(Q/A thread) SRT-4 Performance Modifications and Upgrade Paths - Page 4 - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 05-05-2011, 02:36 PM   #46 (permalink)
Crazyced's Avatar
Member Number: 56385
Quote: Originally Posted by NorthNJSRT4 View Post
If you're trying to use an FM or S2 WGA on a stock or Stage 1 PCM with the 93tune it's not going to work right out of the box. The 93tune on a stock or S1 PCM assumes that you're using a stock WGA so the wastegate duty cycle is scaled for that WGA alone and PCM WGDC% learning is disabled. But there's a trick to get it to learn the correct WGDC% to operate an FM or S2.
1.) Boost leak test the system, tbolt hose clamp and ziptie all the lines making SURE everything is tight. If you don't have a boost leak tester you will need one to complete this step, just tightening things up isn't enough to be positive there are no leaks.
2.) Run a single vacuum line from the turbo housing directly to the WGA then set the arm so that it boosts to 8-9psi. Keep tweaking the arm until it's good.
3.) Hook the vacuum lines back up on PCM control as stock through the WG solenoid.
4.) Load the factory stock or Stage 1 tune back on the PCM, start the engine at least once.
5.) Reset the PCM by pulling the negative lead off the battery for a minute.
6.) Drive the car around doing some WOT pulls for a while until the boost levels stabilize and become predictable (this is the learning process).
7.) Load the 93tune without resetting the battery.
8.) With the handheld, set up your desired boost level to what you want to hit in 3rd or 4th gear, set up your AFR to your target in 3rd or 4th gear, datalog for knock (adding fuel or pulling timing as needed to make sure ST knock never goes over 1 count).
If you have to reset the battery for any reason, write down your DSP settings and repeat the whole process again from step #4.
If for some reason you just can't get the car's boost level dialed in you can make things easier by getting a rescale tune for the FM or S2 WGA by PMing "Turbo666".
Does it affect boost that much to flash the DSP tune on a 'resetted' PCM?
Crazyced is offline   Reply With Quote
Old 05-05-2011, 02:40 PM   #47 (permalink)
Merderates da formz
NorthNJSRT4's Avatar
Member Number: 57126
Without going through the learning process to setup the WGDC% for a WGA the PCM isn't expecting boost can be erratic, not come on as a smooth curve and be difficult to get it to hit a specific boost level every time you go WOT. When you're boosting out of stock sensor range (over 18.5psi) it can make setting up AFR difficult and unpredictable.
NorthNJSRT4 is offline   Reply With Quote
Old 05-05-2011, 02:44 PM   #48 (permalink)
Crazyced's Avatar
Oh I see, I had the stock (or whatever's matching your PCM) WGA in mind.
Old 05-05-2011, 02:56 PM   #49 (permalink)
scramer05's Avatar
Member Number: 70814
Ok sounds good. What would be the process if using an agp? My buddy has his agp off pcm co trol and is just using the dsp for tuning fuel/timing, and so on.
2003 SRT-4
Driver mod + more
Tuned by: Stick's House of Speed
30+ Positive Feedback On Neons.org
scramer05 is offline   Reply With Quote
Old 05-05-2011, 03:23 PM   #50 (permalink)
Merderates da formz
An AGP or Kinetic WGA can't be used on PCM control which is one of the many reasons why they suck with a DSP. Even with a CMR dealer's rescale tune, the lowest possible boost level they can hit is the weight of the spring (usually 15-17psi) so there's no way to eliminate the very undesirable condition that is partial throttle overboost which makes the car ALOT less fun to drive on the street.
They were great when we really didn't have any other way to hit high boost targets (I own a Kinetic and an AGP; loved them for years) but since the DSP came out and we gained full control over the PCM they're pretty much worthless now.
Old 05-05-2011, 03:34 PM   #51 (permalink)
MikeyB_SRT-4's Avatar
Member Number: 84290
Is the AGP FMIC you listed the best thing to get on an all stock setup as far as IC's? The reason I ask is that im trying to do the few things im capable of doing myself upgrade wise before getting into stuf that i dont have the time, skill, money for proper apprenticeship, etc. to do.
Thanks
MikeyB_SRT-4 is offline   Reply With Quote
Old 05-05-2011, 08:07 PM   #52 (permalink)
Merderates da formz
Thanks
IMO...The AGP Mini is the best direct fit unit available because of it's end tank design and core. Second would be the Spearco stage 1 then, on a budget, the CX Racing direct fit.
Old 05-05-2011, 09:28 PM   #53 (permalink)
Boostinfamily's Avatar
Member Number: 77511
well that explains a few ( alot of) things.
Boostinfamily is offline   Reply With Quote
Old 05-05-2011, 09:46 PM   #54 (permalink)
correct me if i'm wrong, but with a reset PCM you can still just modify the stock tune and keep the WGDC adaptive learning right?
Old 05-06-2011, 04:55 AM   #55 (permalink)
Merderates da formz
Correct but you don't get the increased torque output tables (where you get the power increase over stock) or the much more desirable 11.77AFR base point.
Old 07-16-2011, 03:30 PM   #56 (permalink)
Member Number: 85344
If i buy a mopar cat delete downpipe do i need to buy an o2 housing?
Muffin 69 is offline   Reply With Quote
Old 07-16-2011, 04:01 PM   #57 (permalink)
Fresh Meat Moderator
tunerlover3's Avatar
Member Number: 76568
You dont have too. You can use the stock O2 housing.
Diablo CMR tuner ~Dan~
310HP 436TQ
XXXHP XXXTQ
Old 07-16-2011, 05:13 PM   #58 (permalink)
Merderates da formz
/Agree
The stock O2 housing is just fine on a stock turbo. Going up to a 3" only gives you a marginal gain over stock and it's a serious pain in the ass to change.
I wouldn't bother with the Mopar one, it's insanely expensive for what amounts to a just a metal tube. If you have that kind of money to spend, a 3" Needswings catless cutout with an electric opener would be alot better for the same money. If you just want a strait 3" catless downpipe, Needswings offers an extremely well made one for 1/3 the price of the Mopar DP.
Old 07-16-2011, 05:36 PM   #59 (permalink)
director1203's Avatar
Member Number: 78247
Nice write up North. Waiting for more to come.
DCR built
PTE6262 powered
Frana input with extended gears
AEM now installed
Best timeslip
1.78 60ft
11.12 1/4
129.65 MPH
director1203 is offline   Reply With Quote
Old 07-16-2011, 05:40 PM   #60 (permalink)
Merderates da formz
The next installments are coming shortly. They'll cover 'final touch' mods for maxing the stock turbo, drag strip mods to cut your ETs and big wheel stockers for those that want a lil' more out of the stock exhaust mani setup.
