Ok, I know a few of the basics, but EVERYONE appreviates everything. For the noobs, let's start a glossary of terms that they can go to when they need to figure out what the hell someone is talking about. I searched to see if there was one, but the link that was supplied is broken. I'm gonna start with the ones that I know. Oh, BTW, let's make this sticky so that it's easy to find...
BOV = Blow Off Valve
UPP = Upgraded Pressure Pipe
WGA = Wastegate Actuator
BOP = Block Off Plate
CAI = Cold Air Intake
TT = Turbo Timer
STS = Short Throw Shifter
MBC = Manual Boost Controler
EBC = Electronic Boost Controler
DSBC = Dual Stage Boost Controler
HPBC = High Performance Boost Controler
These are the ones that I know and that I can think of at this time. Anyone else?
i know i am a noob for asking, but what is WOT shifting, i always read about that, but i dont understand. btw i dont own an srt..yet so cut me some slack.
-- 2005 Subaru STi - 340AWHP - FOR SALE!!!
-- 2006 Yamaha GP1300R -- 175HP on H2O
-- 2007 Hyundai Santa Fe SE AWD (planned)
-- 2001 Nissan Pathfinder SE 4x4 **SOLD**
SOL= SHIT OUT OF LUCK
HNIC= HEAD ****** IN CHARGE
To Be Continued...........
Dont hate cause it took half the money it took you to be this good!!!
mopar S1
ATP UPP
HKS BOV
AGP BOP
ModZ Billet WASTEGATE
Greddy Profec E-01
Greddy TT
Greddy Catch Can
Greddy Emanage
Stage One
Street GLow Underbodys
Kicker Speakers
Pioneer HU
ModZ Strut Bar
Kicker L7 in Custom kicker box
Audiobhan Shaphire amp
old news but here ya go:::::::::: 2DR = 2 door
4DR = 4 door
A/F = Air/Fuel Ratio
A/C = Air Conditioning
ABS = Anti-lock Braking System
ACG = Adjustable Cam Gears
ACT = Air Charge Temperature Sensor
AFC = Automatic Fuel Controller
AFPR = Adjustable Fuel Pressure Regulator
AWD = All Wheel Drive
ACM = Airbag Control Module
AFR = Air to Fuel Ratio
BCM = Body Control Module
BHP = Brake Horsepower
BOP = Block off plate
BOV = Blow-off Valve
BPV = Bypass Valve
CAI = Cold Air Induction/ Intake
CB = Catalytic back (cat-back)
CC = Catch Can
CEL = Check Engine Light
DAB = Dial-a-boost
DCX = Daimler Chrysler
DOHC = Dual Overhead Cam
DP = Down Pipe
EBC = Electronic Boost Controller
ECU = Engine Control Unit
EGT = Exhaust Gas Temperature
EM = Exhaust Manifold
EMS = Engine Management System
FI = Force Induction
FMIC = Front Mount Intercooler
FPR = Fuel Pressure Regulator
FSM = Factory Service Manual
FWD = Front Wheel Drive
HID = High Intensity Discharge lighting
HOM = High Octane Mode
HP = HorsePower
I/C = Intercooler
I/H/E = Intake/Header/Exhaust
IM = Intake Manifold
LSD = Limited Slip Differential
MAP = Manifold Air Pressure Sensor or Manifold Absolute Pressure
MBC = Manual Boost Controller
MM = Motor Mounts
NOS = Nitrous Oxide System
OEM = Original Equipment Manufacturer
PCM = Power Control Module/ Primary Control Module
PCV = Positive Crankcase Ventilation
PP = PowerPaq
PVO = Performance Vehicle Operations
RWD = Rear Wheel Drive
S-AFC = Super Airflow Converter
SOHC = Single Overhead Cam
SMIC = Side Mount Intercooler
SRI = Short ram intake
SRS = Supplimentary Retraint System
SRT = Street and Racing Technology
SV = Surge Valve
TB = Throttle body
TID = Turbo Intake Duct
TIP = Throttle Inlet Pressure Sensor
TPS = Throttle Position Sensor
TT = Turbo Timer or Twin Turbo
UDP = UnderDrive Pulley
UP = Up Pipe
VC = Valve Cover
WHP = Wheel Horse Power
WOT = Wide Open Throttle
EVEN A BROKEN CLOCK IS RIGHT TWICE A DAY
Quote: Originally Posted by noTe
You can use dish wash soap to wash a car.
Quote: Originally Posted by slow4dr
You can install your hot side pipe on my ass anytime.
got a question didnt know where to post really but i have a 04 srt with mopar stage2 w/o toys 180 theromstat, atr 3 high flow downpipe w cat,electronic exhaust pump and adjustable manual boost contoller set at 18npsi spike 15 psi hold please someone explain what i have and where is the boost controller i dont see a control box all this and covered under warranty by dodge in writing so someone help me any advice at all
