Old 11-08-2009, 11:24 AM   #1 (permalink)
Member Number: 37127
Default Question on spring mod
I did the spring mod today. My question is i used a light spring and was able to adjust it right the first time. I spike 15 psi and it drops to 14psi in 3rd gear. Will this be ok to run. I dont race the car as I will lose my job if im caught. I just was tired when i did hit the gas it wouldnt spike but rather hit 12psi and hold till redline. I did a boost leak check and was only leaking at the normal spots. The car is stock right now I have a new intercooler and exhaust to put on.
BLKJAXR/T is offline   Reply With Quote
Old 11-08-2009, 11:26 AM   #2 (permalink)
04SRT_08's Avatar
Member Number: 68190
it won't hurt anything, but i suggest just paying the money and getting an agp wga. theres used ones for under 100$ and you shouldn't have any boost leaks
'04 SILVER NSRT-4
3" B&B TBE(sold), AGP wga, AEM sri, Crane-Cam plug wires, Stage 1, turboXS rfl on ebay pipe, Boomba mm's, JMB catch can
50 Trim
04SRT_08 is offline   Reply With Quote
Old 11-08-2009, 11:44 AM   #3 (permalink)
I was just saying the leaks are the normal ones like in the t/b.
Old 11-08-2009, 11:48 AM   #4 (permalink)
04SRT_08's Avatar
well honestly im sure buncha people do the spring mod, but its so much easier to get an adj. wga.
Old 11-08-2009, 11:51 AM   #5 (permalink)
edogg23's Avatar
Member Number: 601
The only drawback to the spring mod is that you will have to reset your ecu every week or so because it will eventually lower your boost back down.
Flame Red 04 srt-4 13.4 @ 105 MPH
[live]edogg23[/live]
edogg23 is offline   Reply With Quote
Old 11-08-2009, 11:56 AM   #6 (permalink)
04SRT_08's Avatar
yeah pcm control FTL
Old 11-08-2009, 02:23 PM   #7 (permalink)
If I had the adjustable wastegate wouldnt i still have to reset the pcm because of the higher boost?
Old 11-08-2009, 02:30 PM   #8 (permalink)
Member Number: 68911
Nope, because you would be taking it off pcm controlled boost so there is no way for the pcm to bring it back down
1NiceSRT is offline   Reply With Quote
Old 11-08-2009, 05:05 PM   #9 (permalink)
Whatarush's Avatar
Member Number: 75945
At what point does a map clamp ( Map Sensor?? 2/3 bar etc) come into play? I was reading about that today and egts?
Z
Whatarush is offline   Reply With Quote
Old 11-08-2009, 10:54 PM   #10 (permalink)
blackandbluesrt4's Avatar
Member Number: 71452
...wrong thread. and you should do a search for that because you can't just post questions in any thread.
04 nsrt-4 E-blue
Seibon CF stocker, Stock exhaust(gutted cat, sounds better than my side exit!), mopar sts w/booger/MPx knob, Turbo XS on stock couplers, HD catch can, ebay CAI, ebay MBC at 20psi, P&P intake mani and TB, apexi TT. pump rewire, fan switch. http://www.srtforums.com/forums/f27/...lights-540636/
blackandbluesrt4 is offline   Reply With Quote
Old 11-09-2009, 01:34 AM   #11 (permalink)
gatox360's Avatar
Member Number: 69156
either the spring mod or a new adj wga is the same thing, the adj wga connects to the same hoses to the turbo.. the red line going to the cold side that connects to the solenoid is to " LEAK BOOST " when the pcm detects more boost that it should. if you're a costumer in a budget like me, just grab an ebay boost controller for arround 15-20 shipped and clamp off that red bitch line and you'll be fine, no more PCM BOOST CONTROLLED!!!
hope it works for you, it did for me
gatox360 is offline   Reply With Quote
Old 11-09-2009, 01:44 AM   #12 (permalink)
gatox360's Avatar
let me give you an advise, the intercooler use it only if you boost 20+. if i were you i'll just buy an intake before full 3inch exhaust, motor mount inserts to get rid of wheel hop you know simple stuff. that's if you just dont want to race but when you want to step on the gas pedal get a little more response.
i did the same spring mod with my srt, bought an ebay type-s bov for arround 25, i did my own cold side pipe to mount my bov for around 30, boost controller, downpipe and intake, and im set at 16. more than that with everything like it is now and it'll be bad for my turbo. the economy is not helping me to buy name brand such as agp greddy hks etc. just keep on digging and you'll find some cool mods for really cheap.
Old 11-09-2009, 08:17 AM   #13 (permalink)
Member Number: 75181
I find that hard to believe. I've had the spring mod on for 3 months or so now, spiking at 18 and holding 15 to red line. Yet to have any CEL's to come on.
R--I-D-D-L-E--R is offline   Reply With Quote
Old 11-09-2009, 09:00 AM   #14 (permalink)
Whatarush's Avatar
My bad, got caught thinking about fuel and egts and made me think of those mods....
Thought this was the performance mod section.
Damn noob
Old 11-09-2009, 02:00 PM   #15 (permalink)
MOPARfulSRT4's Avatar
Member Number: 62481
Yeah I've had my spring mod for a year and never had to reset my ECU. I originally brought an aftermarket wastegate (don't wanna say which one because the company has EXCELLENT customer service and I don't want them to look bad) and read about spring mods. So I put the stocker back on and tried the spring mod. WOAH, what do you know, my spring mod actually held more than the aftermarket wastegate. Plus I put a turnbuckle on it (from home depot) and now I can control my boost. So I sold my aftermarket wastegate and brought some tail lights.
A Neon w/ PVO upgrades!
MOPARfulSRT4 is offline   Reply With Quote
Page generated in 0.15835 seconds with 13 queries
