Old 12-27-2008, 12:32 PM   #1 (permalink)
boo5t's Avatar
Member Number: 65044
Default Ported turbo or exhuast mani
which would i get the most gains out of i have been doing some home work some ppl same the stock mani is good for 350 plus hp but some ppl say no and the ported turbo ppl say is worth less unless you have a ported mani or a combonation of both im just looking for more advice.
MoparShortThrow,Aem Wideband,MPxFMIC Injenintake,MSDCoil,NGK VPower,AGPWasteGate,QTPDownPipeW/cutout,Side Exit Exhaust,Mpx Throttle Body,225 Wallbro,Fuel Pump Rewire,FPR Mod,Scan Gauge, Cold Side Pipe w/HKS BOV, Map Clamp....
boo5t is offline   Reply With Quote
Old 12-27-2008, 03:02 PM   #2 (permalink)
supermech21's Avatar
Member Number: 42969
By far, the manifold!!! Hands down the ported turbo will barley net 5hsp, if that.
SRTforums, do as i say not say as i do.
Old 12-27-2008, 03:06 PM   #3 (permalink)
boo5t's Avatar
but if i get the turbo too will it benifit more having the mani?
Old 12-27-2008, 03:09 PM   #4 (permalink)
Dont waste your money on getting the compressor housing...its a waste, seriously.
You wanna spend money? Get a ext gate AND port...maybe maxed out you will see 330hsp...maybe.
Old 12-27-2008, 03:12 PM   #5 (permalink)
7055's Avatar
Member Number: 52407
Why go through all that trouble when you can just swap turbos and see even better gains?
376/437 in HOM 343/382 on 91
7055 is offline   Reply With Quote
Old 12-27-2008, 03:13 PM   #6 (permalink)
You talking about a SST or E1?
If so you wont gain anything but egt's...
Old 12-27-2008, 04:00 PM   #7 (permalink)
7055's Avatar
I meant swap in a different turbofold assembly. I'm guessing the SST and E1 turbo use the stock exhaust manifold?
Old 12-27-2008, 04:35 PM   #8 (permalink)
boo5t's Avatar
i was think the ext gate pt got one for like 700 thats much i was thinkin the economy manifold .
Old 12-27-2008, 05:06 PM   #9 (permalink)
Only1Balto's Avatar
Member Number: 43836
Get them both done while they're out. You'll be on your way to 12's no problem.
Quote: Originally Posted by tunerlover3 View Post
I just help out other black owners ...
Only1Balto is offline   Reply With Quote
Old 12-27-2008, 05:08 PM   #10 (permalink)
Only1Balto's Avatar
Yes. But if you've got an SST or an E1 w/ a ported mani you'll notice huge gains.
Old 12-27-2008, 08:42 PM   #11 (permalink)
boo5t's Avatar
so ported mani is more worth it ?
Old 12-28-2008, 04:47 PM   #12 (permalink)
brianbr's Avatar
Member Number: 50755
Yes it is
AGP Delta 46, Ported intake manifold DCR 55mm tb, ptp 3" downpipe, custom 3" dump exhaust, fuel pump rewire, 255 fuel pump, DW 750cc injectors, Dtec, BC stage 3 cams, DCR oil mod, fidanza gears, aem cai. agp solid mounts, agp race fmic, ultimate racing uhp, 2.5" cti charge pipe, Hks ssqv, aem wideband, aeroforce scangauge. defi egt gauge, 180 deg thermostat, fan mod, Hotchkis springs, Koni yellow's, Prothane Lca's.
brianbr is offline   Reply With Quote
Old 12-28-2008, 05:19 PM   #13 (permalink)
7055's Avatar
I still don't see why you'd take the exhaust manifold off and send it off to be ported when you could just buy a whole new turbofold/turbo assembly.
Old 12-28-2008, 05:47 PM   #14 (permalink)
kevin2004's Avatar
Member Number: 66925
I agree, why not get the whole kit brand new with ext gate, better turbo, and better manifold for not much different money?
Like the agp 3147 kit for $1250. 3147 Turbo Kit Closeout - $1250
Then if your turbo ever shoots craps on you, you can just bolt another one on (because they are pretty universal) and get back on the road instead of having to stick with the stock turbo/manifold setup.
kevin2004 is offline   Reply With Quote
Old 12-28-2008, 08:15 PM   #15 (permalink)
Only1Balto's Avatar
Well- I wouldn't send them to get done. Do it yourself or try to find a good friend (Who knows what hes doing) and he can slash the price for you. I myself don't know how much they cost to get ported.
