Old 12-03-2007, 03:02 PM   #91 (permalink)
03ACR's Avatar
Member Number: 59357
Quote: Originally Posted by StreetRacingTyrant View Post
i'm new to this and dont know where to post but i want to get some advice i'm looking into a greddy GT2871R or GT30 i want to run on pump gas is that safe??
i was in the same boat at one point i went with the stage 3r kit insted just because of the fact that you get every thing you need. fuel pump injectors, pcm, ect. and its just all bolt on the work is done for you. then if you want down the road you can add bolt-ons from there, mopar did it right with the stage kits thats for shure..
but on the same hand it's totaly up to you and what you wana do!!
good luck!
2003 E-blue srt-4 Stg3r w/toys// clutch masters stg4//dss axles// xs BFMIC// hard pipes// 62mm Tb// mopar catback// mopar STS//
personal best ET- 12.3 @ 113.4
personal best MPH- 115
-1980 dodge pick-up 4x4 on 44" w/ 671 blowen 426ci
03ACR is offline   Reply With Quote
Old 12-18-2007, 01:20 PM   #92 (permalink)
SRT4NEMESIS's Avatar
Member Number: 54947
OK, Chuck I 'll confess I don't know the new one... RBM... What is it???
MOPAR OR NOCAR
S3R BIG WHEEL 410HP
SRT4NEMESIS is offline   Reply With Quote
Old 01-20-2008, 04:54 PM   #93 (permalink)
Member Number: 60971
i just put a agp wastegate on my 05 srt and tryd boosting a little more but im always fuel cu at around 18 psi what would anyone suggest a fuel pressure regulator?
batman08 is offline   Reply With Quote
Old 01-20-2008, 09:21 PM   #94 (permalink)
travisanderson's Avatar
Member Number: 53370
unhook the red line and cap it from the cold pipe... no more fuel cut..
travisanderson is offline   Reply With Quote
Old 01-28-2008, 10:51 PM   #95 (permalink)
FayettevilleSleeper's Avatar
Member Number: 40468
you need something to clamp the boost that the computer sees (DTEC, SAFC NEO, map clamp, ect.). you also want a wideband to monitor your AFR's to make sure that you are not leaning out. also if you are going to boost more, i would highly suggest an exhaust at the least. downpipe usually helps too. between an exhaust, downpipe, wastegate, and map clamp, you usually can make at least 15-20 more hp. hope that helps! remember, mod safe!
POWERED BY:
TUNED BY:
FayettevilleSleeper is offline   Reply With Quote
Old 02-20-2008, 11:59 PM   #96 (permalink)
Member Number: 61570
Ob????
hendy* is offline   Reply With Quote
Old 04-04-2008, 06:08 PM   #97 (permalink)
Member Number: 62953
"PTP 3" 02 Housing" ??? PTP??
IronMan2003 is offline   Reply With Quote
Old 04-05-2008, 04:03 AM   #98 (permalink)
first off, welcome to the forums
check out the vendor section at the bottom of the main forums page. i guarantee you will find PTP there. PTP is a vendor here for all things SRT-4. stands for personal transportation performance.
Old 06-05-2008, 01:20 PM   #99 (permalink)
srt-kapp's Avatar
Member Number: 63329
ACR-American Club Racer
And if you have to ask what SRT stands for get the fuck off this website
srt-kapp is offline   Reply With Quote
Old 07-01-2008, 06:40 PM   #100 (permalink)
Member Number: 65253
Quote: Originally Posted by skatemur View Post
i know i am a noob for asking, but what is WOT shifting, i always read about that, but i dont understand. btw i dont own an srt..yet so cut me some slack.
WOT shifting is wide open throttle shifting. In a turbo car like the srt staying on the gas during shifts is a way to reduce or eliminate turbo lag.
JReedsrt420 is offline   Reply With Quote
Old 07-08-2008, 07:38 PM   #101 (permalink)
memphiselitez's Avatar
Member Number: 65236
doesnt that mess up you car though?
memphiselitez is offline   Reply With Quote
Old 07-08-2008, 09:00 PM   #102 (permalink)
Member Number: 52407
Anytime you slam a car into gear it wears out the synchros quicker, puts more stress on the shiftfork.
7055 is online now   Reply With Quote
Old 07-09-2008, 08:10 PM   #103 (permalink)
simple solution is a WOT box
Old 07-16-2008, 08:29 AM   #104 (permalink)
n1vek's Avatar
Member Number: 45115
Quote: Originally Posted by redman View Post
Piitb
Put in in the Butt
...old but I was reading through this guy for the first time and it gave me a chuckle.
Great thread for someone just starting off in the sport compact world who needs to know vocab before he can learn how it all fits together and works (That would be me)
n1vek is offline   Reply With Quote
Old 09-03-2008, 11:39 PM   #105 (permalink)
kobegot81's Avatar
Member Number: 56934
Default stage
What would you guys recommend? Stage 1 or 2? With or without toys?
Mods: Stage 2 w/toys, mpx turboback, agp wastegate, mpx BFMIC, agp hadr pipes w/ HKS ssqv, AEM wideband, MSD coil and wires, Dasmopar mapclamp, walbro 255....
Best quarter mile was 13.40 @ 106mph
** Street tires(bfg gforce sport with 35 psi)
kobegot81 is offline   Reply With Quote
