Old 07-10-2009, 01:19 PM   #16 (permalink)
Adionik's Avatar
Member Number: 51197
Trader Rating: (25)
How do the plugs and wires look? I had the same problem with my step 2 iridium plugs and were gapped improperly and ruined
or 16 whatev
WTB: LCA bushings
Adionik is online now   Reply With Quote
Old 07-10-2009, 04:32 PM   #17 (permalink)
isthatguy's Avatar
Member Number: 49055
Trader Rating: (13)
well i changed out the plugs with another set, and it didnt fix the issue..
354 whp e3 @ 21psi. 0 knock!
Quote: Originally Posted by KBizzle View Post
your car made me happy in the pants, sorry I didn't track you down to say hey.
-Keegan
isthatguy is offline   Reply With Quote
Old 07-10-2009, 07:21 PM   #18 (permalink)
Adionik's Avatar
Trader Rating: (25)
That is a very weird problem indeed
Old 07-10-2009, 07:43 PM   #19 (permalink)
isthatguy's Avatar
Trader Rating: (13)
yea we are going to swap TPS, and CAS sometime this weekend, working too much kills me
Old 07-15-2009, 06:34 AM   #20 (permalink)
Member Number: 50750
subscribed
Kristjan SRT-4 is offline   Reply With Quote
Old 07-15-2009, 05:20 PM   #21 (permalink)
kenoshasrt's Avatar
Member Number: 46494
I think I may be having this issue with my stage 2 car. I've done all the tests(vacuum leak/boost/Sensor voltage,etc...) and nothing seems to be wrong. I have no engine light, but if at idle I am running a 13.7-14.0 a/f ratio and it stumbles a little. Then if I go WOT the car falls on its face completely. I am only boosting 14psi now to see if that would help, but NOPE!! Also I boost leak tested the car up to 22psi and no leaks were found.
The worst part about this is my car was running 12's at the track last year and now with this whole "hitting a wall" crap I am running 14's...worse than I did stock!!
I'm am about to replace the TPS sensor as well, but I think I'm gonna wait for your answer. Please hurry.....
kenoshasrt is offline   Reply With Quote
Old 07-15-2009, 09:16 PM   #22 (permalink)
isthatguy's Avatar
Trader Rating: (13)
havnt gotten to try yet, my car is pulling timing tho, bad. it sounds like a machine gun. lolz!
Old 07-15-2009, 09:41 PM   #23 (permalink)
conroy9940's Avatar
Member Number: 46401
Trader Rating: (114)
figure out this shat mang
Pittsburgh Penguins 14-8-0 28 points
Old 07-15-2009, 09:51 PM   #24 (permalink)
isthatguy's Avatar
Trader Rating: (13)
trying too, this weekend i will have more time on my ahnds, and the car is getting dropped of at adams to do some sensor swaps!
Old 07-15-2009, 11:17 PM   #25 (permalink)
kenoshasrt's Avatar
I'll be awaiting your results.
Old 07-17-2009, 08:57 AM   #26 (permalink)
isthatguy's Avatar
Trader Rating: (13)
tps = no fix
Old 07-18-2009, 05:22 PM   #27 (permalink)
kenoshasrt's Avatar
Well yesterday I changed the TPS sensor and like you - no fix even after 50 miles of pcm relearn time. Then I decided to throw on a different WGA that I had and BAMM(set to 20-21 spike/15-16 hold with the bleeder valve), and the car was pulling like a freight train again.
I never thought to change my WGA because the boost gauge would read up to a 20psi spike and hold 14-16, but I guess something was messed up with my Kinetic WGA. If you have another WGA to try it couldnt hurt
Just remember to reset the pcm(pull fuse and disconnect battery) after the install and dont race the engine for atleast the first 10 miles of the test drive after install. Otherwise the pcm will pull timing like crazy because its trying to relearn base maps.
Old 07-18-2009, 09:13 PM   #28 (permalink)
isthatguy's Avatar
Trader Rating: (13)
i got my issue resolved, it ended up being bad MSD plug wires.
Old 07-19-2009, 01:52 PM   #29 (permalink)
kenoshasrt's Avatar
You know what, now that I think about it I did change my MSD wires out for some Stock ones at the same time as replacing the WGA.......
F*CKING MSD!!!!!!
Page generated in 0.16665 seconds with 13 queries
