Old 07-09-2009, 03:20 PM   #1 (permalink)
isthatguy's Avatar
Member Number: 49055
Trader Rating: (13)
Default No power after 4k rpm help plz
Ok, first off, the mod list.
47# stage 3 turbo less thank 1k miles
ported manifold with DCR ramp mod
PTP wga 20psi
6 an returnline 43.5 rising rate 1:1
6 an feed line with bottle neck fix
walbro 255 fuel pump
fuel pump re-wire
RC750cc injectors
MSD 8.5 wires
NGK 1 step colder plugs (less than 200 miles)
stock pcm reflashed via DSP + turbo666
3bar map/tip
3" intake/ catless exhaust/o2 housing
Griffen BFMIC
ported intake manifold + throttle body
(i think thats all that matters)
ok the car drives perfect under normal driving, but under WOT as soon as 4krpm hits the car has no power, it still holds boost at 20psi a/f at about 11.6/7
it seems like it hits a wall, this just started, and the exhaust makes a CRAZY loud rattle noise as soon as the car loses power. (i will try to take a vid soon)
the car dynod at 347whp with no issues, this just started after I put the ported i/m t/b on.
what we have tried to diagnose/fix to solve this
put stock i/m t/b on - no fix
change wires - no fix
change plugs - no fix
regap plugs - no fix (gapped at 30 now)
change coil pack - no fix
Compression test:
Cyl 1: 145
Cyl 2: 150
Cyl 3: 150
Cyl 4: 150
then we decided to do a bottle neck fix and fuel pump rewire - no fix
we put the gauge for the fuel pressure on the windshield, the car is holding fuel pressure fine, and under wot is at like 63 (1:1) so everyhting with fuel seems ok, and the car is idling fine and throwing no CEL codes.
please help, we are lost
354 whp e3 @ 21psi. 0 knock!
Quote: Originally Posted by KBizzle View Post
your car made me happy in the pants, sorry I didn't track you down to say hey.
-Keegan
isthatguy is offline   Reply With Quote
Old 07-09-2009, 03:23 PM   #2 (permalink)
HCCAFan's Avatar
Member Number: 35768
Trader Rating: (23)
Cat clogged up?
WTB: 96-07 Nissan Pathfinder parts;
Hood
Left front fender
Left headlight
Radiator
Condensor
Bumper Cover
Grille
HCCAFan is offline   Reply With Quote
Old 07-09-2009, 03:36 PM   #3 (permalink)
isthatguy's Avatar
Trader Rating: (13)
Quote: Originally Posted by HCCAFan View Post
Cat clogged up?
edited first post, I am running a catless exhaust, only 1 resonator. exhaust is 1 year old, never seen winter.
Old 07-09-2009, 03:42 PM   #4 (permalink)
Member Number: 71278
mmm, i used to have the same problem but my car was stock, i change the wastegate, and computer, and it fix it, i check whit the original ecu, but you can try whit the wastegate
magego is offline   Reply With Quote
Old 07-09-2009, 09:14 PM   #5 (permalink)
SrT4u2Nv4EvA's Avatar
Member Number: 67955
Kinda weird mayne. Eric's car was doing this exact same thing.. but that was before he got fuel management... everything is fine now.. He is also catless.
lame sig.
SrT4u2Nv4EvA is offline   Reply With Quote
Old 07-09-2009, 10:47 PM   #6 (permalink)
rasp's Avatar
Member Number: 56076
Trader Rating: (21)
Do you have the WOTbox/2-step?
Old 07-09-2009, 10:54 PM   #7 (permalink)
isthatguy's Avatar
Trader Rating: (13)
i do not.
the only electronics I have is an AEM wideband, and a electronic boost gauge.
I am thinking that maybe the PCM is pulling mad timing.
Old 07-09-2009, 11:08 PM   #8 (permalink)
rasp's Avatar
Trader Rating: (21)
So the car pulls until 4k, then it falls on its face but still maintains 20 psi and a good A/F?
Are you using the DSP (thought you were; I may be wrong)? If so, log it.
Old 07-09-2009, 11:43 PM   #9 (permalink)
isthatguy's Avatar
Trader Rating: (13)
yup, and I will log it tomorrow for sure
Old 07-10-2009, 07:23 AM   #10 (permalink)
isthatguy's Avatar
Trader Rating: (13)
does anyone think this could be a TPS issue?
Old 07-10-2009, 10:56 AM   #11 (permalink)
Member Number: 9221
Trader Rating: (19)
COT needs to be disabled i am guessing
GO FAST PARTS
Stock PCM
AGP 44# delta
Diablo predator
Dtec FC
FIC 625cc injectors
AGP returnline
PTP 55mm TB
PTP check valve
ED hardpipes w/ HKS BOV
Maddog STS 72%
AGP motor mounts
Zeitronix ZT2 wideband
Needswings DP (no cat)
180 thermostat
Bwoody H-brace combo
Bwoody Trans mount
AnotherNeon is offline   Reply With Quote
Old 07-10-2009, 11:07 AM   #12 (permalink)
isthatguy's Avatar
Trader Rating: (13)
COT ?
Old 07-10-2009, 11:14 AM   #13 (permalink)
Member Number: 45202
Quote: Originally Posted by isthatguy View Post
COT ?
Cat Over-Temp Protection....it uses your calculated egt and when it goes over like 16xx something it dumps fuel in to cool the cat. Eventhough you dont have one lol. Check with Turbo666 and see if he disabled COT in your tune.
Does it run fine if you take it past 4k when your not at WOT?
STOCK
ghice007 is offline   Reply With Quote
Old 07-10-2009, 11:24 AM   #14 (permalink)
Slow_spool's Avatar
Member Number: 50382
Trader Rating: (33)
ill take a look at a log when you post one
Slow_spool is offline   Reply With Quote
Old 07-10-2009, 12:39 PM   #15 (permalink)
isthatguy's Avatar
Trader Rating: (13)
yeah it drives normal over 4k if im not WOT..
Page generated in 0.19593 seconds with 13 queries
