I couldn't find much more than "hey, here it is, put the sender there..."
well I just put in an AN- T fitting with plugged ends, I'm getting the gauges in the mail this week and will later put pics with the senders in place.
I placed the T the way it is because I need to fit the sender for the electric oil pressure gauge.
here's how I did it:
1-all female 1/8 NPT T
1-male to male 1/8 NPT connector
optional...1 pack of 2- 1/8 NPT plugs
teflon tape
T30 (or equivalent hex head) bit
flat head screw driver(to remove the stock head plug)
1. remove intake
2. unplug the battery and remove
3. wrap all threads with teflon tape
4. tighten down the AN plugs, 1 in the middle of the T and 1 at the end.
5. tighten down the male-male connector in the other end
6. completely loosen the middle head plug with a large enough flat head screw driver(must wedge tight, diagonally in the square hole). Quickly remove the plug and place the male portion of your T into the head, now tighten by using a 5/8 open end wrench to turn the body of the T.
7. replace everything and drive around for awhile to check for leakage.
here's the AN- parts...cost is 17 with plugs and 14 without.......
Here's the plug......
Here's the T in place.......
Once again, I used plugs because I don't have the gauges in yet, and wanted to ensure the T wouldn't leak. To add a sendor or 2, use the T30 bit to remove the AN plugs, and use teflon tape around the threads of the sender. Autometer as well as most companies use 1/8 NPT for the senders.
new pics to be added later this week...................
