes
Fuel and Exhaust
RC Engineering 1000 cc Fuel Injectors
Dual Walbro 255 LPH Fuel Pumps
OBX Fuel Rail and fuel pressure regulator
4 inch Block and Bar Intercooler
Custom Welded Mandrel-bent pipes:
Intake & Downpipe: (DEEPSTAGE Motorsports)
Exhaust System: (Bobs Muffler in Killeen, TX)
Quicktime Performance Electronic Exhaust cutout
Electronics and Management
AEM Engine Management System
Boost control w/ gauge and 3.5 bar MAP
Wideband Air/Fuel Ratio gauge w/Bosch O2 Sensor
MSD Ignition w/ 8.5mm wires and NGK plugs
Chemical injection
Direct port nitrous oxide system
FJO Racing progressive Mini Nitrous Controller
Cold Fusion 20 pound Nitrous Oxide Bottle
CO2 Intercooler Sprayer w/ 10 pound NX tank
Suspension & Driveline
TEIN Super Street Suspension
Vibrant Performance Strut Bars
Prothane motor mount inserts
AGP Hard Transaxle mount
Drive Shaft Shop level 3 racing axles
Spec Clutch, stage 3+ with billet flywheel
Enkei FD-05 wheels (7.5 X 18 inch)
Goodyear F1 AS 225-40Z-R18 Performance tires
Exterior
OEM Paint (Flame Red)
Performance ratings, no, it's not done yet.
