#1 (permalink) |
Member Number: 90196
The car has not thrown a code which is one reason why im so pissed, also the car will rev to 6k no problem with missing a beat. the problem is when i boost about 5psi or more. it completely falls on its face. it sounds like its backfiring through the intake and the car will jerk really bad. ive tried new plugs, plug wires, and a cam pos sensor. i did notice that when i was reving it up from the engine bay there was an arc on the two i think 8mm bolts located one just to the right of the second plug counting from driver side, the other on the next to last plug on pass side. this is really angering me and i really cam close to kicking the crap out of my car, but then realized that would be dumb. my patients is limited towards this car so someone please help me.
| Sponsored Links | |||
Advertisement | |||
#4 (permalink) |
it is on 10psi vac when off, sometimes goes t 0. this car is always doing something different, when i unplugged the battery and plugged it back in, the car would boost over 20psi. (at least according to boost gauge). the plug wires did click on, but i have already removed them as they did not fix problem. at idele is at 20psi vac. if anyone on here is near to st. joseph mo, or near kc area i will drive it to you as i can still drive no problem, just cant boost any.
#6 (permalink) |
not understanding how my boost gauge reading being wrong making my car completely crap itself past 5lbs of boost. im sorry if that sounded rude or anything lol but ive had the car for a year the 28th and its sat at 10 vac every since. never had a problem until today when i was accelerating then out of nowhere the car game me the finger and shut down.
#8 (permalink) |
King Cid you are the fucking man!!!!!!!
Thank you for suggesting dielectric grease!!!! I bought 4 packets of dielectric grease 1 week ago and I packed both ends of my plugs and wires with it.......from day 1 after the dielectric grease......my car has started right up anytime of day......before it would take a couple of cranks My idle has even smoothed out and my car revs a little smoother in neutral now as well......the engine just feels better too!!!!! And!!!!...........my original issue of the engine stuttering and breaking up while in boost in pretty much every gear.......has totally vanished!!!!! ![]() I seriously feel like im driving a new car at the moment!!!!! Whod a thunk it that a purchase of less than $5 worth of dielectric grease would solve so many issues........I bet if all the srt guys on this website complaining of similar issues such as myself......minor or major......just put some dielectric grease on the ends of their plugs and wires........there wouldnt be so many confused and frustrated srt owners suffering needlessly spread the word!!!!! [IMG][/IMG] this is what i have found so far. this is what ill try tomorrow. this guy pretty much describe what is going on with my car, so imma try it |
#9 (permalink) |
![]() Join Date: Aug 2005
Member Number: 33036
your gauge reading wrong means you could be overboosting and you wouldnt even know it. You discribed what my car did awhile back when mine was overboosting. It would rev to the limiter fine, but when under boost, it would go over what the map could read and basically shut down the motor. change or barrow a gauge, find out what you're boosting and go from there.
#10 (permalink) |
Fresh Meat Moderator
![]() Join Date: Dec 2009
Member Number: 76568
Can you take a picture of this connector that you are seeing an arc come from?
Also have you changed your coil pack?
![]() Diablo CMR tuner ~Dan~ 2004 Black Neon SRT4: E85 stock turbo SOLD ![]() 310HP 436TQ 2004 Eblue Neon SRT4: E85 5558 ![]() XXXHP XXXTQ |
#12 (permalink) |
![]() Join Date: Feb 2005
Member Number: 24279
Overdramatic thread title is overdramatic .
I would gladly come by with a flatbed and the cash equivalent of your cars worth as scrap metal . (Jk) As stated if you are seeing a spark from anything grounding to the block then you have a problem . If its the coil or plug wires , then the fix is easy . If the spark is occurring at the harness branch to the coil then some repair and rerouting may be in order . My coil plug to harness section was very tight due to the way the factory routed it . The harness clip on drivers side of the head was causing too much stress on the harness . I think I used a zip tie between clip & harness as an extender to relax the tension . Not sure if that's your issue .
![]() S3 turbo/mani,S3 coilovers,SCT PRP,1025cc inj,AGP Race,N2MBWOTBox,ACT HD-Street,Hurst,Needswings |
#13 (permalink) |
![]() Join Date: Mar 2011
Member Number: 83768
Check the ground wires.
There's one on the passenger side that goes behind the engine, one on passenger in the fender well to the strut, one on each side of the hood where it connects, etc.
2004 Silver SRT-4
Stage I, AEM CAI, UDP, cut balance chain, muffler ![]() |
#15 (permalink) |
Member Number: 91842
Double check to make sure all your grounds are connected to a clean surface, then try a new coil. Any cel?
05 ob
3" tbe aem intake aem wideband dsp tokico struts hotckis springs xxr 527.... |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
