Old 11-10-2008, 06:32 PM   #1 (permalink)
Member Number: 66771
Default question about BC with diablo...
Ok im currently running my car off pcm controlled boost.Im goign to buy the FM wga and go back on PCM controlled boost. Im goign to buy the diablo, and i want to be able to controll boost with it. Dose it act like a EBC and let me run what boost levels i tell it to, or if i go back on pcm controlled boost, will it pull boost and all that stuff? It says on its list of things it dose, Boost controller. do i actually put in what boost levels i want, and it runs that? I know some of you guys have bought this and no more about it then I do. Please let me know i plan on doing this very soon.
pirate562007 is offline   Reply With Quote
Old 11-11-2008, 07:44 AM   #2 (permalink)
Member Number: 9221
Trader Rating: (19)
as of right now you have to have a toys PCM
GO FAST PARTS
Stock PCM
AGP 44# delta
Diablo predator
Dtec FC
FIC 625cc injectors
AGP returnline
PTP 55mm TB
PTP check valve
ED hardpipes w/ HKS BOV
Maddog STS 72%
AGP motor mounts
Zeitronix ZT2 wideband
Needswings DP (no cat)
180 thermostat
Bwoody H-brace combo
Bwoody Trans mount
AnotherNeon is offline   Reply With Quote
Old 11-11-2008, 07:53 AM   #3 (permalink)
U have to have toys to access the Boost controll option with the diablo? that dont make sense, they act like that came standard with there tune. Idk.... I thought the main use 0f the diablo was for cars on stock pcm. I was actually told to sell my stage1 pcm and go back to my stage 0 becuase there is no need for that.
Old 11-11-2008, 06:03 PM   #4 (permalink)
Member Number: 9221
Trader Rating: (19)
That is correct. I suggest you buy the diablo from someone other then Rage. Try Forward Motion.
Old 11-11-2008, 06:06 PM   #5 (permalink)
KBizzle's Avatar
Member Number: 30144
Trader Rating: (28)
wrong.
you can control boost with the dsport
you can not do boost by gears unless you have stg2/3 with the toys or a toybox...
KBizzle is offline   Reply With Quote
Old 11-11-2008, 09:45 PM   #6 (permalink)
ok, i know this now, i talked to one of the guys who helped with the creation of the diablo. thanks though. Ill be switching to a FM wga to run on pcm controlled boost with teh diablo
Old 11-11-2008, 09:54 PM   #7 (permalink)
mebcop's Avatar
Member Number: 42028
OK, to clear this all up and make sure I have it right:
You can adjust your PCM controlled boost on ANY stage ecu to run whatever level you want, you just need a toys ECU if you wanna run boost by gear, RIGHT?
So I can still use my S0 computer and run PCM controlled boost and set it at 25psi(using 3.5bar Map), right?
AGP return line, AEM SRI, AEM UEGO Wideband, VRS 3 inch Exhaust, Maxxfab 3" DP w/o cat, DW 750's, MPx FMIC , 50 Trim AGP, HKS SSQ BOV, Turbonetics evolution wastgate, OBX IC pipes, Labonte Motorsports W/M kit, SBC Stage 5 clutch, Perrin MBC, Maddog 80% STS, bottleneck fix, walbro 255, Bwoody MM.Diablo Predator: 433 WTQ ON A MUSTANG DYNO UNCORRECTED <<< back when I was on EMS WTB:TRACTION HAHAHA
mebcop is offline   Reply With Quote
Old 11-11-2008, 09:58 PM   #8 (permalink)
KBizzle's Avatar
Trader Rating: (28)
correct
Old 11-12-2008, 10:30 AM   #9 (permalink)
Member Number: 9221
Trader Rating: (19)
you can control boost with the diablo even if you have a Big turbo?
Old 11-12-2008, 08:47 PM   #10 (permalink)
TurboMoparGod's Avatar
Member Number: 33697
Trader Rating: (56)
Don't see any reason why not.
Forward Motion 302-658-2829
http://www.forwardmotioninc.com/html...og/page18.html
Sales@ForwardMotioninc.com
Stock turbo 12.82@107mph DR's
E1 Turbo 12.48@115mph DR's slipping stock clutch
E3 47lb Turbo times to come
TurboMoparGod is offline   Reply With Quote
Old 11-12-2008, 11:37 PM   #11 (permalink)
Member Number: 61830
Trader Rating: (17)
so long as you still have the soleniods hooked up, and have the stock line running from the wastegate to the soleniod....
Spaz_22 is offline   Reply With Quote
Page generated in 0.16504 seconds with 13 queries
