#1 (permalink) |
![]() Join Date: Jan 2007
Member Number: 50112
I recently put my new valve cover on and it came with those blue AN fittings and I didn't know how to use my pcv valve with those AN fittings so I just removed it and I'm using my boomba check valve, car seems to be running fine but I'm not sure if it can cause any potential problems.
Here's my current catch can setup... Catch can, Check valve, passenger side valve cover Catch can to TB drivers side valve cover to to aem intake or thinking of using a breather for the drivers side valve cover. |
| Sponsored Links | |||
Advertisement | |||
#4 (permalink) |
Fresh Meat Moderator
![]() Join Date: Dec 2009
Member Number: 76568
As long as you have the check valve your fine.
I run a gutted PCV with a boomba check valve.
![]() Diablo CMR tuner ~Dan~ 2004 Black Neon SRT4: E85 stock turbo SOLD ![]() 310HP 436TQ 2004 Eblue Neon SRT4: E85 5558 ![]() XXXHP XXXTQ |
#5 (permalink) |
![]() Join Date: Jan 2006
Member Number: 37744
Dan what's the point in gutting the PCV? Noob ass question
Go to wikyd-performance.com for all of your srt4 performance needs. Contact jtm0n3y or wonderer86 for more info
http://www.srtforums.com/forums/f416...-parts-639326/ my for sale thread |
#7 (permalink) |
The PCV can break and send its guts into the valve cover. Running a check valve is needed. Ok awesome I was told the same thing but wanted to make sure before I get my car in the dyno Tuesday. Should I connect my vc to my intake? Or just stick a breather on it?
Yes VC to intake for sure.
#9 (permalink) |
![]() Join Date: Feb 2011
Member Number: 83113
From the way you wrote that, it sounds like you have the check valve between the catch can and valve cover. If that's the case you should move it before the catch can so it's not being pressurized under boost.
#10 (permalink) |
Yeah I just read that it should be:
PCV>>>>>>CC>>>>>>CV>>>>>>TB.
#12 (permalink) |
You need one for the car to run fine.
#14 (permalink) |
![]() Join Date: Oct 2009
Member Number: 75469
Yes VC to intake for sure. Do not do that....Either dump the drivers side of the valve cover to atmosphere using a hose or just stick a filter on it. The oil vapors that are being released can contaminate the intake charge if it is ran straight to the intake. I'm using a gutted PCV valve and have it dumped to atmosphere. The vaccuum nipple on my throttle body is used for something else now
#15 (permalink) |
The amount of oil that comes out of the valve cover vent wouldnt be enough to ruin anything IMO. I wasnt talking about putting the vent to the intake manifold.
![]() Diablo CMR tuner ~Dan~ 2004 Black Neon SRT4: E85 stock turbo SOLD ![]() 310HP 436TQ 2004 Eblue Neon SRT4: E85 5558 ![]() XXXHP XXXTQ Last edited by tunerlover3; 12-08-2012 at 09:27 PM. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
