Original thread: Performance Mod Glossary
Combining each individual post from the last thread in order to have just one page with all the terms on it. It was too much to flip through 7 pages. Please post more abbreviations that are not on the list and I will update the page accordingly. Sticky this, and unsticky the other please.
2DR = 2 door
4DR = 4 door
A/F = Air/Fuel Ratio
A/C = Air Conditioning
ABS = Anti-lock Braking System
ACG = Adjustable Cam Gears
ACT = Air Charge Temperature Sensor
AFC = Automatic Fuel Controller
AFPR = Adjustable Fuel Pressure Regulator
AWD = All Wheel Drive
ACM = Airbag Control Module
AFR = Air to Fuel Ratio
BCM = Body Control Module
BHP = Brake Horsepower
BOP = Block off plate
BOV = Blow-off Valve
BPV = Bypass Valve
CAI = Cold Air Induction/ Intake
CB = Catalytic back (cat-back)
CC = Catch Can
CF = Carbon Fiber
CEL = Check Engine Light
DAB = Dial-a-boost
DBB = Dual Ball Bearing
DCX = Daimler Chrysler
DOHC = Dual Overhead Cam
DP = Down Pipe
DR = Drag Radial
DSBC = Dual Stage Boost Controler
EBC = Electronic Boost Controller
ECU = Engine Control Unit
EGT = Exhaust Gas Temperature
EM = Exhaust Manifold
EMS = Engine Management System
FI = Force Induction
FMIC = Front Mount Intercooler
FPR = Fuel Pressure Regulator
FSM = Factory Service Manual
FTW = For the Win
FWD = Front Wheel Drive
HID = High Intensity Discharge lighting
HOM = High Octane Mode
HP = Horsepower
HPBC = High Performance Boost Controller
I/C = Intercooler
I/H/E = Intake/Header/Exhaust
IIRC = If I remember correctly
IM = Intake Manifold
JDM = Japanese Domestic Market
LCA = Lower Control Arm
LSD = Limited Slip Differential
LPP = Lower Pressure Pipe
MAP = Manifold Air Pressure Sensor or Manifold Absolute Pressure
MBC = Manual Boost Controller
MC = Map Clamp
MIL = Malfunction Indicator Light (same as CEL)
MM = Motor Mounts
NGC = Next Generation Controller
NOS = Nitrous Oxide System
OBD = On Board Diagnostics
OEM = Original Equipment Manufacturer
PCM = Power Control Module/ Primary Control Module
PCV = Positive Crankcase Ventilation
PP = PowerPaq
PTB = Partial Throttle Boost
PVO = Performance Vehicle Operations
QSBC = Quad Stage Boost Controller
RWD = Rear Wheel Drive
S-AFC = Super Airflow Converter
SEE = Side Exit Exhaust
SOHC = Single Overhead Cam
SMIC = Side Mount Intercooler
SRI = Short ram intake
SRS = Supplementary Restraint System
SRT = Street and Racing Technology
SST = Super Stock Turbo
STB = Strut Tower Brace
STS = Short Throw Shifter
SV = Surge Valve
TB = Throttle body
TID = Turbo Intake Duct
TIP = Throttle Inlet Pressure Sensor
TOB = Throw out Bearing
TPS = Throttle Position Sensor
TT = Turbo Timer or Twin Turbo
UDP = Underdriven Pulley
UPP = Upper Pressure Pipe
UP = Up Pipe
VC = Valve Cover
WGA = Wastegate Actuator
WHP = Wheel Horse Power
WOT = Wide Open Throttle
